Question about Elna Quilter's Dream 6003Q
How do you take the cover off of the Brother XL2121 machine? What is the trick without breaking it?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
....... these can be very tricky. You need to apply the right amount of pressure in the right place`in the right sequence. Do it wrong and you can damage the cover!
Posted on Oct 19, 2013
How do i remove cover
Lots of screws, then lots of clips to break off when removing the shells, then lots of fine cables to damage. Then a very big repair bill.
Save yourself a headache and a lot of money. Get it looked at by a trained Brother or Babylock tech. Brother makes Babylock machines so getting it serviced by a Brother shop because Babylock shops pay roughly 30% more for parts than Brother shops.
Feb 27, 2014 | Baby Lock Ellure
Brother LS-2000 machine with the up thread not keeping a good tension. Is it possible to remove the plastic cover on the up thread spring to check for lint ?
I have a newer brother too. I suspect the case is put together much like a laptop or game console is these days. But before I would go that far... maybe try "flossing" it with a piece of light canvas or denim folded double. ;)
Nov 29, 2012 | Brother Sewing Machines
My wife has a Brother XL-2027 sewing machine, Does anyone know where we can download a free copy of the owners handbook or users manual...
You can usually download free manuals from the Brother site.
http://www.brother-usa.com/manuals/default.aspx?PGID=3
I couldn't find a manual for the XL2027 but I did find one for the XL3027.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_XL_3025_3027_3030_EN_447.PDF
Also the nearest XL model number listed was the XL2121
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_XL_2121_EN_245.PDF
Worth looking at these two manuals to see if they are similar to your machine.
You could try contacting Brother (see the first link) as they may be able to help you find the exact manual for your machine.
Hope this helps!
Nov 04, 2010 | Brother Sewing Machines
Hook not picking the thread
If you need to retime the machine and you can't get to the raceway you will need to take the body apart which is not easy because therfe are plastic lugs on the inside that you can't see, break them and you are in trouble.
Apr 03, 2010 | Brother XL-5130 Mechanical Sewing Machine
Breaking threads... you so about an inch and it
It sound like it is not threaded properly or the tension is too tight, You should be able to pull on the thread manually without breaking it
look for your manual here
http://www.brother-usa.com/manuals/default.aspx?ProductGroupID=3
Jan 22, 2010 | Brother LS-2125 Mechanical Sewing Machine
Sewing machine circuit breaker
Sorry I have not seen that particular model brother here in Australia, however i have worked on and gone through training on similar looking models (training provided by Brother)
First off, whats the supply voltage difference? USA being 110V at the outlet, what does Ireland use? if not +/- 5% you will need a way of converting whats available at the outlet to what your machine wants (this could explain why it went "...bum..." to start with?
Also this machine will not use a breaker, A fuse is a hell of a lot cheaper, so you are looking for a glass tube fuse, likely about 12mm long.
Getting this machine will not be easy for you with out damaging it.
you will need to remove the light cover (one screw at the back typicly), there will be a bunch other screws in the back, and a few in around the bobbin area, and a few that where hidding under the light unit cover. Then while upside down, take the base plate off (if one) and firmly pry the front and back covers apart from the bottom. pressing at the join inside the free arm area to break the seal, the covers will then need to be taken as far apart as much as you can till you think it is about to break. Then hit it apart very firmly with the palm of your hand, you will hear a loud crack as it comes apart, this is normal. And if you missed a screw, you will need to replace the covers as you would have just broken it.
Best leave it to a pro if you value the machine.
Apr 30, 2009 | Sewing Machines
Brother Embroidery machine thread keeps breaking
the needle thread tension is wrong
bunching up under the material indicates that it is too loose
Nov 17, 2017 | Sewing Machines
My sewing machine has slipped its timing how do i fix it
take it to the shop or buy a good used machine from local dealer.
To repair it it has to be taken apart, the front cover must come off and if you are not experienced at this you will either break it or think you are breaking it
Apr 01, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
22 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
