Question about Garmin GPS 12 GPS Receiver
12 gps transformation - Garmin GPS 12 GPS Receiver
12 volt cigarette lighter socket
the lighter socket will be straight 12 volts and the GPS may require less (5.5 volts) and the different size is to prevent the over voltage and damaging the GPS unit. There may be an adaptor that will do the job and it may have a built- in transformer for the purpose.
Jan 01, 2014 | 2001 Kia Sportage
12 volt lights not running on shore power ,just running off battery. but 120 outlets working fine.
check the fuse for the 12 volt system. Check wiring for the 12 volt side of the transformer and check if you are getting 12 volt out of the transformer.
Aug 04, 2013 | Electronics - Others
Power into unit ok power comming out of unit is very dim.
If you have a volt meter, check the voltage, I believe it is supposed to be 12 volts.
Are your bulbs the proper voltage rating, that is 12 volts.
Do you have enough bulbs connected to the transformer, connected load should be close to 121 watts when you add up all your bulb wattages.
Don't confuse volts with watts. The transformer reduces voltage to 12 volts, but the wattage of the transformer is 121 watts. Each bulb must be 12 volts but wattage (brightness) can vary depending on the fixture from maybe 7 watts to over 50 watts.
Dec 01, 2010 | Intermatic Malibu 121W Power Pack...
Hi i am using gps 12, unfortunately my store waypoins all are lost, is it possible to recover them
Unfortunately the answer is no. When the Garmin 12 was being made there was no facility for recovering any deleted waypoints.
Nov 07, 2010 | Garmin GPS 12 GPS Receiver
Free manual for Garmin GPS 12
Click on the link below to view the Garmin GPS 12 owners manual
http://www8.garmin.com/manuals/GPS12_OwnersManual.pdf
Aug 18, 2010 | Garmin GPS 12 GPS Receiver
Garmin gps 12 loss of data
I had the same thing happen. The problem is that the internal lithium battery is shot. Solution: phone Garmin at 1-800-800-1020 x 2,2,1. You send the receiver in along with a $42.41 check. They will probably replace the unit. They will explain exact procedures when you call.
Hope this helps.
Joan
Jan 04, 2010 | Garmin GPS 12 GPS Receiver
Is rhe autupower cable all you need to operate the gps?
Hello, yes an external antenna is no longer needed with recent improvement to portable GPS systems.
You will need to place the GPS where it has a relatively unobstructed view of the sky.
I use a vent mount which are available for about $12. It clips into the vent louvers and positions the unit directly to the right of my steering wheel.
Please note it may take as much as 5 minutes for the GPS to obtain its initial position so be patient.
Also it may be a good idea to charge your unit, if it did not come with a 110v plug in transformer you can use a USB cable off your computer directly into the USB jack that provides power from your cigarette lighter.
Magellan often releases new firmware for their models so make sure you check their website, register your unit and download any updates that are available.
Hope that helps
Jan 03, 2010 | Magellan Maestro 3250 GPS
My Garmin GPS 12 Turns Black On turning on.
Try turning the unit on and hold the left arrow button down for about 10 seconds.
Apr 01, 2009 | Garmin GPS 12 GPS Receiver
GPS hookup on a snowmobile.
Take the insides out of an old wall-wart, those black things that hang from outlets. They take the 12 volts AC from the transformer and pass it through diodes and filter it with a capacitor. And there you have a feed wire too.
Jan 31, 2008 | GPS
Garmin GPS 12 GPS Receiver Logo
111 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
