Question about Sony STR-DE505 Receiver
SONY STR DE-505 PROTECT - Sony STR-DE505 Receiver
SOURCE: Sony STR DB-930 Receiver jumping into protector mode
I went through the amp/receiver and used small star washers on all the grounding screws I could find including the one securing the transformer, cleaned dust off all circuit boards, checked output transistors and fuses, all OK.
Re Assembled unit and it worked OK.
I will buy a fan and fan it to avoid sourcing heatsinks for the previusly suggested IC's.
Thanks for the technical help, sure solved my problem.
Regards
Darryl.
Posted on Mar 13, 2008
  • 3 Answers
SOURCE: code for sony receiver model str d565 protect mode
If you need support you can log into:
http://esupport.sony.com/US/perl/support-contacts.pl?mdl=STRDG510
for free tech support on sony chat line
Posted on Jun 02, 2008
  • 336 Answers
SOURCE: sony str de415 ( protect
You can try tighting the ground screws that hold the circuit boards and heat sink to the chassis, But more times than not it will need a pair of output transistors replaced (and a few resistors). This is a job for a pro. A rough estimate is $100-$130.
Sorry for the bad news.
Posted on Mar 08, 2009
mjjdesigns
  • 98 Answers
SOURCE: PROTECT DISPLAYED ON RECEIVER
This generally means you've got a short somewhere, and the received is trying to protect itself.
My suggestion is to disconnect all of your speakers at both ends, and reconnect them.
Most times this happens because a speaker wire is lose, and the positive and negative connections are touching each other, causing it to short out.
Posted on Mar 25, 2009
ginko
  • 19396 Answers
SOURCE: stuck in protect mode
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
Posted on May 29, 2009
I have a Sony STR-DE 597 reciever. I have been using it fine for a few years with no problems and it sounded great. I turn the unit on recently and a message was displayed on the unit that said PROTECT....
Protect will usually show up if the receiver was turned up too loud to the point where the speakers will crackle, the receiver will switch to protect to not damage anything. Unplug it for about 30 seconds and check all the audio wiring in the back to make sure everything is plugged in good and tight and no loose cables or stray pieces of copper audio wire and plug it back in.
Aug 21, 2011 | Sony STR-DE595 Receiver
Hi. my sony STR-DE 597 go in protect mode. how can I fix/repair this? Give me a tips.
protect mode means there is a shorted components inside your reciever it's probably the out put transistors take out the transistors and test it with a multimeter.
Jul 11, 2011 | Sony STR-DE597 Receiver
Sony str de 475 ?? is appear 'protect' on screenboard and can not listen anything
The message appears usually when the wiring is wrong (short circuit) or the speakers are defective or their impedance is too small for the amplifier's output (for instance 4 ohms speaker connected to an 16 ohms output). First, check your connections.
May 15, 2011 | Sony STR-DE475 Receiver
Sony DE-445 reciever flashes PROTECT
Sounds like a grounding problem. If the ground plug isn't missing or loose try plugging it into a different outlet.
Jun 13, 2009 | Sony STR-DE445 Receiver
Sony STR-DE 697
Hi there. Sounds like you may have some wires that go from your stereo to speakers touching.Check all wiring and make sure none are touching especially behind you amp...
Mar 29, 2009 | Sony STR-DE697 Receiver
Protect flashing
es posible que un canal se ha dañado por lo que primero daño el fusible con la sobrecarga y posteriormente se daño el canal. es necesario se revisen las polarizaciones de los transistores para determinar el canal dañado,es seguro que el daño se encuentra en uno de los frontales.
Mar 21, 2009 | Sony STR-DE345 Receiver
My reciever does not work
Power Amp IC gone in your set, replace it.
Jul 30, 2008 | Sony STR-DE575 Receiver
Help
check/replace your speaker wires. If a wire came loose, it will go into "protect" mode and shut down, to protect from a short circuit.
Jun 16, 2008 | Sony STR-DE525
78 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
