Question about Speck Pumps Badu Ecom3 Variable Speed Pool Pump
The badu display just says stop. you cannot adj anything on the display.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Speck Pumps Master
  • 1,448 Answers
Sounds like pump is in a lock out mode try putting on manual
Posted on Mar 21, 2014
How do you use it
--- SCANNED INSTRUCTIONS ---
CLOCK AND DATE SETTING: 1. Press and hold MODE button for three seconds. The minutes display will begin flashing. Press MODE button to switch among minutes, hour, 12/24 hour, month and day. 2. Press ADJ button to set value of the minutes, hour, 12/24 hour, month and day. NOTE: Original screen will return after one minute of inactivity. To view the date, press ADJ button.
ALARM CLOCK SETTING: 1. Short press MODE button to switch from clock to alarm clock. 2. Press the ADJ button once to make the D))))) symbol appear, which will indicate that the alarm is on. Press ADJ button again and a bell symbol will appear, indicating hour notification signal is on. The hour notification signal
sounds once at the top of every hour. Press ADJ button again to activate alarm clock and hour notification signal, press ADJ button again to clear all.
MEMORY FUNCTION: 1. Press the MEMORY button for maximum temperature and humidity to display. Press MEMORY button again for minimum temperature and humidity to display. Press MEMORY button again to return to current temperature and humidity. 2. Press and hold MEMORY button for three seconds to clear maximum temperature, minimum temperature and relative humidity.
COMFORT DISPLAY: When temperature remains between 68F to 82F (20C to 28C) and the relative humidity remains between 50% and 70% "COMFORT" will be displayed. When relative humidity is above 70% "WET" will be displayed. When relative humidity is below 50% "DRY" will be displayed.
FAHRENHEIT/CELSIUS: To switch between Fahrenheit and Celsius, press FAHRENHEIT/CELSIUS SELECTOR button on back of unit.
INSTALLATION: 1. Use provided suction cups to position the sensor probes in the terrarium. 2. Position THERMOMETER & HYGROMETER in desired location outside of terrarium with a built-in stand.
BATTERY TYPE: 1 PC Button cell (AG13/LR44)
WARNING: Install THERMOMETER & HYGROMETER and sensor probe out of reach of pets and away from water.
For more information about All Living Things products, please call 1-800-806-7870.
Dec 24, 2013 | ALL LIVING THINGS Digital Thermometer &...
Radio display displays ADJ and won't operate
This is outlined in the owners manual please click here to download the manual
Feb 21, 2012 | 2008 Ford Escape
Pump is 10 years in continuous operation. Stopped working. Can it be fixed or time for a new pump? 660/341-4801 prnhcc@aol.com
you should be able to replace the motor and shaft seal. You may need a new impeller/diffuser as well. Will still cost less than a new pump, unless you want to upgrade to a more energy efficient pump like the intelliflo.
Oct 26, 2010 | Speck Pumps Badu Ecom3 Variable Speed Pool...
Wharfedale NE-571 How do i set the time on it i bought it second hand
Hold MEM/C/ADJ in power off/Standy mode until you see the clock display flash.. let go of MEM/C/ADJ using the forward/backward buttons above the volume dial select 12/24 hour press MEM/C/ADJ again.. you will see the left bank of digits flash.. press forward or backward to select your hour then press MEM/C/ADJ again set the minutes and then press MEM?C?ADJ again and your done!! ;)
I phoned ARGOS spares and got them to email me a copy of the instructions.. if you want me to forward a copy of the PDF to you let me know at darkmyble2006@hotmail.com.
Sep 01, 2010 | Audio Players & Recorders
6 monts old quartz model vz03-dd 2 weeks ago hands stoped, after adj. runs fine now all stops , no hands movement, no display.
Replace the battery. Does not matter watch is just 6 months old - battery was fitted long before you bought it.
Jan 24, 2010 | Watches
Cant set the time on this one at all
Setting the clock - must be done in standby mode.
Press PROG/CLOCK ADJ button . Either 12H or 24H will display.
Choose your preference by pressing the >>| button, then press PROG/CLOCK ADJ button
Press>>| button for HOUR setting, then press PROG/CLOCK ADJ button to store
Press >>| button for MINUTES setting, then press PROG/CLOCL ADJ button to store.
Oct 02, 2009 | iSymphony CR8CD CLOCK RADIO MUSIC SYSTEM...
How do you set time on the Armitron Women's Sport Large Digital Pink Resin Strap Watch #456963PNK+
Here is what I found....
Hi, I have a 40/6753 and here is what I found to set the watch
................Adj......................Start/Stop
...............Mode
.............................EL
Press and Hold down the MODE button until the display starts to flash that you are Adjusting the alarm. If you need to adjust the alarm here ya go :)
Press the mode button again and it switches from adjusting the ALARM to adjusting the TIME.
At this point the display will be flashing the seconds. Press the ADJ button and it will switch to Adjusting the Minutes. Press the AdJ button to advance the minutes.
Pressing the Start/Stop will switch to Adjusting the Hour. Again pressing the ADJ button will advance the Hour until you get to the correct one.
Once correct press the Start/Stop to switch to Adjusting the DATE. Press the ADJ to advance Month and Day.
Pressing the Start/Stop will finally switch to Adjusting the DAY OF THE WEEK. (little circle to the left hand side). Again, pressing the ADJ will advance the Day until correct.
This took me an hour just pressing buttons until I could figure this out. I hope this helps everyone.
Joe
Posted by: Joe From Oregon on February 04, 2008 at 09:39 PM
Aug 24, 2009 | Armitron Watches
How do I set my Kahuna watch. In particular stop the hourly beep
From the Time display press 'Mode' twice or until you get to the Alarm display.
From there press 'Adj' to toggle on/off the Chime and Alarm icons.
May 05, 2009 | Watches
Need an owners manual
to set the 5 main presets:
with radio on, use the manual tuner to find station you want on a preset. push and release mem/clock adj button (mem will flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that number.
to set the 5 additional presets:
with radio on, use the manual tuner to find station you want on a preset. push and release the +5 button (+5 will flash on display), push and release mem/clock adj button (mem will also flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that +5 number.
to set the digital clock display:
with radio off, push and release the mem/clock adj button (clock display will now flash), use the tun up / hr part of manual tuning button to adjust hour and the tun dn / min part to adjust minutes.
Apr 05, 2008 | GPX HDT4004SP AM/FM Radio
How do you set the wake up? So the radio turns on automatically? each morning
I did not find my manual, but this worked for me. Set the clock to be a 24 hour clock by pressing and holding the Memory/Clock Adj button. The display will show 24h or 12h. Use the fast forward button to change from 12h to 24h. Press the Memory/Clock Adj button again and use the fast or reverse forward buttons to change the time to read, for example, 13:00 instead of 1:00 if the time is 1pm. Press the Memory/Clock Adj button again to set the minutes.When you are done setting the time, press and hold the Timer/Sleep button. Either a time or "0:00" will appear in the display with the word "TIMER" flashing above it. Quickly press and hold the Memory/Clock Adj button until the first digit in the time starts flashing. Set the hour that you wish the alarm to sound using the fast or reverse forward buttons, just like you do for setting the time. Press the Memory/Clock Adj button again to set the minutes, and one more time to finish. The word "TIMER" will stop flashing and go solid, and the display will return to the time of day. When the alarm sounds, you can hit Snooze which will give you 5 more minutes, or you can turn the Clock Radio off. Pressing the Timer/Sleep button again will turn off the timer (alarm) and pressing and holding it again after that will turn it back on.
May 28, 2007 | Teac LT-1 Clock Radio
Speck Pumps Badu Ecom3 Variable Speed Pool Pump Logo
74 people viewed this question
Top Speck Pumps Pool & Spa Experts
k24674
Gil Shultz
Jay Finke
Jay Finke
Are you a Speck Pumps Pool and Spa Expert? Answer questions, earn points and help others
