Question about JVC TH-M505 System
Where is vfp button on a jvc remote - JVC TH-M505 System
The ok button has stopped working on my JVC smart telly remote control
Open remote and clean contacts on that button with alcohol. Or put small piece of aluminum foil under the rubber button after wrapping it around that button. Often works fine.
Sep 07, 2017 | JVC Televison & Video
I need a new remote
Several sources of replacement OEM remotes are on the internet.
Jun 15, 2016 | JVC XL-SV22 CD Player
Printer Command using VFP
Greetings
Install Bartender software,seagul printer driver.
Design your label.
Print the label to file.
Use the file to embed in vfp (increment the variable i.e. the one printing 18...)
Buzz me at 9344104232, mmi.mdu@gmail.com
M. Murali
Feb 10, 2015 | Argox Office Equipment & Supplies
How to set clock for jvc-pc-xc50
I have a JVC pc-xc30. Essentially the same device - I believe the owners manuals are the same as well. I am in the process of hunting one of those down.
To answer your question - I have found no way to set the clock with the buttons on the JVC PC-XC50/XC30 Portable CD System. This was done using the remote control. If you search for a RM-RXC30 (for my model) you can still find replacement remotes. On the remote there is a button for clock set and timer set along with down and up buttons.
Aug 25, 2013 | JVC PC-XC350 Radio/Cassette/CD Boombox
Hi, how do I turn on the system without the remote (i dropped the remote in a blender by accident)
Go to the unit and press the Standby (Icon has the Power symbol) button to the left of the JVC logo. Use the Source button to switch from one source to another (the button is above and to the right of the JVC logo).
The manual for the JVC TH-A85 is available from JVC. The direct link is http://www.jvc.co.uk/files/instruction_manual/lvt1025-003a.pdf . See page 19 (22 of the pdf) for the details. See page 5 (8 of the pdf) for the layout of the controls on the center unit.
Unfortunately the original remote is no longer available. There may be universal remotes that will control the system. (The ones that can be programmed by a USB connection to a computer will be the easiest to program.)
I hope this helps.
Sep 17, 2011 | JVC TH-A85 System
Remote Codes for Commtel Control Freak and JVC
0053, 1253, 1923 if those don't work, I have others.
Jan 18, 2009 | JVC RM-C18G-1H Remote Control
The JVC remote control, model JVC RM-SXVS60J, has stopped working as far as the bottom buttons go even though the top buttons work fine. If you can help, please.
Since the top buttons are working fine, i doubt that the remote is faulty. Sometimes its due to moisture/dust accumilating on the remotes board and creates a barrier against the board and the buttons. You may need to open the remote and clean the surface of the mainboard.
Hope this helps
JigSaw
Aug 04, 2008 | JVC AV-56WP74 56" Rear Projection...
Black and white picture on the JVC TH-505
If you hold the VFP button while a movie is on, you will get a small box on the corner that shows your color. My default color also turned black and white. I just moved over to a user1 color setting (push the right arrow on your remote), and it allows to the change the colors. You might be able to put the colors to come out through here. Hope this helps.
Jan 28, 2007 | JVC TH-M505 System
JVC TH-M505 System Logo
21 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
