Question about Mitsubishi WT-46809 46" Rear Projection Television
Possible convergance/bowtie problem.
Center 1/3 of picture is fine,left and right 1/3's of picture get a rainbow seperation effect.comes and goes intermittently but getting worse.Is this the convergence ic problem or something else?thanks for your help in advance.
  • max13 Sep 27, 2007
    This is for a wt-46809 tv.
  • 790 Answers
Yes you have defective convergence circuit!
Posted on Sep 27, 2007
The top and bottom of the picture makes a rainbow effect toward each other in the center of the screen++++++++TV. model 3 ws55807 it's a 55 inch screen the problem occurs all the time. I have no TV repair...
This tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than this tv have a dead convergence board.The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.Fix the tv convergence board to solved the tv convergence pictures problems.The shop,will cost u like $300-350 for parts and labors.
Feb 08, 2011 | Mitsubishi WS-65807 65" Rear Projection...
My Zenith tv picture on the screen looks like a bowtie red green and blue are seperated on screen
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 24, 2010 | RCA D52W23 52" HDTV CRT TV
RCA HD52W69D with a slight convergence & bowtie problem
Ur convergence it dead.If can't auto adjust must replaced.Tries Tv repair World.com,Tv repair kits.
Nov 04, 2009 | RCA HD52W59 HDTV Projection Television
Red and Blue seperate and picture curved toward the middle
You have a hardware problem, you cannot fix it using the menu. in fact you could make it worse.
Try googling DIY convergence repair if you can solder.
If not then call in a pro, about $300
Jul 12, 2009 | Toshiba 50H81 50" Rear Projection...
I replaced the convergence board and ICs, but picture stil bowtie
Did you go into the convergence menu and allign the colors? Here's the link where i fixed mine... it's got the remote control button layout to adjust everything.
Jun 23, 2009 | Akai PT5598HD 55" Rear Projection...
Tohsiba 61HD70 Rear Projection
Yes, its a convergence problem and you may be able to fix this yourself if you have a soldering station and a few basic tools. Its possible that all that is necessary is to re-solder the pin connections on the convergence output ICs on the underside of the cicuit board. There may also be a poor solder connection on a jumper wire connection near the ICs. Its near the plastic frame. If this does not resolve the issue, you will need to replace the ICs. Remember to unplug the TV before doing any service.
Feb 15, 2009 | Toshiba 61H70 61" Rear Projection...
Blue line trouble
Hi Kracka,
Are you able to post a picture of the problem?
It sounds from your description that it might be a 'convergence' problem which is when the red, green and blue parts of the image aren't alligned properly.
Check in your menu to see if there is a convergence setting.
Hope this helps
Andy
Jun 26, 2008 | Panasonic PT-51G41 51 in. Rear Projection...
Bent picture
The convergence circuits straighten out the edges of the picture, putting the 3 colors exactly where they should be for the picture to look normal. There are usually 2 large IC's that handle the 6 convergence channels and if one of them burns out then one of the colors bends dramatically. If the power supply for the convergence circuits stops working, then all 3 colors bend in, the colors do not line up with each other and the image looks almost 3D, and the adjustments in the convergence menu will have no effect. I would bet that is the case with your set - the convergence power supply has quit working. If you do not have experience troubleshooting power supplies and realigning convergence circuits in projection TV's then allow a qualified tech to handle it for you.
Aug 07, 2007 | Philips 51PP9910 51" Rear Projection HDTV
Concave picture with rainbow effect at the edges
Hello, Check and replace IC1606 (P/N: 875292571) and IC1608 (P/N: 875982987). Best regards, Arpi http://www.partstore.com/sl/2/418644-ic-cxp86448635q-875292571.html
Apr 23, 2007 | Sony KP-57HW40 57" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
79 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
