Question about Amana ACS3350 Gas Kitchen Range
Amana aer5330bas0: in the midst of cooking, the oven had just been turned off and the stovetop was in use, first one burner would not come on, then the one that had been on went off, and then the entire display went off. The electric range was complete dead. No sound was made and no circuit breaker was tripped; no problem with electric power to the range. It just completely shut down and will not come back on.
    Top Expert:
  • Amana Master
  • 9,472 Answers
This is how the "control clock" goes out. You will need to replace it and all will be good. Here is the part to order and on that same page is a video to show you how to swap them out.
The part also come with a 365 day, any part, any reason return policy.
Posted on Oct 20, 2013
4 Suggested Answers
SOURCE: amana gas range will not heat up in bake mode
it turned out to be the igniter...a friend tested it and found it to be bad.....
Posted on Nov 17, 2008
  • 291 Answers
SOURCE: electric oven and stovetop do not work, clock and oven light do.
Sounds like you are only getting 120 volts instead of 240 volts. Either a house electical problem or wiring in range. First go to your breaker and turn it off and on three times and give it a little extra push each time you flip it. ( You can actually flip a breaker off and on without resetting a blown breaker if you doni't push it all the way off and all the way on. If the breaker throws itself off do not reset it. You have an elecrical short in your house or range. If resetting the breaker does not work then you need to test for 240 volts coming into the range. We don't recommend you do any electical testing unless you know what you are doing with electicity. If you have 240 volts going to the range then unplug your range and remove the backing panel off the back of the range. Look for burned wiring or terminal blocks. If there is nothing obvious then you need to know how to read a wiring schematic and use a electical tester to go any farther. Let me know if this helps. Good Luck, Appliance Specialists
Posted on Dec 15, 2009
oldTech2332
  • 2341 Answers
SOURCE: My amana gas range just
One possibility is that the circuit breaker has weakened and tripping intermentently for no real reason. To see if that is the case the oven could be plugged into a outlet on a different breaker using a extension cord.
Another potential cause is that any one of the wires in the range has became bare and lost its insulation and touching a peice of metal, shorting out
Good luck in figuring out what is wrong,
Gene
Posted on Aug 06, 2011
Why has our oven stopped working whilst cooking - nothing electrical seems to be working?
Did you check your electrical breakers? Maybe it tripped. Reset it by first switching it fully to the off position, then switch it to on.
Feb 29, 2016 | Ovens
NATURAL GAS OVEN WONT COOK PROPERLY
· Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
· Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Apr 06, 2014 | Frigidaire Ovens
Propane oven won't light
Can you post more details like: Does the oven ignitor come on (glow orange)? Can you hear the oven gas valve click open and/or smell gas? Do all the stovetop burners work fine? Have you checked your propane tank to be sure you are not out of gas?
Mar 13, 2014 | Amana AGR4433XD 30" Freestanding Gas Range...
THE STOVETOP BURNERS WILL NOT WORK ON THE CLEAN CYCLE?
The clean cycle requires both heating elements to run at the same time.
Since your oven is a 220volt, each heating element will require their own 110v source to heat the oven. This means that the stovetop elements will need to be disabled to prevent the breaker from tripping since the cleaning cycle requires a lot of electricity to do it's job.
There is not enough wattage left over to both clean and cook, this is why cleaning is recommend during a time in which you will not be using your oven.
Nov 07, 2010 | Jenn-Air JES9860 Electric Kitchen Range
I have an Amana AGR5715QDS and when I turn it on and set it for any temperature, lets say 350 degrees, it does not turn on or heat up. The stove top burners still work fine and the door appears to be OK,...
Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Feb 05, 2010 | Amana Ovens
Oven won't light.
Make sure your oven timer is not set for automatic cooking
Dec 06, 2009 | GE Ovens
Amana Gas Stove M/N ARG 7302WW set temp. is higher than desired t
the oven safty valve is goin bad. that the part that most oven burners sits on.
Dec 09, 2008 | Amana ARGS7650SS Gas Kitchen Range
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Amana ACS3350 Gas Kitchen Range Logo
57 people viewed this question
Top Amana Kitchen Ranges Experts
Sal De
Ismael Rodriguez...
Oloyede Monsuru
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
