Question about Coffee Makers & Espresso Machines
Work mode switch lever stucks. - Coffee Makers & Espresso Machines
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Lubricate it .
Posted on Nov 02, 2013
I own a 2002 Hyundai Santa Fe and my transmission is stuck in manual mode it won't go past number one I can't get it back over into automatic mode and I want to know what might be the problem
The big question here is how did it work before it got stuck the transmission I mean .
Did it shift OK before it got stuck if no you have a big problem with your trany .
If it worked good then look at the key switch it locks the shift lever so you can't shift it with your foot on the brake or any linkages connecting to this system its all on the steering collum or a linkage to the transmission
Aug 20, 2016 | 2002 Hyundai Santa Fe
Not sure of the model number but my paper shredder was purchased on Jan 16 of this year and quit working the middle of July except for the reverse mode. I need help.
no
we don't sell anything
there is something stuck in the blades
in the middle of the cutters there is a small plastic lever that is the micro switch for the forward action . paper is stuck and that lever is now not operating the microswitch to drive the cutter motor
either that or the lever has broken off, again not activating the micro switch
If you want repairs or warranty , contact the manufacturer direct by phone
Aug 17, 2016 | Omnitech 12 Sheet Cross Cut Shredder
How to reset brake warning light on 01 volks beetle
Brake warning? U mean parking brake light? Push the parking lever all the way down to disengage the switch if that doesnt work then pull the cover for the brake handle the switch is just below the lever u might have something stuck to it or ur have a faulty switch
Feb 14, 2015 | 2001 Volkswagen Beetle
Self timer stuck
hello
Have you tried turning the drive mode lever from self timer mode to single shot mode? If not, surrounding the mode dial are a couple of levers: one being the on and off lever and the other being the drive mode lever. if you move the drive mode lever up to the first option (illustrated by a single box, meaning single shot), you'll be able to turn the self timer off.
If that doesn't work, then it might be a system bug/error. In that case, download the latest firmware here and upgrade your camera.
Hope this helps!
May 11, 2012 | Panasonic Lumix DMC-G1K Digital Camera...
How do you replace the neutral safety switch
Mode switch is on the LH side of the transmission.
Unclip the mode switch cover.
Disconnect the nut that holds the selector lever to the mode switch and pull the lever away.
Disconnect the harness from the mode switch connector then unbolt the connector and its bracket from the transmission and unbolt the mode switch itself from the transmission.
Replacement is the reverse of removal.
Do the following to align:
Loosen the switch hold down bolts. Turn the switch until the slot in the switch lines up with the bushing and insert a drill bit into the slot. Retorque the switch to transmission bolts.
Torque settings: Mode switch bolt 13 N.m., selector lever bolt 23 N.m.
Sep 11, 2010 | 1998 Isuzu Trooper
When I start engine and depress brake pedal and go to move shift lever I can't depress shift lever button to move out of park. This will happen 6 times out 10.
2002 chevy trailblazer on neutral mode, trailblazer can be pushed easily,but shifter is stuck on park. vehicle will start.the push button on shifter will not engage
Sep 09, 2010 | 2002 Chevrolet TrailBlazer
Console Shift lever stuck in park
check to see if your brake lights work if they dont ,you need a brake switch ,this is a safety feature from ford it wont allow you to shift out of park
Apr 24, 2010 | 2002 Ford Thunderbird
Turn signal lever is stuck
it sounds like you need a new directional signal switch located behind the steering wheel and the
air bag not a 10min job but not a wallet buster
hope this helps good luck
Jan 15, 2010 | 2002 Ford Thunderbird
2008 Avenger that wont shift from park!
the locking lever that goes to your shift lever is stuck or not releasing its electronic so check for blown fuses or you might have to open up the panel under the lever and move it manually to set it free
Aug 22, 2009 | 2008 Dodge Avenger
Oven will not come on to cook, it will come on in cleaning mode
I've seen this problem on my own oven. If yours, like mine, has a door that has a locking mechanism, the catch is most likely stuck in the locked position. The door still closes and the lever still moves (though it may be very stiff).
Take off the screws around the locking plate, manually push the catch to the open position, spray the catch VERY, VERY lightly with WD-40 and dry it thoroughly. Close the oven door and try the lever again.
At this point, it should move freely and your oven should be able to switch between LOCKED/Self-Clean Mode and UNLOCKED/Cook Mode. If it does still get stuck, you'll just has to a) try lubricating the catch a bit more or b) keep a screwdriver handy! ;)
Aug 05, 2009 | Hotpoint RB757 Electric Kitchen Range
Coffee Makers & Espresso Machines Logo
41 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
