Question about Sewing Machines
My bobbin won't load on my Brother Sewing Machine XL21. Trying to remove the top case and can't do it? Afraid to break it.....how do you do this and how can I fix problem?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 42 Answers
You need your manual. If you don't put machine back together exact it will not run.
Posted on Mar 30, 2015
  • 4 Answers
When u say load do u mean it won't fit into the machine/bobbin well? If so, then you may just have the wrong size bobbin. If it is in there but the thread keeps jamming when u sew. Then it's in the wrong way. U may just have to flip it around.
Posted on Oct 19, 2013
4 Suggested Answers
SOURCE: Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Posted on Jun 23, 2008
SOURCE: bobbin case case keeps jamming
I am having somewhat the same problem with the exception that my needle did not break. I've cleaned and oil, but the bobbin case and projection positioned spring is not communicating to allow sewing to continue. The thread keeps jamming and the bobbin raises up the plate. So, what else am I to do?
Posted on Aug 07, 2008
Mimito7
  • 128 Answers
SOURCE: bobbin case on brother sewing machine
Well, from the picture I see that your bobbin is a front load as opposed to a top load.. if you tilt the front panel down, you will see where the bobbin and casing goes. Put the bobbin in the casing with the thread pulling from the right hand side of the casing making sure the thread in guided into the small **** on the top edge of the casing.. On the back of the casing the will be a small tab. Pull that away from the casing and enter the casing in to the opening for the bobbin. It should snap into place when you release the little tab.
Posted on May 29, 2009
MY THREAD GETTING WRAPPED AROUND THE BOBBING WHEN TRYING TO SEW THE TOP THREAD WRAPPING AROUND THE BOBBING CASE AND DRAGGING CAUSING THE TOP THREAD TO BREAK ?
It sounds like the lower shuttle is out of place. You should be able to take out the bobbin case and unlatch the shuttle. It will probably be in 2 pieces. Clean out the dust behind it and replace the shuttle pieces. You may have to fiddle with it a little to get them back in place. Then you can test it by manually turning the wheel. Make sure the bobbin is placed into the bobbin case and that the bobbin turns in the direction that you pull the thread.
Good luck.
Nov 11, 2014 | Brother Disney PE-180D Computerized Sewing...
Bolt under bobbin winder fell inside machine LS-2125i
My brother machine has 2 screws that are under the carry handle, this removes the top piece of the casing and then you should be able to just tip the machine upside down to drop the screw out. Hope this helps.
Jan 21, 2014 | Brother LS-2125 Mechanical Sewing Machine
Brother 1100 threading the bobbin
try changing the needle
rethread the machine top and bobbin
make sure to use every thread guide
make sure the top thread has not come off the thread take up
lever--this can cause the sewing machine to jam
if it's a top loading bobbin--take the bobbin out of the bobbin case
and turn it around and reinsert the bobbin
if it's a side or front loading bobbin take the bobbin and bobbin
case out and make sure the bobbin is inserted correctly into the
bobbin case and that the bobbin case is inserted correctly into the
sewing machine.
Nov 14, 2012 | Sewing Machines
Singer Confidence Model 7470 bobbin jammed, needles breaking, now won't sew
Sewing machines will get out of time, often as a result of broken needle. Search for sewing machine timing or take it for service, otherwise it will simply continue to break needles and possibly damage the machine.
Nov 11, 2017 | Brother Sewing Machines
Brother xl-2600 As I am sewing ( not thick material) the thread keeps breaking, also over seams it is not sewing through. Then, when my bobbin ran out, went to change it and when pulling the needle down...
try changing the top thread tension to 3 or 4
also rethread the machine just in case the thread is hung up somewhere
take the bobbin out & put the bobbin in reverse of what you did before
you said you changed the needle, check to make sure it in correctly,, the flat side goes to the back of the machine, push it all the way up before tightening the screw
Aug 06, 2011 | Brother XL-5340 Mechanical Sewing Machine
How do you load the bobbin properly?
Well you may please follow the steps below -
1. Remove the bobbin from the sewing machine. Note: whether you have a drop-in, front or side-loading bobbin on your sewing machine. A drop in bobbin will load from the top, may be via a removable bobbin case cover near the machine-fed dogs. A side or front loading bobbin needs to be loaded into a removable bobbin case under the machine.
2. Choose the right size bobbin for the sewing machine.
3. Wind thread onto your bobbin. Your sewing machine should have a standard thread spool to hold the thread and a short, squat post wide enough for a bobbin.
4. Put the thread and empty bobbin into position on your sewing machine. Wrap the thread around the bobbin to start it. On most machines, disengage the needle by turning the smaller hand-wheel on the machine toward you. Push the bobbin post into position, securing the bobbin into place. Press gently down. Thread should begin to wind neatly onto your bobbin.
5. Break the thread, push the bobbin post back into an inactive position and remove the bobbin. Tighten the hand-wheel. Thread your sewing machine again if necessary before loading the bobbin.
6. Remove the bobbin case cover and put the bobbin into position. The thread should slide through a catch on the bobbin case and up through the cover.
7. Access the bobbin case for a front or side mount bobbin. Lift the catch and remove the removable bobbin holder. Put the bobbin into the holder and run the thread through the holder, bringing it to the front. Lift the catch and slide the bobbin holder back into the case. Hold your needle thread gently forward with your left hand and turn the hand-wheel. The needle thread will pass down into the machine and catch a loop of the bobbin thread. Pull this loop up and slide both threads to the back before beginning to sew.
Good Luck!!
Thanks for using FixYa!!
Sep 22, 2010 | Euro-Pro Shark 60 - 384
Bobbin case on brother sewing machine
May 28, 2009 | Brother LS-2125 Mechanical Sewing Machine
Top & bobbin thread will not sew
Most likely the needle is in backwards. Weird I know, I have no idea why but if the needle is in wrong, it either hits the bobbin and breaks or won't grab the thread at all. Good luck.
Jan 06, 2009 | Brother LS-1520 Mechanical Sewing Machine
Threading and putting the bobbin back in the machine
Most machines have a bobbin case, that removes to place the bobbin inside and then the case goes back into the machiens. However some bobbins just load the bobbin flat from the top. The best place to start is with your machine's manual. If you don't have the machine manual, contact your machine's manufacturer or google "sewing machine manuals" as there are several vendors who sell replacement manuals. One of them is SewUSA.com and they have free threading diagrams on the site,maybe that would help you get started.
Feb 12, 2008 | Brother XL-5130 Mechanical Sewing Machine
Sewing Machines Logo
42 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
