Question about Dryers
Maytag MED9800TQ0 When I hit start it just says sensing
Maytag neptune washer code FL and DO
FL means the door failed to lock
DO
means washer door is sensed as being open.
Aug 19, 2016 | Maytag Washing Machines
Lid Sensing light flashing on maytag centennial washer wont start
could be the sensor has gone bad..but try unplugging for little while then reconnect it..it may reset ..good luck...also try Maytag help and support online..customer services
May 23, 2016 | Maytag Washing Machines
Maytag Epic dryer model MED9800TQ0. Dryer was running fine, changed loads, held the start button down, it beeped and attempted to turn the drum, clicked and nothing. All the controls light up, timer...
does the element come on at this point ?
I'm not sure if you tried this already or not, but i would unplug the unit and wait a min and plug it back in and see if it resets and then works again . you could have had a power surge .
Nov 05, 2013 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
Dryer only runs while holding start button in
We have a Maytag Epic dryer with the same problem (Model MED9800TQ0). Pulled out the control board yesterday and saw that the weld had been blown right at the motor relay (burnt marks surrounding the area on the flip side of the board where the relay attaches). Do you suggest we replace the motor relay or just try to re-soder that part on the board? Also - should we be concerned as to how this happened (that it was something elsewhere that caused it to blow)?
Jan 16, 2013 | GE Dryers
Maytag admiral refrigerator, the fan inside the refrigerator is making a loud sound when on and the cooling in the refrigerator is freezing
Makes sense, you are not moving enough air. Do not over fill the refrigerator. Fix the problem with the fan, if it is noisy I am 99% sure it is not moving enough air. To make noise something mechanical is hitting, it could be either the fan blade (cheaper to fix) or the motor.
Good Luck,
Gilshultz
Dec 01, 2009 | Maytag Admiral Top-Freezer Refrigerator
Interrupted washer won't start
Dear jwarbonnet,
ngfam at you service!
TRY UNPLUGING IT FOR 3 MINUTES AND THEN REBOOT IT!
IF THIS DOES NOT SOLVE IT THEN,
this sounds like it will only fixed by service
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Aug 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
Dryers Logo
121 people viewed this question
Top Dryers Experts
