Washing machine aw 9770s
Washing Machine is weak or may not spin almost despite that Dryers operate but slowly
    Problem Solver:
  • 5 Answers
Is this a stack washer and dryer . if it is it will be connected to a 240 volt supply and sounds like its only running at 120 volts check main power supply either fuse or breaker is not tied
Posted on Oct 19, 2013
  • 67 Answers
SOURCE: duet Washing Machine spin cycle is spinning slow
make sure u are not under loading the washer with just one or two items and that the load is fairly balanced or else the machine will not go into high speed spin as to not go completely off balance and walk across your floor if that doesnt fix it you might need a new ccu or motor control board probably the second one and make sure u are using HE detergent and not too much because suds will lock the pump up which will not spin with water in the unit
Posted on Mar 20, 2007
  • 1294 Answers
SOURCE: Washer spins but not enough to extract water from clothes or tub.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Dec 31, 2007
  • 1314 Answers
SOURCE: Figidaire GLTF1040ASO Washing Machine
so is there still water in the washer it did not drain
Posted on Jan 24, 2008
SOURCE: washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Posted on Apr 21, 2009
SOURCE: Asea (Asko) Cylinda 12000 Washing Machine Spin Problem
No reset. Carbon brushes are worrn out. Consider changing the bearings while you have the motor apart. Se http://www.nettoparts.co.uk/shop/frontpage.html for spares.
Best regards, Dag Gulbrandsen, Norway
Posted on May 16, 2009
Agitator is frozen
my machine modelis AW-9770s
Dec 03, 2013 | KitchenAid Washing Machines
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
Nov 13, 2010 | Washing Machines
I have a whirlpool ultimate care 2 super capacity plus washing machine. We had it for about 7 years, just yesterday it stated to make an unusual noise when it was in spin cycle. As of today the washing...
My LSQ9549L is 7 yrs. old as well with an awful sound when spinning in high speed.
I've changed the agitator assy. as well as removed the drum and cleaned the soap build up on it.
Still makes a terrible sound in high speed spin. All other functions work.
Could it be the springs or coupling? I'm leaning towards it being the counter balance springs with it being rather weak. Could I be correct?
Your help is much appreciated.
Mar 22, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine will not spin. It will spin slowly but not fast enough to empty tub
Get the motor checked.Its either getting weak or the motor coupler is cracked.Also see if the drum is turning freely and nothing is blocking it.Any small cloth or any object blocking the drum. Thanks.
Jan 09, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
Jan 01, 2010 | Washing Machines
Washing machine spins slowly and smells of burning rubber
Your washer has brake problems you need a qualified repair person
Apr 02, 2009 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
