Question about Watches
Surface watch model 31553 - Watches
I need locate instruction for a surface watch
Try Googling (surface)(model)(manual) without parens.
Jun 06, 2017 | Watches
Setting up the Surface 33416 watch.
sadly I would have to have it in my hand to tell you .
Nov 19, 2015 | Watches
Can you help me set my surface watch model 33009
Are you sure the number 33009 is correct?
Most Wenger watches have 5-digit numbers starting with 7.
There is a Swiss Military Manual here:
https://www.wengerna.com/stuff/contentmgr/files/6/540159dc9885eeee1a65eec748ed4597/pdf/swiss_military_watch_manual_2012.pdf
May 07, 2014 | Wenger Swiss Military Classic Field Watch...
How much is a capacitor
The Capacitor itself is 20 dollars. There are different Capacitors for the different Calibers (models) of watch. If you want to install the Capacitor itself I recommend swatchbattery.com. They have a long and clear list of which Capacitor for which Caliber. And they have 2 brief tutorials on how to install the Capacitor. I do NOT recommend it if you are not very very comfortable working deep inside a watch. This is far different than simply replacing a battery in a Casio or Citizen, where the battery is "on the surface" and extremely easy to reach. This involves some special tools and special skills.
Feb 04, 2013 | Seiko Kinetic watch
Hour hand does not move minuet hand does not move but second works
Loose cannon pinion or cannon driving wheel, depending on model of movement inside the watch.
The seconds hand represents the wheels in the back of the watch going around ok, but the power need to transfer through to the front of the watch somehow. This is done by snapping/clicking two wheels together on either side of the main plate. The one on the dial side (cannon pinion) needs to slip to be able to set the time as the minute hand is set on this pinion. From there it is one wheel to the side & then back into the centre for the hour wheel. Over time the mating surfaces wear & become loose, meaning that the two hands driven fron the front of the watch are not being carried anymore. Time to see a repair guy!
Feb 14, 2011 | Watches
How to open the back of Kenneth Cole KC3434 watch to change the battery?
BASIC WATCH BATTERY CHANGE
Get a replacement battery for your watch. Some watches have the battery information stamped on the back plate. If yours doesn't, you'll have to wait until you've removed the old battery to see what kind of replacement watch battery you'll need.
Lay your watch face down on a non-scratching, non-skid surface. It may help to clamp the watch to the surface.
Remove the back from the watch. You might be able to pry it off with your fingernail, but you'll probably need a stiff, thin tool like a knife or screwdriver. You can also buy watch repair kits, which have the perfect tools for the job. Check the watch back for a small notch to insert your tool, but not all watches have these.
Remove the battery from the watch once the back is off. You might need to tip the watch over to let the battery fall out.
Insert the new watch battery into the proper space, first double-checking its size against the old battery to make sure it will fit. Press lightly into place.
Replace the back on your watch. Make sure you press firmly to get the back seated snugly.
If this doesnt work, then take to a local jeweler/watchmaker who is equipped with the right tools to assist you.
Best regards.
Aug 17, 2010 | Kenneth Cole KC3434 Wrist Watch
Battery replacement. can not get back cover on.
mcdevito75 here, First look for any for any notches or cut outs on the cover, there should be a cut out on the cover for the stem, at this point line up the cut out with the stem, place the watch on a sturdy surface, Table, counter top, make sure the watch is completely flat on this surface with the cystal (glass) faceing up, now place the palm of you hand on the crystal and with even pressure press down slowly and evenly, the back should snap on.
Jun 16, 2010 | Pulsar PXH225 Watch
Surface Watch Model 31819 How do you turn the alarm off?
I have a Surface Watch. Not sure if it's the same model number, but the button set up is the same. Here's what I did:
Hold down the bottom right button. While you're holding it down, press the top right button. My bottom right button doesn't seem to always work, so it made it rather difficult to figure out what has going on.
Dec 03, 2009 | Watches
SCRATCH ON BLUE BEZEL OF WATCH
If it a scratch on a brushed surface try one of these watch Brush pens
Here only a couple bucks
If it is on a polished surface
try a cape cod cloth here
both are indispensable watch collectors items.
Dec 30, 2008 | Tag Heuer 2000 Aquaracer WAB2011.BA0803...
Casio 2688 Wave Ceptor - No Display
On the solar charge watches, they use a chargeable Lithium battery. It is NOT an off the shelf regular battery! It is best to send the watch to the factory service rep in your area for a battery change.
In many of these models the battery is using solder contacts to the circuit board. The person changing the battery will require the original spec battery, and be equiped to do surface type soldering.
When working on this watch, the factory service will change the seals and do a pressure water resistance test. The regular corner watch service store is not equiped to do this type of testing.
Normaly, the battery in solar watches should last more than 5 years. Some are going past 10 years!
Jerry G.
Feb 23, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
