Question about Refrigerators
I have a BEKO Universal refrigerator model NCB 9750, the frezer fan is not working
s_4u_11
  • 535 Answers
SOURCE: frezer is working, but refrigerator
check the compressor of your refrigerator
Posted on Sep 03, 2008
Sea Breeze
  • 4655 Answers
SOURCE: freezer is cold fan running , refrigerator not cold no fan
If it is the pss26msrss or close I can tell you that it is most likely the defrost heater and defrost thernostat that needs changed, Would you like me to show you how to do the test. First tell me if a layer of frost is building on the rear wall of freezer. If yes unplug and remove rear panel until we see the defrost heater at the bottom of the evaporator coil. let me know, Sea Breeze
Posted on Apr 10, 2010
blueextc3221
  • 15935 Answers
SOURCE: I have a kenmore elite model 59676523500
It appears your damper solenoid has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: I have kitchenaid refrigerator , model #
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Nov 27, 2010
pjhislay1
  • 822 Answers
SOURCE: Frezer and refrigerator dont work, but the fan is
needs regassing...............not a diy job.........
cheers
Posted on Apr 02, 2011
BEKO COOL54FS. FAN IN FREEZER STOP START. been working fine for 5years all of a sudden the fan in freezer not working correctly keeps switching on off on off
Fan motor has been in constant motion for 43,800 hours. At some point the fan motor can fail and needs to be replaced.
Feb 09, 2018 | Beko Refrigerators
Daewoo refrigerator
Usually means the fan between the 2 sections is not torning or obstruted
Jul 14, 2014 | Refrigerators
There is frost buildup on back wall of frezer fridge or frezer dont get cold enough
my fan blade had slipped down and was rubbing makeing a noise and fine particles of white dust was at the rub point. Pushed the fan back up drop of super glue and lubricated the motor. works great!
Jul 27, 2010 | Hotpoint (HSM25IFTSA) Side by Side...
Fridg is not cooling.frezer working real good.
Open the freezer compartment and listen for the fan motor if you don't hear it but you can hear the compressor running. youll need to first make sure that the door switch is working( If the lights go off when you press the button it should be okay). You'll need to remove the back panel and inspect the coils if frosted over evenly and the fan still is not working give the fan a little push. if it will not go, you need to see if it has voltage if so, replace the fan. If no check the defrost terminator which only on amanas will keep the fan off. In this case replace the defrost terminator(it look about like 5 quarters, with 2 wires clipped through the evaprator coils in back of freezer.
Jul 15, 2010 | Amana ABB1927DE Bottom Freezer...
The freezer works but the refigerator section does not. When you turn the temp switch for the refrigerator it will turn off the freezer also.
dont tuch the thermostat put it in normal setting!
now, check if your fan in the frezer working, if it is working che3ck the thermostat unit and heater in the frezer unit also need to see if the frosting is eaven all over in the frezer side..
contact me at www.911servicetoday.com
Dec 30, 2009 | Refrigerators
The fridge is not working and the frezer has a low temperature
be carefull when you remove the panel inside the frezer it may be you have a build up of ice and the panel could get frozen to the ice, best idea is to turn off the fridge/frezer for 24hrs to let it thaw
Oct 15, 2009 | Hotpoint FFA60 Bottom Freezer Refrigerator
Compressor not working warm fan inside frezer run
Heat exchanger was iced over, took a hair dryer and melted ice. I think defrost heater element is bad will check it this week end. I put a new computer in the frige about 3 mounths ago and will check if it has gone bad. The compressor is working fine.
Jun 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frezer temp is 20 deg. fridge temp is 47 deg.
Remove the freezer shelves and bins. Remove the freezer back panel to access the fan motor.
May 26, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Beko fridge freezer humming
- Loose flooring or floor not firm.
- Cabinet not level.
- Tubing in contact with cabinet, other tubing or other metal.
- Drip tray vibrating.
- Fan hitting another part or worn fan motor bearings. Unplug the unit and rotate fan manually by your finger.
- Compressor mounting grommets worn or missing; mounting hardware loose or missing.
- Free or loose parts causing or allowing noise during operation
- Check compressor it may contact with tubing or other parts.
- Check the body of your unit is not touching the wall or other object.
Jan 12, 2008 | Haier (492420265334) Refrigerator With Ice...
Refrigerators Logo
78 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
