Question about Snap-On Welding Tools
I have a Snap On YA217A welder and needed to replace the switch- I made a sketch of where the wires connected to the switch and got a new switch however one of my employees threw out the paper I had sketched the location on so I need to find out where the wires go on the switch and was looking for a schematic with the switch to the location of the colored wires- thanks,
luxur4
  • 92 Answers
SOURCE: need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
Posted on Jan 23, 2009
luxur4
  • 92 Answers
SOURCE: SNAP-ON FM140A MIG WELDER. HOW TO SET UP WIREING
Hi, yes it can be ugraded but,( theres always a but,) you will need a feed from the mains to a rated connection on the main fuse box, this is not a DIY job, certain rules and regulations prohibit the unqualified. the new line will run to it's own fuse box, then to wherever you want, garage or w/shop with electrical cable 1.5biger than your max (30 amps) best be safe , you cooker socket is thirty amp, but thats max, there are some people that would increase the fuse size, ending up,( If they arel lucky), for a total re-wire those unlucky guy's arn't around to tell the tale. contact your provider and get it safe.
lets know how you get on
Posted on Mar 01, 2009
  • 14 Answers
SOURCE: need operators manual
call or email the company,theyll be happy to see there consumer spending there hard earned money to buy parts ect.,and if you ask nice they ll prob ly throw in a manual too. hope this helps jojogunne.
Posted on Mar 15, 2009
SOURCE: I PURCHASED A USED 185 MILLER SPOOL GUN..NEW IN
You will have to go to a dealer and get adaptor to unite spool gun & power source.
Posted on May 16, 2009
co7196
  • 3433 Answers
SOURCE: snap on ya219B mig welder. when welding, spark
Is your ground good?
Posted on Jul 06, 2009
Welder circuit board
That is not enough variance in the pot. The value should be listed on the POT.
Feb 22, 2014 | Snap-On Welding Tools
Snap on mw 120 turns on feed wire but no juice
Could be a poor ground at the work piece . The trigger switch might not be applying power to the nozzle. Check fuses and circuit breakers
Sep 26, 2013 | Snap-On Welding Tools
My snap on welder isn't working properly. With the heat dial turned all the way up, I have to turn the wire speed almost all the way down. Even with it in the hottest setting it welds cold. Won't even burn...
I own and love my Snap-On YA-212A and had a similar problem that turned out to be a power issue, not a welder issue. Repair costs and parts availability of these welders can vary wildly, it may be cheaper to replace it with a Lincoln, Miller, or Hobart. Snap-On uses more than one supplier to make their welders, if you tell me the exact model number I can probably tell you who manufactured it,
For now, try the following:
  1. Unplug the welder from the power outlet on the wall
  2. The power cable where it connects to the welder should be a twist lock type, make sure it is not loose. Take it off and look for any signs of arcing that look like it may have been a bad connection
  3. Look at the power connector that plugs into the wall and look for signs of arcing. If possible, take the back off the plug that goes into the wall and ensure that everything looks tight.
  4. Put the power cable back on the welder
  5. If your breaker box has a load controller turn it off and try your welder again
  6. Replace the circuit breaker in the breaker box on your house
Feb 26, 2011 | Snap-On Welding Tools
My snap-on mig welder powers on fine, wire feeds normally, but I only get a little blue spark and a sizzle when I try to use it
Initial setting it's wrong, you should have a vivid spark. If it just sizzle try to increase your voltage and wire speed.
Nov 07, 2010 | Snap-On Welding Tools
Lincoln Weld Pak 100 arc welder troubleshooting
There can be a switch that makes the wire electrically "dead" so it can be fed through the liner. Also suitcase style welders have a sensor wire with a clamp that must be connected for the arc to be able to be struck.
Nov 22, 2009 | Welding Tools
Snap on ya219B mig welder. when welding, spark quit working and feed at same time, which usually means overload switch above transformer and in front of fan. when it reset, i get no spark, but feed works....
I have the same problem with my ya219b every year or so. it is the diodes located on the aluminum plate above the transformer. usually they short first and cause the welder to grun and barely weld at all and the they open up and everything works except for welding. when replacing, pay close attention to the polarity of the diodes. there is usually a little schematic symbol printed on it to tell you which is the anode and which is the cathode
Jul 04, 2009 | Welding Tools
Snap On Ya219B No Spark
The transformer has an overtempature switch the shuts the welder down when its duty cycle is exceeded. After it cools, the switch will close and the welder will run again. However, you are not supposed to use the welder until waiting an additional cooling off period as specified in you manual(~10 min.).Also you are not suppose to weld beyond the duty cycle or damage could result. Especially if done on a continuous basis.
Apr 10, 2009 | Hobart Welding Tools
Relay clicks, gas blows, rollers dont turn
If you use it regularly, the liner should be replaced about every 6 months. Make sure you get a wiper for the wire. It goes inside the machine, on the wire, just before the feed rollers. It keeps the dust from clogging the liner.
Feb 08, 2009 | Miller Welding Tools
Welding Tools Logo
126 people viewed this question
Top Snap-On Welding Tools Experts
littlewheel
Level 1 Expert
Lawrence Oravetz
Are you a Snap-On Welding Tool Expert? Answer questions, earn points and help others
