Question about Innovera 16010 One Color Printing Calculator - AZERTY INCORPORATED
16010 ivr manual
How do I replace the paper tape?
Mfj-16010 schmatic
Why not just google the above?? http://www.wimo.com/antenna-tuner-mfj_e.html http://www.wimo.com/antenna-tuner-mfj_e.html
Jun 11, 2016 | MFJ 16010 Antenna tuner, 1.8-30MHz, manual
How to load paper in innovera 16010 calculator
You should check it in Users Manual. If you don't have one, try to download it from Internet, Use google to find it.
Oct 08, 2014 | Innovera 16010 One Color Printing...
How to load paper in innovera calculator
You should check your User's Manual. If don't have one, dowwnload it from internet search with google.
Oct 08, 2014 | Innovera 16010 One-Color Printing...
How do I stop my IVR-16010 from rounding off my answer?
This makes zero sense, but you must press the "tab" button. Also I know this is two years too late, but no one has answered this question online and someone might find this helpful.
Aug 16, 2014 | Innovera 16010 16010 One-Color Printing...
Needles on my Gauges are absolutely crazy! 1996 Pontiac Grand Am SE V6
1= this happen because th IVR fail, see the diagram and test it use the DVOM OR VOM for test the IC .l
2= test the thermistor or sensor for defective.
3= if the voltage of IVR is out of regulation in this case +12vdc,test for ground.if is o.k test by the side of battery side of the IVR, if this voltage is present replace the IVR, if regulated voltage is withing specifications, test the printed circuite from the IVR to the gaues, and if there are open circuite replace the circuit board. OF course test the fuse too.
God bless you
Jul 14, 2012 | Cars & Trucks
I HAVE A VIDEO WITH AN IVR FILE, I HAVE NO ENGINE FOR IVR FILE, I HAD TRIED DIFFERENT COVERTER BUT NONE OF THEM SUPPORT .IVR FILE. PLEASE ADVICE
.IVR Files are a "Video format developed by RealNetworks for sharing video clips on the Web; may be created by using the "Record" feature in RealPlayer 11 or later; saved in a proprietary format that can only be opened with RealPlayer."
Basically, Real converts these videos to .ivr files so that you don't use other video players except Real to view them, and so you'll pay Real for a subscription to be able to convert the files. If you actually right click on the .ivr files in your Real Library there will be an option saying "Covert Media Format..." and if you click on that it will tell you you have to upgrade to Real Player Plus in order to convert.
There is a work around i found while googling, you can also burn your files to a dvd or video cd and then rip them back to your computer and they'll be in another format. The downside is that this can take more time if you want to convert a whole lot of files and you have to have dvd's and cds at your disposal. but at least it works.
Hope it Helps!
CreativeTTECH
Nov 24, 2010 | Computers & Internet
Ricoh - Mpc4500 displays adding toner when you open/close door
That model, as most Ricohs, uses the ID sensor to determine when and how much toner to add. I would check to make sure it's clean, no toner or paper dust. If that's not it you might need to replace it.The ID sensor is located in the PCU, facing the drum.Good luck. If this helps, please remember to rate this. Thanks
Jul 03, 2009 | Ricoh Office Equipment & Supplies
Java code for IVR system
dear friend check these websites:
http://www.java2s.com/ http://www.sun.com/
You can get your answers about java there. Goodluck
Jan 22, 2009 | Cisco IPCX OR IP IVR 3.5 3.Y MS SQL SVR 1...
Correction Tape
The correction tape which should be a yellow spool and the correction ribbon cartridge should be a yellow also, sometimes orange, first. The correction tape has to in front of the black correction ribbon. in othe words this is the order. Platen, paper, correction tape, correctable film ribbon, printwheel. Also make sure correction tape is dull side toward paper. Shinny side should face operator...
Aug 12, 2008 | Brother ML-100 Typewriter
Xerox Phaser 8200 false "Replace Paper Tray" message
I've had a similar problem with a client's 8200 printer, and looking at the right hand side of the tray someone had previously put some tape over the topmost 'slot' (above where the green slider goes across).
I put some new tape over the top slot and the 'replace paper tray' message went away.
Admittedly, the tape gets pushed in so I don't know how long it will be before the tape gets dislodged and the error re-appears.
The printer is well out of warranty and they don't want to pay anything to get it fixed... so this solution is fine with them.
Hope this helps someone else out there :-)
Jul 02, 2008 | Xerox Phaser 8200 Laser Printer
Innovera 16010 One Color Printing Calculator - AZERTY INCORPORATED Logo
96 people viewed this question
Top Innovera Computers & Internet Experts
Mister Danger
Timothy Gore
Timothy Gore
Are you an Innovera Computer and Internet Expert? Answer questions, earn points and help others
