Question about Blendtec Smoother Blender Package, Touch Pad Controls, Quiet, Clear-14834
Need Blendtec motor carbon brush replacement....where to buy in Ireland?
The blender blades are only moving really slowly. Can I open the blender to clean parts that may be sticking? If yes, then how do I do this?
If blender blades are realy turn to slow in most cases the armature of the motor can having a few bad collectors where the carbon brushes can be to short but have been warned of the risc to order new carbon brushes that they can be becomes as short as the old ones in a real very short time, so make a ohm measure of the armature collectors over the carbon brushes if there is a thermal closure in the anchor(armature), in most case you can smell the problem or hear it and sometimes feel it because the motor becomes hotter then normally that its no longer has the right speed anymore.
Replace the blender is most times marketing technical an better option then repair it. but its in priority depend most on the brand and price.
Feb 17, 2016 | Blenders
This morning while I was making my smoothie, the macine just , stop. What should I do?
Might be the carbons brushes of the motor.worn out. It's a relatively easy job to repair.
See this yourtube video
How to Replace Carbon Brushes on any motor
Vintage Waring blender with bad motor brushes
Replace the Blendtec carbon brush
Where can buy brushes for my blender Blendtec Total Blender
Of course if you feel you don't have the technical knowledge to open your blender and check if ti's a "carbon-brush" failure, you should take it to a repair service
Sep 10, 2015 | Blenders
Haven't used it in a while and when I did the interior was smoking and the smoothie tasted terrible
It could be either a melted wire or the motor winding overheated and shorting out. If it is the motor, you should just buy a new blender. It would have to be taken apart to see inside. If you are handy, fix the burnt wire yourself. If not, better off buying a new one. Do not leave it plugged in, when not being used, due to a fire hazard.
Aug 26, 2015 | Blendtec Blenders
Get a manual for blendtec ES3
i have blendtec blender model ES3 they have problem always showing overload?
Apr 06, 2012 | Blendtec Extra Carafe / Jar for the Total...
Does anyone know how to reset a Blendtec ICB-3 to factory settings?
ust removing all power from the machine for 15 secs or more should reset it.You can contact Blendtec here, Not a solution I know sorry. The manual is here http://www.blendtec.com/Resources/A3-31E-BHMV/Connoisseur%20Manual.pdf
you can contact them here
http://www.blendtec.com/contactus.aspx
Jan 03, 2011 | Blenders
Blendtec replacement jar
You can also go to http://veggiesensations.com to buy blendtec total blender parts. Hope this helps!
Jun 30, 2010 | Blendtec Extra Carafe / Jar for the Total...
How to change the blade
You can't. The Jars have perfectly balanced blades that cannot be changed. A replacement jar from Blendtec is cheaper than a replacement blade assembly from other manufacturers. 1-800-253-6383 is the customer service number.
Jun 04, 2010 | Blendtec Smoother Work Top Blender
BLENDTEC BLENDER WONT WORK WATCH DOG TIME OUT?
That is a motor issue, you need to contact Blendtec customer service. They will let you know if it is still under warranty. 1-800253-6383.
Oct 31, 2009 | Blendtec HP-611-FLP / HP-621-FLP Work Top...
Blendtec blender jug split
I wouldn't fix the jar, just buy a new one. A crack, though rare, could possibly harbor bacteria. You could try using heat and melting it, but it wouldn't work as well. Your jar may still be under warranty, call Blendtec at 801-222-0888
Feb 24, 2009 | Blendtec Extra Carafe / Jar for the Total...
Blendtec Smoother Blender Package, Touch Pad Controls, Quiet, Clear-14834 Logo
167 people viewed this question
Top Blendtec Blenders Experts
eyecam
Are you a Blendtec Blender Expert? Answer questions, earn points and help others
