Question about Haier Heating & Cooling
I have air conditioner/heater will not come on after working for a while this morning.i alreaetdy tried reset button and doesnt help
    Champion:
  • 213 Answers
If the aircon is running to heater and the temprature outside is really cold [ sorry do not know the exact temp] the evaperator at the back will ice up and stop the aircon from working.if this is the case you just have to wait for the ice to melt. hope this helps cheers
Posted on Oct 19, 2013
yalmer
  • 549 Answers
SOURCE: Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Posted on Feb 25, 2008
  • 95 Answers
SOURCE: Thru-the-wall air conditioner won't turn on
Check for power at the plug in, if it's got power take it back under warranty.
Posted on Jun 10, 2008
  • 17 Answers
SOURCE: My Ruud Air Conditioner Model UAMB-048JAZ is not blowing cool air
3 things it could be:
#1 problem with AC units - dirty coils, this leads to many other problems and is caused by neglecting to change filters monthly. You can buy coil cleaner commercially, but it is not the coils you see that get dirty. There is another set inside that is usually not visible. If you look outside and your unit is "iced up" there is a 98% chance that is your problem. Sometimes it could be iced and you can't see it from the outside. Solution, turn AC off and blow fan to thaw. When thawed, clean coils with coil cleaner and coil comb.
Relay switches, you already pushed it so you may have a bad switch.
These are the two most common problems. A mechanic will be quickl to say it is your compressor for $. There are normally only half a dozen things that go wrong if your AC is 10yrs or less. If it is over that, it could possibly have a more serious problem. (Secret hint - I have known AC's to last 30+ years if the filters are changed regularly. Letting dust and dirt build up on coils invites a host of other problems due to the stress it puts on the other components.
Posted on Aug 30, 2009
  • 57 Answers
SOURCE: Air conditioner won't reset.
If you're trying to reset it right after it trips, you're not giving it enough time for the pressures to equal out.
Also, try again, unplugging it from the wall and waiting about 20 minutes before plugging it back in.
If it got a good surge from the storm, it may have grounded out the compressor.
Posted on Jul 16, 2010
SOURCE: Does the 76129 Kenmore Air Conditioner have a reset button
We have a Sears Kenmore 2537015600 that just quit working, will not power up at all. Is there a reset method on this unit or do we need to buy a new unit.
Posted on Aug 03, 2010
My air conditioner wont turn on
Good Morning Friend,
I understand that your Frigidaire air conditioner will not start. I also see that it slowly declined until it just gave out. I suggest contacting your local authorized technician for further assistance. They have been trained on your particular appliance and should be able to determine why it is not receiving power. I hope this is helpful.
-Best Regards-
WP
Jun 30, 2014 | Frigidaire Heating & Cooling
The heater won't heat in my window unit.
Hello Jim Hyde - Try pressing the reset button on the plug, if you haven't so already. If the unit continues to not heat up, contact a professional that works with your manufacturer to move forward accurately. Keep in mind that for some air conditioners the heating option is simply a supplement to help heat up a room but in most cases it will not completely heat up the entire room.
Oct 09, 2012 | Frigidaire FAC126P1 wall/window Air...
Vulcan Ducted Heater has gone into reset a couple of times in the past fortnight. This morning not in reset not functioning. Tried reset. no go, held reset on Bonaire wireless remote code F1 11 displayed??
Hello
You are experiencing a thermostat problem,what you simply need to do is to call up an experienced repairman and have the thermostat of your heater replaced
Apr 22, 2011 | Heating & Cooling
Hi We have a GIANT waterheater 60gal 4500watt 94-12 Problem: The water heater doesn't heat up anymore since about 24hrs. It's not the breaker we checked that. AND if we would like to RESET with the...
Yes, the reset probably is tripped...push in the red button hard
Then turn it on and try it...
Check out this tip..
How to replace the Thermostat and Element for
Electric Hot Water Heater
heatman101
Dec 12, 2010 | Heating & Cooling
Heater stopped working. Fan works, control panel diagnostic check reports no failure code. Placard on front of unit says heater unit has manual reset, I can't find a reset button or breaker for heater....
The front panel should be held in place by four screw at the corners or snap in place. Either remove screws or pull gently on top right corner to remove cover. You should see a red reset buttom type reset. Push it in to reset. Hope this helps. Thanks.
Nov 13, 2010 | Amana PTC123D50AR Air Conditioner
I have a AMANA PTh153B50AE (PTAC unit). The air conditioner works fine. It is when I turn on my heater and it does not get warm. It just blows cold air. I have looked at the board and it appears that...
I have the same problem, and I found the manual reset inside the unit. Turn the power off, and unplug the unit. Remove the outer cover of the unit ( inside cover ) , and remove the 2 screws holding the " wire mesh " in the front of the cover. Pull the wire mesh up and out of the way, then carefully pull out the heating element.
On the heating element, where the wires are connected, there is a manual reset button... Push the button in, till it resets...
My reset was on the upper left connection of the wires... just looks like a small push button, but the reset is recessed a bit.
Replace all covers and plug back in.. working fine..
Nov 12, 2010 | Amana PTH153B50AE Air Conditioner
Outside fan not working
Replace the fan motor capacitor and try again.
Jul 05, 2009 | Ruud Central System Air Conditioner
Heater not going on
Please send back the model number. Then we can narrow the roblem down.
Thx,
Peanut
RepairUSA
Jan 07, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
My electronic panel will not work at all.
This is not the most technical of solutions, but I had this exact same problem last night and I unplugged the air conditioner and left it that way overnight and this morning it had reset and was working again. I had tried everything I could think of to get it to work prior to just letting it be overnight. Hope this works for you, as well.
Jul 07, 2007 | Haier HWR06XC6 Wall/Window Air Conditioner
Heating & Cooling Logo
43 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Edd
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
