Question about E-Machines eMachines Desktop PC
Every time I start my laptop there is an option Press F1 to open windows
    Master:
  • 359 Answers
Yes most machines when starting up give you the option to press F1 to enter safe mode options. Are you having an issue with this?
Posted on Oct 19, 2013
What do I press to access the bios to reset?
Re-start the computer and well before it starts loading windows press the F2 key continuously until the screen pops up. If it does not and the computer loads and opens windows you were too late hitting the key or you were not hitting the key frequently enough. In that event you need to start the process over again by re-starting the computer again.
Dec 22, 2015 | Computers & Internet
I have a compaq presario 1237, and it will not boot, when started it goes to a black screen and has f1 or f10, it also says error 0271, check date and time settings, i have went and set default settings...
Hi
please try this
press the power up key as well as the F8 key both together
then if you get into the repair options
choose the last know good configuration option
windows will then restart and try to take it back to when it was ok
if this has helped you please let us know
so that we may be able to help others
many thanks
Jul 18, 2011 | Computers & Internet
I made in bios a setup to boot fast and when i open the laptop the bios option it doesnt appear anymore , it is starting windows. how can i repare it .how can i acces the bios again?toshiba L655-S5058
1. Turn on computer by Holding down power button while pressing the ESC key.
The machine will beep, then display:
Check System, then press [F1] key.
2. Release ESC key
3. Press F1 key
May 04, 2011 | Toshiba Satellite L655S5058 Notebook PC
When i switch on my compaq presario V2000 laptop it beeps three times and then freezes giving me the option to press f1 or f10 but when i press f1 or f10 it still doesn't work and is still frozen
Hi....
Actually beep sound indicates hardware error or BIOS error.
Don't press F10 while starting.
Let your laptop to start wait for 10min....
If it will not starts..........
Press F1(BIOS Settings for some pc F2 is Bois Setting)
If it will load BIOS.......... then your BIOS is OK
Then you need to change hard disk...
If not you need to change BIOS hardware(IF you i will tell you the way restore BIOS but it's very difficult task.It needs a trained person.)
Thank you have a nice day............
Feb 06, 2011 | HP Compaq Presario V2000 Notebook
How can i start reformatting my fujitsu siemens c1020 laptop?i had a cd for manageability of the laptop but i dont know what key is going to press when i open my laptop.
How to Format a Hard Drive in Windows XP
  1. Insert the Windows installation CD into the CD drive. Make sure that there are no other disks in the computer, and restart.
  2. At the "Welcome to Setup" screen, press either the "Enter/"F2"/"F1" keys to set up Windows.
  3. Press the C key to continue setup.
  4. Press the F8 key to agree to the license.
  5. Press the C key to create a partition.
  6. Enter the size of the partition, or just press the Enter key to use maximum size.
  7. Select the "New (Unformatted)" option, and press the Enter key.
  8. Select NTFS or FAT file system (select NTFS if you are unsure).
  9. Simply follow the prompts format the hard drive in Windows XP continue the Windows installation.
Dec 29, 2010 | Fujitsu Siemens AMILO D-7830 Notebook
How use the functions key F1 to F12
Hi
In your samsung laptop you'll be able to see a Fn key on the left to windows key and space bar, press that along with the any keys from F1 to F12 and it will function normally.
eg-- Fn key + F1 key will open up windows help (as it happens in normal systems when we press F1 key)
Daniel Scott
Jun 24, 2010 | Samsung R610-64G Laptop
My Acer Aspire 1500 laptop wont pass startup.
It seems that your laptop hardware is good and it seems that it is a software issue.
  1. Boot in safe mode: When your laptop start, press the F8 key. then it will ask you which boot device to boot from, browse using the arrow keys and chose something with HDD and press ENTER and then press the F8 key again. Then you will be given a boot option and choose SAFE MODE.
  2. While in SAFE MODE, try to uninstall your newly installed software that might be causing the laptop to hung up.
  3. Also, click Start => Run then type: msconfig.
  4. Go to the Startup Tab and uncheck the many programs that looks not necessary to load while windows is loading. The program like Yahoo Messenger, Skype can be opened manually so uncheck them if present.
  5. Click Apply then OK.
  6. Restart your laptop and see if it helps.
Feb 23, 2010 | Computers & Internet
Need to set back to factory settings
There are a few ways you can do that, when you start up your pc at the top left corner it will say press f11 for recovery, it will only give you a few seconds to press it, if you press it you will be given options on how to start your recovery, or you can goto your start menu goto programs then scroll to system recovery, or you can restart your pc with the recovery disc that came with laptop to start system recovery.
Mar 30, 2009 | Gateway MT6840 Notebook
Why wont my laptop run on my lcd hdtv made by Vizio
You must redirect the video output from the laptop screen to the TV.
It usually takes a keystroke combination, depending on your laptop it is hold the FN(function) key(lower left on keyboard close to the Ctrl and Alt key) and press on of the F1-F12 keys on top of keyboard.
You can try one combination at a time until it switches. Your FN key may have a Flying Windows icon and the F1-F12 key may have a TV icon on it.
Let me know if you get it working and please rate this solution.
Lone99star
Feb 10, 2009 | Vizio L32 32 in. LCD HDTV
When i try an open system restore the window appears blank, an my laptop doesnt no what the internet is when i try an open internet explorer it asks me what program to use, all this started after i ran i...
You might want to print this out:
1) Turn off your laptop.
2) Press the "on" button on your laptop, and *immediately* start tapping on the F8 key on your keyboard. This should bring up a black screen with white text on it.
NOTE: You may get a message saying "keyboard error, press F1 to continue." If this happens, press F1 and then keep tapping on the F8 key.
NOTE: If the Windows screen comes up, turn off the computer and try again until you get to a black screen with different startup choices on it.
3) Once you have reached the startup choices screen, use the arrow keys on your keyboard to highlight "safe mode." Press the Enter key. If you are asked to choose your operating system, just press Enter again.
This will start a lot of text scrolling on your screen. Just be patient. When it stops, you will see a login screen. Log in under your name (sometimes this is "owner").
4) You will now be logged in to you computer in Safe Mode. A message will pop up asking if you want to use Safe Mode or System Restore. Click on System Restore.
5) You should now have the option to undo your last System Restore. Choose this option and follow the instructions on your screen to get back to where you were before you tried to restore your laptop.
If you need further help after that, please reply with the name and model number of your laptop. For example, "Dell Inspiron 530," or "Compaq Presario 3000." Also let me know what version of Windows you are using, for example "XP" or "Vista."
Jan 08, 2009 | Computers & Internet
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
