Question about Printronix Line Matrix P5005B Printer
Ram test failed b11 error
B11 ram test fail error
My desktop frequantaly booting what can i do
When you say frequently rebooting; Is it randomly rebooting without warning? Do you get a BSOD (Blue Screen of Death) error message? Or does the PC just reboot without any error's other than windows was not shutdown properly?
MOST random reboot issues are caused by Power issues;
-Failing Power Supply
-Blown Capacitors on the motherboard
-Insufficient power to run the system.
These would be a good place to start to troubleshoot if you do not get a Blue Screen Error Message.
-Failing Hard Drive can cause this issue as well but is usually acompanied by a Blue Screen Error of sorts.
-Failing RAM again usually accompanied by a Blue Screen Error.
You can test for failing hardware, by using Hiren's Boot Disk for diagnostic tests on your Hard Drive or Ram.
Hiren's Boot CD 15.2 - http://www.hirensbootcd.org/files/Hirens.BootCD.15.2.zip
You will want to run memtest X86 to test the Ram or Hitachi's Drive Fitness Test or SeaTools to test your hard drive.
This BootCD is not for the typical end user whom may not know there way around the features and options this Tech CD provides.
You will want to burn the Hirens Boot.ISO file to a CD (Burn Image Option) using any of your favorite flavors of burn software.
Hope this helps.
You can also download these diagnostic test individually such as memtest x86 and Hitachi's DFT or SeaTools independently from the Boot CD just by doing a google search. This might be the easier way to perform these tests for people who aren't very savvy with boot CD's.
Dec 09, 2013 | Intel D845GVSR Motherboard
Error code 2000-0122
Error code 2000-0122 means that the RAM failed its tests, the steps to fix it are:
  1. Locate the RAM modules in your laptop, (refer to product documentation for help)
  2. Remove the RAM modules one by one, if you have say 2 stick of RAM installed, put one in and leave the second out and try again if it still fails, remove it and put the other one in and do the same.
  3. Failing that place both the RAM modules in together and try a third time
  4. If this is still failing, you require new RAM
May 31, 2013 | Dell Computers & Internet
My dell E1505 memory test failed error code 2000 0123 DIMM_A Address=0_55c7FF5ch,Actual=D5555555h.Expected55555555h March LR And PMOVI test Failed error code 2000 0123 IT shuts down radomly on battery...
Computer does not boot up The problem maybe the RAM, it could be faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Apr 05, 2013 | Computers & Internet
Error code 1 and 3 on my Precor 9.21s treadmill?
Precor Error 01, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 01
Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
Precor Error Code 03 E03 EEPROM Test Error
Mar 27, 2013 | Precor 9.21s Treadmill Display Console...
Getting error message on ibm x3400 Fatal Error Controller Monitor Failed Controller Not Started
dear sir in my server IBM X3400 has a problem due to RAM it might be corrupted or out of order bcause system gives continues beep when i change the RAM with HCL 1 GB DDR2 (Previous RAM was also 1 GB) it gives error:
waiting for controller to start
FATAL ERROR: controller kernel self test failed
<< press any key to continue>>
please solve the problem
Oct 28, 2010 | IBM x3400 Server
I ran diagnostics on my Dell Inspiron 1525. Results: Data Bus stress test failed. Memory compare error, DIMM-B. Suggestion: try to reseat the memory. How should I do? Please help! Thanks T.Doan
1. reseat the ram
2. at the buttom part of the laptop you will see a window covered which will allow you to remove and have the ram be reseated.
3. take out 1 ram firs then run test then run again the test using the other slot. please test each ram on each slot. check if the faulty if the ram or either of the rams of one of the slots. if both ram passed on one of the slots means that ram is ok and slot is not, so then replace the motherboard. if one ram errors on a slot which the ram passed then that ram might be faulty and needs replacement.
Oct 15, 2009 | Dell Inspiron 1525 Notebook
Continuous beeping sound
Do you get video? If so then it could be a stuck key on the keyboard.
Do you get no video? If so then reseat the RAM.
Feb 10, 2009 | Sony VAIO PCV-RX370DS PC Desktop
BOOT FAIL: PCF8584: I2C ERROR
According to the message you received on the screen there's might be something wrong with your RAM module(s). Take a look inside and see if everything's alright with RAM. Replace it to another slot if there are empty.
Download and use a program like MemTest to see if RAM is properly working.
If you have another computer which is compatible with your RAM, try it inserting then in to PC and see if everyhting's alright.
If nothing helps, then purchase a new RAM module
Jan 30, 2009 | Dell PowerEdge 6400 Server
Virus or bad sound card
check your ram .also i think your hard diskl had bed sectors
no woorry if u have winodws xp bootable disk
boot your ssytem wiht it
run the chkdsk /r command.
but first chek your ram fix correctly in slots
that it.
Sep 29, 2008 | Computers & Internet
Printronix Line Matrix P5005B Printer Logo
57 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Cliff
Nick
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
