Question about Whirlpool Ovens
How do you use the timer on whirlpool akz496 - Whirlpool Ovens
What is wrong with my Whirlpool Double Wall Oven-Mod RBD305PDB8? Control Panel is blank. Light & timer works. Nothing else. Breaker ok.
This is a symptom of a common control board failure. Although your board has been discontinued by Whirlpool, your original EOC electronic oven control can be rebuilt. See here for details:
http://www.fixyourboard.com/boards/8302319.html
or here:
http://www.fixyourboard.com/boards/4451991.html
Sep 01, 2015 | Whirlpool Ovens
I have a whirlpool oven which I bought from Ikea a few years ago but at the end of a timed programme the beeper is not going off can you tell me the answer please.
Timer
To Turn Tones Off/On: Press and hold TIMER SET until a tone
sounds. The display will show "TIMER" and "NA9 On" or
"TIMER" and "NA9 OFF." To remove from the display, press
UPPER OFF, LOWER OFF or OFF/CANCEL. Repeat to turn
back on.
Feb 26, 2015 | Whirlpool RBS305PDS Electric Single Oven
Whirlpool loc
From a google search the following is copied:
LOC is a control panel lock not a door lock, see below.
The Control Lock shuts down the control panel pads to prevent
unintended use of the ovens.
When the control is locked, only the CLOCK, TIMER SET and
TIMER OFF pads will function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Before locking, make sure the ovens,
Timer and Timed Cooking are off. Press and hold START/ENTER
until a single tone sounds and "Loc," a picture of a lock and
"START?" will appear on the oven display, about 5 seconds.
Repeat to unlock and remove "Loc" from display.
If the above does not work have you tried removing power from the uit for a few minutes to see if it will reset.
________________
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/499415-whirlpool-double-oven-shows-loc-display.html
Jan 26, 2018 | Ovens
Coil won't turn off
Have it checked by a properly qualified and licensed technician. You can't see electricity and it is a killer.
Nov 10, 2013 | Whirlpool Ovens
Oven won't work - its a timer problem how do I reset the timer?
I believe the control's child lock function is enabled. To disable it, press and hold the cancel key (will have small padlock icon under the word "cancel"). That should clear the condition.
Dec 24, 2008 | Whirlpool RBS305PDS Electric Single Oven
Oven will not work on my whirlpool rde350pw1
Sounding like the element is bad for the oven. Can you ohm it out? If that checks okay then it is diffidently the knob to turn on the oven. The switch is bad and needs to be replaced.
Nov 22, 2008 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool Oven/Convection Oven Timer Problem
replace the control cpu unit the main control board is deffective
Apr 11, 2008 | Whirlpool RBS305PD Electric Single Oven
Whirlpool super capacity 465 timer won't beep
clock timer and motot for a black electric oven 220Volt. oven number on plate at bottom of door is these two RGE 1600 P 5.8 and MK 93877451 4.4
rge
Jan 12, 2008 | Whirlpool GBS307PR Electric Single Oven
Ovens Logo
15 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
