Question about Muratec Copier
Service 18 TONER TRAY IS OVERFLOW & TONER JAMM IN TONER TRAY WHEN REMOVE TO PULL OUTSIDES IN RODS?
  • 3 Answers
What is the problem for call service 18 i need solution
Posted on Nov 30, 2013
HOW DO I REMOVE TRAY2?
Tray 2 should be the one on the bottom and you should be able to put your fingers under the middle section and pull it out.
Jun 23, 2014 | HP LaserJet 2430 Printer
Aficio mp c2051 waste toner bottle 2 full. wheres the bottle?
next to first cassette tray left side of it. pull cassette out then pull on left side cover were tray was. There is a screw that has to be remove if it wont open on top unless someone has take it out already. When emptying toner go outside and take a big garage bags it is messy along with a rags to wipe down when down.
Dec 03, 2011 | Ricoh Aficio MP-C2051 Color Copier
Toner light on and have cleaned overflow tray still on will not reset new toner in
ok mate. clean the toner supply unit where the toner fits in. the unit is blocked with toner inside. that is why it is not supplying the toner to the machine.
Dec 08, 2010 | Ricoh FT3713 Copier
Remove toner
you need to place new toner on top of toner unit, press it until cliks and you pull the plastick "track" out do not tear it.
May 10, 2010 | Canon ImageRunner 3320N Copier
Remove jamm paper from the hp laserjet 1018
bring out your catridge and try to pull out the paper out of the printer, lastly use forceps for the resedual paper stuck into the paper roller
Apr 13, 2010 | HP LaserJet 1018 Printer
Have vertical cyan lines 1 inch wide on same side
Don't know about your "primed" toner, but go to Diagnostics and run the PQ test. See what that looks likes. Go to Disable Cartridge Check and swap the black and cyan toner. Run another PQ test. Are the lines still there and are they black or cyan? If they are cyan, the cartridge is bad. If they are black it's not the cartridge. It going to take a tech to look at it.
Feb 02, 2010 | HP LaserJet 4650 Color Printer
How to replace savin c3030 waste toner bottle
The used toner collection bottle is located behind the cover, just left of tray 1. To empty/replace this bottle, follow these steps.
  1. Turn machine off with red rocker switch, this is located on the left side of the machine.
  2. Open front cover.
  3. remove screw on the bottom-left side that holds the toner collection cover closed.
  4. close the front cover
  5. pull out tray 1
  6. open toner collection bottle cover(swings to the left)
  7. pull out toner collection bottle
At this point you can empty it or replace it, and reassemble in the reverse order of removal.
Dec 05, 2009 | Office Equipment & Supplies
My Brother HL 5250DN printer has started making a loud clicking sound when it tries to feed paper for printing. It then stops and the paper light starts flashing.
Clear the jammed paper as follows.
Observe Cautions signs in printer.
Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and prevents paper jams.
1. Press the cover release button and then open the front cover.
2. Slowly take out the drum unit and toner cartridge assembly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
3. Pull the paper tray completely out of the printer.
4. Close the front cover.
5. Pull the jammed paper up and out of the printer.
6. Open the front cover again.
7. Open the back cover.
8. Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
9. Using both hands, gently pull the jammed paper out of the fuser unit.
10. Close the back cover.
11. Pull the duplex tray completely out of the printer.
12. Pull the the jammed paper out of the printer or the duplex tray. Put the duplex tray back in the printer.
13. Push down the blue lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
14. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the blue lock lever will lift automatically.
15. Put the drum unit and toner cartridge assembly back in the printer.
16. Put the paper tray firmly back in the printer.
17. Close the front cover.
18. Make sure that the Paper LED is now off and the printer is ready.
After clearing paper jam if noise persist printer may need a Repair Tech and parts replacement for broken or wore parts.
Dec 04, 2009 | Brother Office Equipment & Supplies
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
Muratec Copier Logo
93 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Ben
Ben
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
