Question about Vehicle Parts & Accessories
I have a voltage drop on the ring circuit and my tester telling me its an earth fualt
    Champion:
  • 473 Answers
Sounds like something is shorting out then. Look for bare wires shorting, faulty components possibly a bad regulator.
Posted on Oct 21, 2013
I have a 2007 madza3 2.0 battery is good but when you turn the key it just clicks
Clicking sound is the solenoid activated starting switch pulling in, then dropping out because of low voltage when the starter motor is connected electrically. When the contact drops out, the load on battery is reduced, voltage rises again enough to pull the solenoid switch back in and click. This happens four or five times a second and thus hear the "clicking" sound.
Only a load tester will indicate if battery is weak. Simple voltage testers only show open circuit voltage.
Load testers usually apply a 50 Amp load for 30 seconds. That 30 second voltage must then be compared to the battery's CCA rating, which gives you an true indication of battery's condition.
I suspect a load test will show the present battery to be weak or bad. If battery is five or more years old, it owes you nothing.
Best deals on new batteries is WalMart with free installation.
Sep 22, 2017 | Cars & Trucks
Yamaha ybr125g
check the voltage as you remove or disconnect one circuit at a time, including all the lights and grounds on the bike, one at a time and see which one drops the voltage, find the circuit that is draining the battery
Dec 18, 2017 | Motorcycles
2009 murano will not start, just clicking sound
If it is a rapid click test battery with a load tester (carbon pile type the best) it may be charged but have no capacity. If there is a single click from the starter when try start test voltage at starter solenoid activation lead you may have voltage drop (if below 9v you can fit an inline 30 amp relay to boost the circuit. Also check body earth to engine. If none of these work please advise with additional information.
Feb 25, 2013 | 2009 Nissan Murano
Hello there would you be able to tell me wiring colours and what the do etc hi low and earth for headlights for kp61 starlet thanks
It seems, you had disconnect the cables and bulb fitting.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You can fix the problem this way (use a multi tester / AVO meter) :
1. While car in off, check resistance of each wire to body. The one that has 0 ( lowest) resistance is earth (ground)
2. Start the car, turn on hi beam, measure the voltage of the rest of wires to the earth. The one has DC voltage ( 12-13 VDC) is Hi beam positive ( +) cable.
3. The rest is Low beam positive cable
Aug 10, 2010 | 1983 Toyota Starlet
Car seems to be charging ok but some thing
Check for consumers staying on such as interior lights , radio etc.. To check for current draw, you need an AMP meter. remove the negative battery terminal. Connect one amp meter lead to the battery negative terminal and the other to the earth cable. Hold the cable against the battery negative cable, close all doors and press bonnet switch to closed position. Activate the alarm and wait for it to arm. Once it has armed itself, separate the earth cable from the battery terminal keeping the amp meter connected. read the current draw. Should be less then 100 milli amps. Usually +- 40ma. To check which circuit has current draw remove one fuse at a time and check if current draw drops. A drop in current draw will indicate that the problem is on that fuses circuit. Also check alternator charge rate. To check this hold a volt meter across the battery terminals. with engine off, should get battery voltage. Start the vehicle, battery voltage should rise to 13 -14v and maintain this voltage with the headlights on. The battery itself could be faulty, you would need to do a load test on the battery. Load tester needed to do this.
Apr 24, 2010 | 1996 Audi A6
Monitor problem.
um.. im just gona say this it seems obvious but on mine one of the leads connecting the sub to the rest of the cabinet fell off and all i had to do was reconnect it and it was fine.
Aug 11, 2009 | Yamaha NS-A636 Speaker
Why must voltmeter be connected in parallel w/ circuit component
When connected in parallel it reads the voltage drop across said component.
When connected in series the current flows thru the meter allowing the measurement of the current flowing thru circuit.
Hope that helps.
Jan 04, 2009 | Mbt ZTS Inc. Mini-MBT, Mini Multi-Battery...
Ipod won't turn on
U HAVE DROPPED IT NOW MAY BE ITS BATTERY IS DEAD OR I WUD SUGGEST U 2 CHECK THE CIRCUIT CONNECTION AND THEN TRY 2 RESTART IT
Dec 09, 2008 | Apple iPod nano
Heater element
Hello Paul, I am not sure what a circuit tester is showing you. I use a volt meter to check the incoming voltage to the element. If the voltage is within factory specs, then I use my Amp meter to check if the element is pulling any amperage. The fact that you fill the washer with hot water then it works tells me that the unit isn't heating. If you don't have a volt meter to measure the voltage, then see if you have a friend to borrow one from. Hope this helps.
Jan 30, 2008 | Washing Machines
Vehicle Parts & Accessories Logo
60 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
