Question about Grandstream Budgetone Bt-200 Bt200 Voip Sip Ip Phone
Reset all funtion - Grandstream Budgetone Bt-200 Bt200 Voip Sip Ip Phone
My o2 goes to hard reset when press button to unlock
http://xda.o2.co.uk/pdf/user_manual/Detailed_XdaIIs_Windows_Userguide.pdf
Mar 15, 2010 | O2 Xda IIs Pocket PC
How can i reset to factory settings? i changed to sci mode trying to figure out how to use 10^x funtion and now it gives me weird answers!!
Hello
To reset to floating mode press [2nd][FLO]. The scientific display mode will be replaced by the floating point mode.
Hope it helps.
Sep 25, 2009 | Texas Instruments TI-30XA Calculator
Won't reset to zero (60 sec.) after battery was replaced
You need to "Reset" the watch's computer, this is done by removing the case cap, (Same as battery replacement) Look for a imbosed "RESET" and using a paperclip, Push gently in the reset hole for five seconds, Remove the paperclip, You should then have all funtions restored to "Factory Settings"
May 20, 2009 | Casio Watches
Sony CDX-M600R car radio CD: Radio does not work, CD player OK and all other funtions OK. When in radio mode can hear white noise but no transmitions.
I had this before with my unit, I did a system reset by holding down the reset button for about 5 seconds - all back to normal then.
Apr 15, 2009 | Sony Car Audio & Video
I lost over half my options and can not find a reset button
no reset on pioneer. You have to either disconnect it from the wiring loom or disconnect the battery. Allow a minute or so if disonnecting battery on car so as to discharge any capacitors in device.
Oct 26, 2008 | Pioneer DEH-2700 CD Player
Multiple copies of same song on device
Just resync the device to the computer after
a) resetting the GoGear (volume + and play/pause at the same time)
b) restarting the computer
-Tha Mp3 Doctor
Mar 30, 2007 | Philips GoGear HDD6330 MP3 Player
Grandstream Budgetone Bt-200 Bt200 Voip Sip Ip Phone Logo
26 people viewed this question
Top Grandstream Computers & Internet Experts
David Payne
David Payne
Are you a Grandstream Computer and Internet Expert? Answer questions, earn points and help others
