Question about Epson Stylus Photo R320 InkJet Printer
Ink out problem.
I have my black ink cartridge full while the others are empty. When I go to print my black and white only paper, I get an error saying I have to replace the color cartridges. So far I have found no way to print off my papers on my black ink solely. If there are any ideas, it would be greatly appreciated. PS: The ink/paper service light is lit on the Epson with a Error Ink Out screen on boot as well.
  • 59 Answers
Http://www.ssclg.com/epsone.shtml go there first and download that. Next, either buy new cartridges, or go to your local cartridge world and buy refills. Now using the program I posted the link for, configure it, do a soft reset, and then freeze your ink levels. Please email me @ [email protected] and I'll go more into how to do it.
Posted on Oct 02, 2007
3 Suggested Answers
SOURCE:
SOURCE: Epson aculaser c1100 cant access empty ink cartridge.
go to the reset menu (right arrow and then down arrow until reset menu is displayed) on the lcd display and then choose change toner #(right arrow until the desired toner is displayed) Hope this helps
Posted on Oct 04, 2007
Soulvisitor
  • 1113 Answers
SOURCE: Epson R1800 Low Ink Lights
replace ink with new gen carts. Your carts are may be dried up or blocked
Posted on Oct 18, 2007
Can I change to 95 tricolor for a black ink cartridge,,,,we never do any color printing
It won't recognise the black cartridge in the printer and may even throw an error code. Use the black and white option setting for printing.
Sep 15, 2018 | Black Office Equipment & Supplies
Error E and 5
Number following "E"
Cause
How to correct
No paper. /
Paper does not feed.
If paper is not installed, load it and then press the <Black> or <Color> button. When paper is installed, check each of the following items and try printing again.
1. Confirm only recommended paper is installed.
2. Confirm paper is installed properly.
3. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
4. Clean the paper feed roller to resolve the error.
Paper jam
Remove the jammed paper.
If paper jams frequently occur, check the following:
1. Confirm there is no foreign material inside the machine.
2. Confirm only recommended paper is installed.
3. Confirm paper is installed properly.
4. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
Empty ink tank
An ink cartridge is empty.
To cancel printing, press the <Stop/Reset> button.
To continue printing, press <Black> or <Color> button.
After printing completes, replace the empty ink cartridge.
Printing with an empty ink cartridge may cause the machine to malfunction.
5
The ink cartridge(s) is not installed. / The ink cartridge(s) cannot be recognized.
The ink cartridge may not be installed properly, or an unsupported ink cartridge may be installed.
Install a recommended ink cartridge.
Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing.
If one of the ink cartridges is missing, this error can occur.
7
The ink cartridge is not installed in the appropriate position.
The ink cartridge is not installed in the proper position.
Install each ink cartridge in the proper position.
8
The waste ink absorber is almost full.
The waste ink absorber is getting full.
Press the <Black> or <Color> button to clear the error and continue printing.
Printing can continue until the waste ink absorber becomes full. If the waste ink absorber becomes full, the machine will require service.
The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations.
9
A specified period of time has elapsed without receiving a response from the digital camera. / A print mode compliant with PictBridge is not selected. / A specified period of time has elapsed without receiving a response from the digital camera.
The machine cannot communicate with the connected camera.
Disconnect the cable between the machine and the camera to clear the error.
Check the following items, then try printing again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct.
If the camera does not support either one, the machine cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge.
Please refer to the camera instructions for more information about procedures required before and after connection to the machine.
3. There may have been no response from the camera for the prescribed time.
Re-connect the cable between the camera and the machine.
1 , 4
1 , 5
The ink cartridge cannot be recognized.
An unsupported ink cartridge may be installed.
Install only recommended ink cartridges.
1, 6
The ink level cannot be correctly detected.
A used ink cartridge may be installed, or the ink cartridge is empty.
Replace the ink cartridge.
Press the <Black> or <Color> button, to clear the error and continue printing without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate.
1 , 9
Scanning failed.
Scanning a document failed.
Check if the document is placed in the correct orientation / position and try the operation again.
2 , x
3 , x
4 , x
(Where x represents a number)
Turn the machine off, and remove the power cord from the electrical outlet.
Wait approximately ten minutes then plug in the power cord and turn the machine on.
If the problem is not resolved, the machine may require service.
Feb 18, 2012 | Canon PIXMA MP150 All-In-One InkJet...
Printer not working. The light flashes red six times.
Error Condition Indicator Beeps Error
Code Possible Solution Paper Feed / Delivery Orange 2 Remove any paper jammed Paper Jam Orange 3 Remove any paper jammed Ink Out Orange 4 Add Ink BJ Cartridge Misinstalled Orange 5 Re-install cartridge or replace it NO BJ Cartridge Orange 6 Re-install cartridge or replace it BJ Cartridge Error Orange 7 Re-install cartridge or replace it Waste Full warning Orange 8 Waste is almost full , needs service very soon Service Errors Blinks Beeps Error
Code
Possible Solution ROM Error 1 x Orange 10 6100 Try unplugging Printer RAM Error 2 x Orange 10 6300 Try unplugging Printer EEPROM 3 x Orange 10 6800 Try unplugging Printer Home Position 4 x Orange 10 5100 Temperature Sensor 5 x Orange 10 5400 Try unplugging Printer Waste Full 6 x Orange 10 5B00 Needs Service Cartridge OverHeat 7 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge OverHeat 8 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge Displaced 9 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 10 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 11 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Other Hardware error 12 x Orange 10 6500 Other Hardware error None None 5910 Needs Service Other Hardware error None None 5C00 Needs Service
Oct 01, 2009 | Canon S400 InkJet Printer
Error Message U053
Error messages displayed on the LCD and how to handle them
When an error has occurred in the printer, the error / check message is displayed on the LCD.
Take the appropriate action to return to the normal condition.
Error / Check message How to correct CHECK INK
U041 An ink cartridge is empty.
To cancel printing, press the Stop/Reset button.
To continue printing, press the OK button.
After the printing finishes, replace the empty ink cartridge.
Printing with an empty ink cartridge may cause printer malfunction. U051 / U052
U053 / U059 The ink cartridge may not be set properly, or an ink cartridge not supported by the printer is installed.
Install the proper ink cartridge.
Make sure to install both the ink cartridges even when you set the printer to use only one ink cartridge (Color or Photo) in printing.
If one of the ink cartridges is missing, this error will occur. U075 / U076 The ink cartridges are not installed in the proper position.
Install each ink cartridge in the proper position. U140 An ink cartridge not supported by the printer is installed.
Install the proper ink cartridge. U161 / U162 A used ink cartridge may be installed, or the ink cartridge may be empty.
By pressing the OK button, printing can be done without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate. READ/WRITE MODE Since the memory card is currently write-enabled, printing is not possible.
Set READ-ONLY MODE ON. NO PHOTOS ON CARD Some images in the memory card may not be in a supported format. images listed below cannot be printed directly from a memory card. Print them from a computer.
- images edited on the computer
- images in a format other than JPEG or TIFF
- images with double-byte characters used in the file name
- images saved in a folder nested 4 or more layers deep INCOMPATIBLE CAMERA The printer cannot communicate with the connected camera.
Disconnect the cable between the printer and the camera to clear the error.
Confirm the following items and print again.
If the camera does not support either one, the printer cannot print directly from the camera.
Please refer to the camera instructions for more information about procedures required before and after connection to the printer.
Re-connect the cable between the camera and the printer. WASTE INK NEAR FULL The waste ink absorber is getting full.
Press the OK button to clear the error.
Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and printer maintenance.
The waste ink absorber is a part inside the printer, which absorbs ink used in the cleaning operations, etc. CHECK PRINTER Turn the printer off, and remove the power plug from the outlet.
About ten minutes later, plug it in again, and turn the printer on.
If the problem is not resolved, the printer may require servicing. Please contact your local Service Center. HEAD ALIGNMENT ERROR Automatic print head alignment failed.
Press the OK button to release the error.
Check the followings and do automatic print head alignment again.
- Check if A4/Letter-sized paper is loaded in the auto sheet feeder.
- Check if the paper output slot is not exposed to a strong light source
- Print the nozzle check pattern to check the status of the print head.
If the problem continues, do manual print head alignment. LOAD PAPER If paper is not set, set paper and press the OK button. When paper is set, check each item and do printing again.
1. Confirm that unusable paper is not set.
2. Confirm that paper is set properly.
3. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
4. Cleaning the paper feed roller may resolve the error.
If the problem persists, the printer may require servicing. Please contact your local Service Center. PAPER JAMMED Remove the jammed paper.
If paper jam frequently occurs, check the following:
1. Confirm that no foreign material is inside the printer.
2. Confirm that unusable paper is not set.
3. Confirm that paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
Sep 15, 2009 | Canon PIXMA MX310 All-In-One Printer
Changed out black ink screen says insert
It will be a hardware printing problem mostly. Try cleaning the parts with alcogol or/and elastic rubber. Also try to increase the force of contact with a sticky tape or like that.
Aug 09, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Won't print with only 1 cartridge empty
sorry you can print unless all your cartridge are having some ink
Dec 17, 2008 | Epson Stylus Color 740 InkJet Printer
Blinking "E" and "5"
Hi barneyfan -
You're absolutely right - E5 means that the ink is empty (or that the ink can't be loaded for some other reason, such as an incompatible cartridge or improper installation)
For your reference, here is the complete list of error codes for the MP150 with brief descriptions:
E2 No paper (ASF)
E3 Paper jam
E4 No ink
E5 The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera-Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
I hope this helps - please let me know if I can be of any further assistance.
Kind regards,
H2H
Dec 13, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Installed new black and color cartridge.
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
Are they Canon ink cartridges?
Remove the cartridges, make sure that the tape is removed , and re-install them. Make sure they are seated correctly.
For future reference , these are the error codes for your printer.
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Mp140 e2
E3 – Paper jam error.
How to correct, fix: Remove the jammed paper. If paper jams frequently occur, check the following:
E4 – Empty ink tank.
How to correct, fix: An ink cartridge is empty. To cancel printing, press the <Stop/Reset> button. To continue printing, press <Black> or <Color> button. After printing completes, replace the empty ink cartridge. Printing with an empty ink cartridge may cause the machine to malfunction.
E5 – The ink cartridge(s) is not installed. The ink cartridge(s) cannot be recognized.
How to correct, fix: Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing. If one of the ink cartridges is missing, this error can occur.
E7 – The ink cartridge is not installed in the appropriate position.
How to correct, fix: The ink cartridge is not installed in the proper position. Install each ink cartridge in the proper position.
E8 – The ink wasteabsorber is almost full.
How to correct, fix: The waste ink absorber is getting full. Press the <Black> or <Color> button to clear the error and continue printing. Printing can continue until the waste ink absorber becomes full. If the waste ink absorber becomes full, the machine will require service. The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations.
E9 – A specified period of time has elapsed without receiving a response from the digital camera. A print mode compliant with PictBridge is not selected. A specified period of time has elapsed without receiving a response from the digital camera.
How to correct, fix: The machine cannot communicate with the connected camera. Disconnect the cable between the machine and the camera to clear the error. Check the following items, then try printing again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct. If the camera does not support either one, the machine cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge. Please refer to the camera instructions for more information about procedures required before and after connection to the machine.
3. There may have been no response from the camera for the prescribed time. Re-connect the cable between the camera and the machine.
E14 – Ink cartridge cannot be recognized.
How to correct, fix: Unsupported ink cartridge may be installed.
E15 – Install only recommended ink cartridges.
How to correct, fix: Install only recommended ink cartridges.
E16 – The ink level cannot be correctly recognized or detected.
How to correct, fix: A used ink cartridge may be installed, or the ink cartridge is empty. Press the <Black> or <Color> button, to clear the error and continue printing without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate.
E19 – Scanning failed error.
How to correct, fix: Scanning a document failed. Check if the document is placed in the correct orientation position and try the operation again.
Aug 01, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
Canon pixima mp140 error code E4
following error codes i found
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
Apr 24, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
Epson Stylus Photo R320 InkJet Printer Logo
2,822 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
