Question about Honda Pressure Washer PSI 3000
Honda power washer parts diagram
I want to check where to put the gear oil
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Honda Master
  • 1,727 Answers
What gear oil ??? it should be a non detergent motor oil but this all depends on the brand of pump that you forgot to mention
Posted on Oct 20, 2013
99 Roadstar Dies when i put it in gear just changed the oil i have went fine, but know matter what ive checked keeps dieing
Are you sure you put the oil in the engine and not the transmission, check both the engine and trans dip sticks to make sure they are at the correct level.
Mar 17, 2015 | Cars & Trucks
Dies when put in gear and knocking noise from engine
Knocking noise usually indicated low oil, dying with knocking when put in gear usually means NO oil. Check oil level and fill it. If that works you need to check the oil level every day to see if it is leaking and how fast it is leaking.
Jul 31, 2014 | Cars & Trucks
How to put gear oil in..
The only place to put gear oil is in the "pumpkin". Otherwise called the rear-end.
To do so, I recommend driving the car backwards onto two ramps to raise the rear end up in the air, this also tilts the car forward.
Between the rear wheels, in the center of the axle, is a large metal container of gears and gear oil.
There should be a large hex-headed bolt less than half-way from the bottom to the top on the rear, facing your back bumper.
This is where the gear oil goes in, but after you take the bolt out, before you add any oil, stick your finger into the hole and try to feel the oil level.
If you can feel it, you don't need any more gear oil to be added.
Jan 21, 2013 | 1998 Ford Expedition
What oil do i put in a kawasaki kmx 125?
hi my kmx 125 runs starts fine but when i put it in gear it cuts off help
Nov 08, 2012 | 2002 kawasaki KMX 125
My renault scenic i hard to change gear
possible clutch cable or cluth itself, check the clutch cable first to see if its stretched, i didnt check and put a new clutch in ,and wasted £250 , try euro car parts for cheapest clutch cable.
May 17, 2010 | Cars & Trucks
Gear oil instantly came out , put new gear oil there was no problem to drive , kindly tell me why it happened
is it the gear oils from the bottom or hood? either way, check for leakages or probably the cap for the gear oil wasn't properly set. which is why it spilled for the 1st tym but the 2nd after changing it, you tightened it of course causing it to do well.
Jul 08, 2009 | 1996 Ford Explorer
Where is opening on for oil on the gearbox. lost lot of oil and now needs more
hi the oil filler is on the side remove the plug fill gear box till the oil runs just runs out of the hole put plug in
Apr 24, 2009 | Volkswagen New Beetle Cars & Trucks
OIL PUMP PROBLEMS
the oil pump is not electronic it is gear drivin . either the gear is bad or the installation was done incorrect. my advice is to start over and sure the rod is seated correctly . you should be able to put the rod in and not be able to spin it. if it spins that means either the gear is completely bad or the rod needs replacing or both. in order to replace the gear you have to remove the timing chain. in your vehicle if you have a distributor and not coil packs you have to remove the distributor and look at the bott of the shaft to see if it is worn out. hope this helps........please rate this.
Aug 31, 2008 | 1999 Ford Taurus
Honda Pressure Washer PSI 3000 Logo
99 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
