Question about Seagate Computers & Internet
No power when i plug in
I put the power cord and usb to Freeagent external HDD and no lights is there a reset of some sort?
  • 55 Answers
Did you try a different power cord?
Posted on Oct 21, 2013
  • Gail Chambers
    Gail Chambers Oct 21, 2013
    i did and i wonder if that could be the issue?
Coldcut
  • 1554 Answers
SOURCE: External HDD continuously beeping
The beeeeep beeeeep long twerps is the hard drive trying to spinup. drive don't beep unless they have died.
Posted on Mar 22, 2008
SOURCE: Seagate FreeAgent External 500GB HDD - Data Recovery
well firstly if u wana recover ur data u have to make the external hdd power up but thats the major area of issue that its not powering up. the difference in plug doesnt make a difference cuz u can use the same plug,the voltage is same thorugh out in ur place from the substation. so it might be a possibility that when u connected ur hdd,the power ON/OFF switch was awredy ON IF hdd has one. so wat i feel is dat u can try opening the hdd and then connect the hdd to ur desktop with help of the BUS CABLE used to connect the HDDs in desktops. so in dat case i would suggest that u go through the manual of ur external hdd to see how to access the the casing in which the hdd is there.then if u happen to get thorugh n it turns on then u dont have to recover ur data. it would still be there. HOWEVER,its recommended that u dont try these things personaaly if u are'nt too tech savy. u shud consult a tech or a freind who knows abt this.
Posted on Oct 06, 2008
  • 58 Answers
SOURCE: Freeagent desktop external hard drive will not power up
I have my own Seagate hard drive and with mine you have to plug it into the computer and power source for it to power on.
Posted on Jan 10, 2009
SOURCE: Seagate External Hard Drive powers down after being idle.
If you load the Free Agent Software, there is a utility for setting the power saving. You can set it to a number of different times including never. The default is 15 minutes. I think this is what you are experiencing. The settings are in the Utilities tab.
Posted on Jun 17, 2009
yashrajsen
  • 61 Answers
SOURCE: Seagate freeagent 1TB Ext HDD wont power up.
try with removing and reconnecting the bus cable and smps cable.
and try with different bus connection
Posted on Jul 13, 2009
Input voltage?
looks like it is 12 V, 1 to 2 amp.
her are some power Adapters listed on amazon. Also, look on the bottom to see what polarity it is (also by mosue over the picture of the adapter in the bottom link (to zoom in)
Amazon com Pwr Extra Long 6 5Ft Cord AC Adapter Charger for Seagate Hdd...
Amazon com Super Power Supply AC DC Adapter Charger Switching Cord Plug...
Apr 28, 2016 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My seagate freeagent 1tb is blinking whit lights and my computer does not recognize it. Help me
***Please NOTE***
Touch the drive and put your ear to it, to test if the drive is spinning and working. Do this while it is powered on. Also, try disconnecting the USB cable, reboot the computer, re-connect USB cable to another USB port on computer. If you still have the same issue, try the below solutions.
  • Make sure the computer and external hard drive are powered on.
  • Disconnect the external drive's USB or the eSATA cable, which ever one you're using.
  • Disconnect the power supply plug from the external drive.
  • Power off the computer.
  • Disconnect the computer's power supply cord for 60 seconds.
  • Reconnect the computer.
  • Power on the computer.
  • Connect the power supply to the external drive.
  • Connect the drive's USB or the eSATA cable and check for detection.
If the still no detection and still blinking lights on the drive, check the power supply to the drive.
Check to see what the led light on the power supply is doing.
If it's blinking, power down the drive, unplug data cable and then reconnect the power supply to another electrical outlet. If it still blinks repeatedly, then you power supply is bad.
If the led is solid (lit and not blinking) follow the same steps from above to connect it to another outlet.
Next, plug the power supply to the external drive and power it up.
If the power supply starts to blink repeatedly, then your controller board inside the enclosure is bad.
Thank you for the opportunity to help you.
Jun 04, 2011 | Seagate FreeAgent Pro 1TB External USB...
Hi I Have an I O Error On My External Hard (500 GB Seagate) and I can't open or copy my files. Please Help Me. Thank You
  1. Unplug both the power cord and USB cable from the external Seagate hard drive.
  2. Restart your computer
  3. Plug back in both the power cord and USB cable from the external Seagate hard drive.
Comment back if this doesn't fix the issue.
Mar 01, 2011 | Seagate FreeAgent Pro 1TB External USB...
Hard disk is not working
1.- check USB cable
2.- power cord
3.- try HDD direc to the main board and check if work?
Dec 18, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have a 320gb beyond micro external hard drive. it has been working fine up to yesterday. when i turned it on it started making a wierd noise, sort of like a humming noise that has a kind of pattern to...
If you get no joy using the Troubleshooting Guide then try this...
You will need to check You Tube to find a Dismantle on your product and follow the step guide on here, the procedure should be similar.
Check 1st that your External HDD has an P.C. internal HDD inside, from You Tube, before dismatle of your External HDD. Connections for an Internal Laptop HDD may have same connections as P.C. not sure though.
Once your happy that it has continue reading and follow the step guide on the link below.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not reconized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 Thread can be found in 'Technical' under 'General Technical Issues'
Thumbs up please if it's any use to you Thank you.
Aug 24, 2010 | Beyond Micro Computers & Internet
Suddenly stopped working
i think your hdd is dead,Because your hdd light not even turn's on....
Apr 09, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Lost FreeAgent Pro power cord...where do I get
You can pick up a replacement cord at radio shack. they have universal cords that match the power rating.
Sep 02, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Jul 13, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Oct 06, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
External Harddrive Ignorance...
I've seen this happen with hubs being connected to external hard drives before.
Do you have a free usb port on the back of your computer you can plug it into?
That should fix the problem.
Jun 11, 2008 | Belkin (F5U233-APL) 4-Port USB Hub
Computers & Internet Logo
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
