Question about Electrolux Epic 6500 Vacuum
There appears to be no power coming to the hose at the connection to the canister. I put a volt meter tester's probes on the two points just inside the hose connect opening and got no reading while the machine was on and operating. Should I get a volt reading when doing this?
  • Electrolux Master
  • 1,290 Answers
You should be getting full voltage reading. The points deliver the voltage to the wires in the hose which transfers the power to the power nozzle. It is most likely a fault inside the machine itself.
Posted on Oct 19, 2013
4 Suggested Answers
BingoDabbers
  • 102 Answers
SOURCE: electrolux renaissance power hose
If the wires power a motor then it shouldn't actually matter as the motor is AC which has no polarity.
Posted on Oct 07, 2007
LizDahl
  • 75 Answers
SOURCE: Electrolux 2100 canister vacuum
Possibly the bag sensor is bad.
Posted on Jan 21, 2008
  • 430 Answers
SOURCE: Electrolux model 2100 shuts off with slightest suction blockage
This is exactly the symptom you would expect from a defective bag control valve. The actual control valve sits under the dial on top of the vac and often cracks internally. It can be replaced in about 15 minutes by a good tech with genuine parts from AERUS Elctrolux dealer or repair center.
You can open the vac front to rear like a **** shell by sliding the bumpers out the front with the bag door open, however you must be careful not to disturb the wiring harness and to mark wiring locations. The body must be carefully realigned for closure. If it is not perfect you will not be able to slide the bumpers back in.
Posted on Dec 17, 2009
How do I fix the beater bar attachment on my Oreck Canister Vacuum?
Well Anonymous, unless you have a continuity tester I'd say you will most likely need to take your machine to a vac repair shop. You need to determine if there is voltage going to the power nozzle portion through the hose and the wand. This is where the continuity tester comes in. If you have one and know how to use it, check the hose to make sure there's a clear path there for the juice to flow, if so, then check the outlet on the vacuum itself. If all is kosher at these two points then check the power nozzle itself. Somewhere along the line you will find an open circuit, that will be the problem that needs to be repaired or replaced. If you take it to a vac shop for repairs, they will do all this for you and then tell you what needs to be repaired and how much it will cost.
Oct 17, 2015 | Oreck Vacuums
The hose has come out of the fitting that connects it to the main body of my Henry vacuum cleaner - how do I get it back in?
You say that you have checked the belt, so I assume that you ensured that the belt is engaged properly and is not slipping. When you press the switch on and then off, do you hear the belt drive motor turning? If not, then you either have a defective drive motor or a defective switch. Testing the switch will give you the answer. To do that, first unplug the vacuum from the wall outlet and then gain access to the switch connections be removing any parts that prevent such access. Using an inexpensive digital multimeter set to read ohms, touch the two probes together and you will see the meter reads 000.0 and that is the same thing you should see if touching the probes to the switch connections with the switch in the "ON" position. In the "OFF" position, the meter should show something other than zeros, or show no reading at all. If your readings are as they should be, the switch is good and you then need to ensure that the wires connected between the switch and the belt drive motor are in fact connected securely and are not loose. If the connections are good then next you need to determine if you are actually getting power to the switch, and if you are then the belt drive motor is the suspect. If you don't know how to test for power at the switch using the meter or a test light then you should ask someone to assist you who does have that knowledge in order to avoid the possibility of electrical shock. If there is no power to the switch, there is obviously a bad connection between the switch and the power cord which feeds it, so you would need to trace those connections and determine the cause.
Jan 24, 2015 | Numatic Henry Bagged Canister Vacuum
I have a CT600 power brush that would not power up. Thinking the motor was bad in it, I replaced it with a new CT700 power brush, I am still experiencing the same problem the power brush itself does not...
First try connecting the power nozzle directly to the hose. If it works, the problem is due to a broken wire or faulty connection in the wands. At least one wand will need to be replaced.
My guess is it's probably due to a broken or disconnected wire. This could be in the hose (most likely), the wands, or the tank wiring itself. You can test the hose wiring by using a multimeter or continuity tester. A tester may be easier for you to use, and will provide the info needed.
Disconnect both ends of the hose, sit down, and lay the ends on your lap. Touch one end of the probe to a terminal on one end of the hose. Place other probe on a connector at the other end. One connector will light, the other won't. Now repeat with the other terminal at the first end of the hose and repeat. The terminals will read opposite the reading in the first test. If the light fails to turn on with either test, it's a broken wire in the hose. This is most likely near/at the handle end, or at the wall end. In some cases it can be repaired, but not always.
It could also be due to a faulty switch.
For a definite diagnosis, take the unit, the hose, power nozzle etc. to a repair center.
Jan 28, 2011 | Broan-NuTone VX550 Bagged Central System...
Carpet rollers dont work
Hi There,
Yes, there is a reset switch on your Electrolux. This particular model also has some problems with the wands on the machine as well. Sometimes these wands will short out, preventing the power nozzle from working.
Try pushing the reset switch first to see if this fixes your problem. The reset switch is located on the power nozzle on the right hand side if you're looking down on it. It will be a little red pole, simply push this pole downwards, possible using a ball point pen is the easiest way.
If this didn't fix your problem, then it could be a few different things. The wands on your model are problematic, and should be the next thing that you test. Simply remove the wands from the power nozzle, and you can use a simply electrical tester purchased from Home Depot, and put the testers into the female receptacles on the end of each section of wand to ensure that power is getting down to the brush.
It may also be that your hose has gone bad. If you test both wand sections, and no power is getting through, remove both wand sections and test the female electrical connections on the end of the hose handle.
If you're not getting power here, this indicates that your hose has gone bad and needs to be replaced. We do carry all of the hoses for the Electrolux canisters, and most likely have the one for yours in stock. Please feel free to contact me if you need any further help.
Thank you,
Chris Jones
GoVacuum.com
May 13, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Beater bar lost power - even after pushing reset button
Hi There,
If you've already tried resetting the power brush, and it still won't come on, this indicates that your electrical hose has most likely gone bad, and needs to be replaced.
This is actually a pretty common problem on Panasonic canisters, as well as Kenmore canisters (Panasonic makes Kenmore canisters).
In order to confirm this, what you'll need to do is purchase a simple electrical tester from Home Depot, or Lowes, and test the hose to make sure you have power making it through the hose.
To test this, remove the hose from the wand so you just have the handle of the hose in your hand with nothing attached to it. Put both ends of the electrical tester into the two female receptacles that plug into the wand, turn the machine on, and make sure that your hose is set to the carpet setting.
You definitely should have power coming to the hose at this part. If there is no power getting her, this indicates that your hose has gone bad. You may also just purchase a new hose (see link below), and if for any reason this doesn't fix your problem, you may return the hose to us within 60 days for a full 100% refund.
If the hose does have power at the end of it, repeat the process with the wand attached to the hose, but not connected to the power nozzle. If you have power getting to the hose, but not the wand, this indicates your wand has gone bad and need to be replaced. If you have power to your wand and hose, this probably indicates that the cord in the neck of the power nozzle has gone bad. Inspect the wire in the neck of the nozzle and see if you see any burning, or discoloration in on the male prongs.
I'm pretty sure that you'll just need to replace the hose, this is by far the most common problem on Panasonic canisters.
There are two different styles of hoses for Panasonic canisters. In order to find out which one is yours, remove the hose from the canister itself. Where the hose cuff plugs into the canister portion, look at the electrical prongs. There is either a 2 prong hose, or 3 prong hose. Here are links to both of the hoses. If your hose is a 3 position hose with a setting for bare floors, and carpets, then you have the 3 prong hose.
3 Prong Panasonic Canister Electrical Hose (Most Common)
2 Prong Panasonic Canister Electrical Hose
If this didn't fix your problem, please just use the comment section on this repair page and let me know what the outcome was after testing it with the electrical tester, and I'll be more then happy to try and do some more advanced diagnosing with you.
I hope this was helpful to you. If you found this helpful, please be so kind and rate my repair helpful, or leave feedback for me, this is really what keeps Fixya repair experts answering free questions, rather then just the premium questions that we get paid for. This is greatly appreciated.
Chris Jones
GoVacuum.com
May 07, 2010 | Panasonic MC-CG973 Canister Vacuum
Brushes not working on vacuum
It would be much more helpful if you would leave the model number of your machine so that I can know exactly which model you have.
If your Panasonic is a canister model, and the rest of the machine works fine, just not the power head, the first thing you should check is the reset button on the powerhead. On the top of the power head there is an "Overload Reset" button. This is a protection feature that will automatically shut off the brushes if anything is vacuumed into the brushes, i.e. sock underneath of the bed, tassels on an oriental rug, etc. This will cut off the brushes to prevent any damage to the belt. With the machine turned on, and the hose switched to carpets, push this reset button down, and the brushes should come on.
If this doesn't fix the problem, and you have a canister model, you may need to replace the electrical hose at this point. You can easily test the hose's continuity, by purchasing a $15 electrical tester from Radio Shack. Simply put one end of the tester into the socket that plugs into the wand, and take the other end, and test the electrical prongs that go into the canister itself, you should be able to determine if your hose is bad by doing this.
If your model is an upright style, the repair is much easier. When the brushes don't spin on an upright, this just means that your belt has either broken, or fallen off. If you'd give me your model number, I can easily give you instructions with part numbers of the belt you'll need to buy. Please just send me an email with your model number, and I'll send you a blown up parts schematic to your vacuum by email.
Let me know if you have any other questions,
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
Oct 12, 2008 | Panasonic Vacuums
Electrical to power head
Greetings from GoVacuum,
There could be a couple of reasons why you are not getting power to your power brush. The first and most popular reason is the hose of the machine. Sometimes the wires inside of the hose will go bad, causing the power not to get down to the power brush, but the rest of the vacuum working well.
You can test this hose easily. You will need to go out and purchase a continuity tester from Home Depot or Radio Shack. When the electrical test is in the continuity position, remove the hose from the canister, and put one of the testers on one of the electrical prongs that plugs into the canister itself, and put the other tester into socket where hose connects into the wand, you should have continuity on both terminals. It is important that the switch that controls the power brush is turned to the on position. If one of the terminals does not have continuity, you will need to replace the hose itself.
If both terminals have continuity, then you should then follow the same procedures on the electrical wand. If the wand tests ok as well, you may have a loose connection in the power brush.
Please let me know if none of these solutions work for you, I can then shoot a video showing you how to open the power brush to check for loose connections.
You do have a Miele S548, correct?
Please feel free to email me with any questions, I really enjoy sharing my knowledge of fixing and repairing vacuums, and would be delighted to answer any questions you might have.
Chris Jones
GoVacuum.com
Aug 09, 2008 | Miele S548 Bagged Canister Vacuum
Power to power carpet head
it sounds like the spring on the cord reel let go. difficult to reinstall. it may have been broken already and that is why it came off. it is rather meticulous trying to work on a cord reel. many can't be disassembled without breaking
Intermittent Power brush
I would first check where the hose attaches to the canister. There are 3 power leads; if one is bent, this might produce what you describe. You might even try wiggling this connection to see if it affects operation.
The other place you might see a problem is where the hose connects to the handle itself. There are 3 wires that attach from the hose. This is a bit tricky to remove as it's basically a force fit and take some effort to remove.
Dec 15, 2007 | Kenmore 22812 Bagged Canister Vacuum
Won't start
take an AC VOLT Meter and place the leads of the meter where the power cord terminates,one on the white lead and one on the black. There should be 110-120 volts AC. If that is good then move one of your meter leads to the other side of the on switch. With the on switch ON there should be 110-120 volts AC.If that is good, you may want to connect the motor directly to wall current to ensure that it is good. BE VERY CAREFULL IF YOU DO THIS!!!!!!!!!!!!!!!!!!! Before you do anything be sure to make sure that there is not a breaker or reset button somewhere on the machine that has been overlooked.
Oct 21, 2007 | Electrolux Epic 6500 Vacuum
Vacuums Logo
91 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
