Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
I cant remove the ice maker to replace it there is a screw at the bottom but seems to be two clips at the top I dont want to break it but don't know how to get the clips to release.
    New Friend:
Call a pro
Posted on Oct 19, 2013
bestdarngood
  • 3037 Answers
SOURCE: ice maker does not work
This is a quite common occurrence. You just have an ice build up in the ice maker. Make sure the prongs are vertical in the ice maker and defrost the freezer and dry it out and you should have it working again, it not let me know and there is something else we can do.
Please let me know how this works out though
A quick fix is to take a hair dryer to the ice maker but it may freeze up right away again so its best to defrost it.
good luck
Posted on May 22, 2008
  • 5626 Answers
SOURCE: want ice maker with crushed ice maytag
Try looking in your phonebook for Servall. It is a reputable appliance parts source. Or if you can check online for the Maytag website you can usually find the part yourself and order it or talk to customer service. Last, there are a number of online appliance parts companies which may sell genericparts for your unit.
Posted on May 19, 2009
woodchuck789
  • 4070 Answers
SOURCE: hi we have a maytag
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer
Posted on Dec 16, 2009
Testimonial: "we are very pleased with the advise my husband is working as i type this it was just what you said it was thank you"
TheMobilian
  • 8220 Answers
SOURCE: How do remove ice maker on modelMZD2766GEO? I
Their are 2 screws you just back out then lift up the ice maker and unplug the harness. Sometimes their are 3 and the bottom one def needs to be removed. Here's a secret tip: Sometimes you cannot get to the harness quick connect, if so just use a little screw driver to release the tab holding the harness to the head. The replacement wont have a harness and I think the reason why is just because of that. LOL
Posted on Feb 27, 2010
toolkits
  • 1099 Answers
SOURCE: ice maker is le
Check the hose under your fridge that drains condensation and such into a catch tray. Make sure the hose is draining properly.
Blow air through the tube to make sure it is not clogged. A coat hanger wire can be inserted to break up clogs. An alternative method is to use a bicycle pump to force air through the drain hole to remove any obstruction. Vacuum dust bunnies from under the fridge to allow free flow of the air. Most refrigerators periodically blow warm air across the condensation tray. The warm air dries the condensation in the tray.
Good luck......
Posted on Aug 01, 2010
How do I replace a broken ice full guide?
The ice maker is easy to remove once you get the drawer off the slides. There are two plastic clips located near the back of the drawer that attach it to the slides. Pop those out and lift the drawer out. Pull off the plastic ice maker cover to expose the mounting screws. Remove the two screws holding the assembly to the top of the freezer, then slide the ice maker forward about 1/2 inch. It will drop down a few inches, allowing you to unplug the wiring connector and remove it as a unit. The ice full guide is then easily removed.
Sep 06, 2013 | Samsung RF265AA Bottom Freezer French Door...
Tip
How to install/replace Icemaker in top bottom fridge
Start by unplugging fridge. Take 1/4 inch nut drive ( sometimes phillips ) remove bottom screw from under ice maker. Next loosen top to screws mostly out. The screws are located in brackets near the ice tray behind the front cover. Ice maker has brakets that the top screws slide into. Lift the icemaker up and out off the screws. Next disconnect the quick connect that is on the back wall of the freezer. Some models are hard wired into the icebox. If this is like yours than disconnect the quick connect from the icemaker itself. Take icemaker out of freezer and connect quick connect into or from new ice maker. Slide the new icemaker onto screws and into place. Screw bottom screw in and than tighten the top two screws. Place ice maker arm down so it can make ice. Give it 24 hours to cycle before it starts producing ice. Most of the time icemaker starts making ice within a couple hours. Plug in fridge.
on Aug 01, 2011 | Refrigerators
Samsung Fridge - Ice wont drop
Broken wires at the ice maker can cause that problem. Check your digital temperature readout at the top of the refrigerator with the doors open. If it reads 88 88 and has a flashing digit, check the ice maker temperature sensor for a cut or broken wire. The temperature sensor and rubbery gadget holding it in place often fall out of place when the drooping wires snag on the ice scoop or whatever. The sensor assembly is held in place by a wimpy plastic clip that breaks easily. Sometimes the wires get cut or broken when this happens.
After fixing this problem several times, I finally made a metal bracket from aluminum angle, drilled and tapped 4-40 holes in it, and drilled the plastic icemaker to mount it more permanently. I added a wire tie to hold the temperature sensor wire up and away from possible snag sources. The sensor wire and wire tie are not shown in the photo below, but if you have the tools to solder the wires and fabricate a bracket it helps a lot. It is easy to get the ice maker out, once you discover how to remove the drawer from the slides (two plastic clips at the rear of the slides).
Pull the front cover off, take out the two screws, and unplug the wire connector and it drops right out.
z
Ice maker assembly upside down on bench.
2q==
Aluminum bracket and screws
z
Bracket installed. The sensor is not shown in this photo, but the wire comes out the right side and crosses in front of the metal bracket. The wire tie holds it to the bracket near the top center (hole not shown).
Jun 11, 2013 | Samsung Refrigerators
Krups XP7230 - I am trying to disassemble the housing. I have removed several screws and pulled off the face ring. The topis loose but seems to be stuck in the back. I don't want to break anything. I...
no you are not missing a screw. There are two clips on the back that keep the top on even after the screws on top are removed. These can be seen by removing the paper manual and looking up to see two slots about a half inch each. I ended up pulling hard and the top came off. But I think a flathead screwdriver might also help separate the clip with little force.
good luck
jt
Jul 11, 2011 | Krups XP7230 Compact Super Automatic...
How do I replace the ice maker in my Sears side by side kenmore refrigerator model no 106.58142801 already have replacement ice maker just need to know how to install it and take old one out
Hello, Thank You for using FixYa. I will be helping you today.First remove the door that covers the icemaker it just pops off be careful it breaks easy. next there is one screw under the icemaker to the right side remove that screw.Now the piece that screw went through pops off.Now if you look under the ice maker,the rails that it slides into there are plastic clips you have to push up and slide the whole icemaker toward you. Thats it.
Thank You and please rate my answer if it was helpful..
Jun 11, 2011 | Refrigerators
Ice maker control arm has broken and ice machine keeps making ice. How do I stop the icemaker? And, then, how do I fix or replace the control arm (which appears to have snapped at the point that the arm...
Good day,
You will have to remove the ice maker. Usually 2 screws or clips on top and one screw on the bottom, as well as the plug that supplies the electrical power.
Since you'll need a new arm anyway, I would suggest you take the ice maker to any decent sized appliance parts house, and see if they'll pull the the old stub out and install a new control arm.
If that doesn't work, you'll need to replace the whole ice maker.
If you want to see if you can remove the stub yourself, unsnap the front cover. You'll see a semi-solid state type board. It is held in with 3 screws. Remove those, pull the board off, and inspect the area we are talking about. You might be able to get it out, but if not, go back to my first suggestion.
Oct 11, 2010 | Amana ARB9059CS Bottom Freezer...
Need to replace Ice Maker in bottom freezer
Good day,
3 screws hold the ice maker in place. On some versions the 2 top screws are replaced with clips, but it is self explanatory.
The cover is a tight fit, but un clips from the bottom first. You re-install by snapping it in place with the palm of your hand.
The wire pulls straight out of the front of the ice maker and then you wiggle the rear off its mounting hole.
HOWEVER,
What you described is classic of a bad water valve. Especially the overflow issue. I would change the valve first, and if it still has issues then replace the ice maker.
Apr 07, 2010 | Amana AFD2535DES French Door Refrigerator
Wire on icemaker came loose. I can't secure it back in to unit since it came loose on the door side and I cant see where it goes back in
Good day,
Suggest you remove ice maker. 3 screws(clips on top maybe), and the electrical plug.
Stretch the wire slightly and re-install the wire. If the action up and down seems normal re-install.
If the action is not working properly, you will either have to replace the ice maker head or best the entire ice maker.
Mar 01, 2010 | Whirlpool 18.2 cu. ft. Top Freezer...
Ice maker isn't working
the fingers should "normally" be in the 2 o'clock position facing the front of the icemaker. what we need to do is remove the front cover of the i/m look at the big gear in the center of the gear should be 2 clips that hold the gear in place. sometimes this clips will either break off or become compressed and then it doesnt allow i/m operation. the part is very easy to replace your self you need pt#8201515 that can be purchased thru a local appliance parts supply house or online thru  some place like sears.com. good luck peyton..
Jan 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do I remove the grate on the bottom to clean the coils
They are usually held in with clips that snap in and out. This is especially true if you don't see any visible screws. Give it a good tug on one side and see if it pops out.
Dec 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
