Question about LG Microwave Ovens
Lg Magnetron 214 39F
Where can i find the Magnetron 214 39F and what is its cost
  • 40 Answers
The last time I looked someone wanted $31.00 for a used one.
Used magnetrons are not a smart buy. You have no way of telling how much it's been used. I don't know anyone who would guarantee a used magnetron, and even if it were you'd still be out the shipping charges for return.
I'm guessing around $60.00 + shipping for a new one.
GOOGLE: 214-39F magnetron and see what you come up with.
Cheers.
Posted on Oct 21, 2013
When you push start button fuse blows if i disconnect magnetron then its ok would the magnetron be faulty
every possibility that is the case
by disconnecting the magnatron you are disconnecting the circuit that is shorting out
get a quote as the cost will be more than a new unit
Apr 16, 2016 | LG 0.9 Cu. Ft. Combination Microwave /...
Can I order a new Magnetron from you?
Your aware this site is not associated with LG, rather it's a place where individuals can ask questions and get answers from others regarding specific problems.
Regarding your specific problem, if your certain it's the magnetron I'd suggest you consider buying a new microwave. The cost of repairing yours may be more than a new unit. Prices for microwaves have dropped significantly. I saw a 700 watt Conv/Microwave advertised for $50 at a local retailer (on the East coast). I doubt a 1000 watt model would be more than $75 to 100.
Nov 22, 2010 | LG LMV1630 Convection/Microwave Oven
SET TIMER FOR 20 MINUTES FOR BAKED POTATOE.. CAME BACK AND FOUND POTATOES CHARCOALED. SMOKE AND SINGED INSIDE. MICROWAVE WILL NOT COME ON. CHECKED CIRCUIT BREAKER. POWER TO UNIT.
That was a very long duration to have set for potatoes. It would have made the magnetron burnt by exeeding the limit and findinf there was no conductive medium by moisture , it has ended up burning the magnetron.
First of all clean up the inside and clean up the point of the magnetron beam.Now confirm on the inside to be totally dry.
Disconnect power and check inside for break of fuse to the magnetron.If the microwave does not heat on testing with a cup of water , then it is possible that the magnetron is cooked.
Confirm the cost for the unit to decide on replacement.
Hope this helps.
Aug 21, 2010 | LG LMV1630 Convection/Microwave Oven
TRY TO HEAT SOMETHING AND MIRO STAY FOR 5 SEC ONLY
The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts (including a fuse and the diodes), then most likely the magnetron is done and a new microwave is the way to go.
Let me know how this works out for you.
Benjamin
Aug 17, 2010 | LG LMVM1935 Convection/Microwave Oven
Powers but no heat. Everything else functions
Sounds like the magnetron has failed. This is the component that produces the microwave that heats the food. The cost of the magnetron is about 95% of the cost of a microwave . Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing. There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Jun 30, 2009 | LG LMV2053 Microwave Oven
Does not heat up any more.
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
Benjamin
Apr 19, 2009 | LG LRM1260SW Microwave Oven
LG LMVM1935SB Microwave won't heat anymore!
With these symptoms, I would suspect you have a bad magnetron.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Some manufacturers will send you the magnetron to do it yourself. If nothing else, you can save about $75 by taking it to the shop yourself.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html (continuity can be good even though it is bad!)
http://www.gallawa.com/microtech/xformer.html
To order Goldstar / L.G. parts, visit Vance Baldwin Electronics.
For more Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or
visit here. You can get warranty info & find a local authorized servicer.
L.G. / Goldstar owner's manuals can be downloaded here.
Nov 21, 2008 | Microwave Ovens
Heat up
In this case, the magnetron is the most likely suspect, but other suspects would be :
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 10, 2008 | Goldstar MV-1715 1000 Watts Microwave Oven
GoldStar MH-1357M microwave
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
Jun 17, 2008 | Goldstar MH-1355M Microwave Oven
Microwave Ovens Logo
Top LG Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
Devabhakthuni...
Devabhakthuni...
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
