Acer Aspire™ T180 PC Desktop Logo
t
tracey coomber Posted on Oct 19, 2013
Red light on my tower and it wont work
I have a red light on my acer computer tower and it wont work
Mark Chapman
Level 1:
New Friend:
  • Contributor 54 Answers
  • Posted on Oct 19, 2013
Mark Chapman
Contributor
Level 1:
New Friend:
Answers
54
Questions
0
Helped
5413
Points
99
The red LED indicates that the hard disk is active. Replace hard disk.
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    I have a acer aspire T135 and when I turn it on to boot I get the red and green light with a loud whirring noise from the cpu anyone know what is happening and how can i fix it please
    sounds like the cpu fan and that would also explane the green then red lights also open the tower access panel but first unplug the unit,wait 30 secounds or so plug the tower back in then look at the fan sitting on the motherboard or main processer see if it turns on and make sure it keeps running they tend to start then if there is a problem they eigther don't turn on at all or turn off a few secounds later Im thinking later would explane the lights
    Veriton 7200D ACER - I went to turn on my computer today and it wont turn on. On the front of the tower there is a green light flashing intermittently. Looking at the back of the machine I see that the...
    Press and HOLD the ON/OFF button for TEN seconds, until the computer turns itself off.
    Then, press the ON/OFF button as per normal, and it should start.
    9helpful
    4answers
    Acer Aspire M1640 PC monitor 'no signal', tower non-responsive.
    i found the same problem (can't load BioS) but we are not alone as you can see on web about M1640 and M1641 it's very popular defect
    I made various test:
    cpu (pentiun e2180) pass the test mounted on another PC.
    I removed the two ram and replace with other ,result nothing (Pc power on but can't load the BIoS).
    Some of this Acer model have this motherboard crash
    look also here
    http://www.tomshw.it/forum/schede-madre-e-ram/129267-scheda-madre-non-da-segnali-di-vita-microstar-n1996.html
    http://www.tomshardware.co.uk/forum/271665-12-motherboard-problems-m1640
    http://www.fixya.com/search/p954810-acer_aspire_m1640_refurbished_intel_desk/acer_aspire_m1640_fast_ddr2
    http://www.tomshardware.co.uk/forum/270660-12-acer-motherboard-sak09-replacement
    Change the MotheBoard
    Acer Pc Tower Extensa E210, p4p800vm motherboard connection probl
    So I have found the answer myself ;o)
    I removed the front panel of the computer, behind the panel the wires were labelled, I connected the cables to the connectors that I required and connected them to the MoBo, works like a dream!
    Wont post led 3 flashes
    if its the red flashing light on the tower, its the hard drive activity light.
    when the monitor goes on stand by, does the tower retain power? (green light on and flashing red light sometimes?) Does your keyboard's scroll lock/num lock/caps lock keys and keyboard lights work?
    4helpful
    3answers
    Acer desktop E500 dvd drive to remove
    back? dvd.cd drives usually slide out the front.i think ur try to push a door that u have to pull. rating please. get back if not the solution
    2answers
    Acer 6800
    hi first of all check that nothing is touching the blades then spry some oil in the hinge (WD40..) make sure both ways of the fan are open for good air flow if the SUDDEN accelerations annoys you then connect it soo it will run all the time - take the red and black wires to the red and black wires of the 5v hardiscs good luck
    Steve Sweetleaf
    Steve Sweetleaf
    Grand Canyon Tech
    Grand Canyon Tech
