Question about Hotpoint TDC32 Electric Dryer
Hotpoint Tcm580p burning smell - Hotpoint TDC32 Electric Dryer
Hotpoint Aquarius condenser dryer, TCM 580p. Where can I purchase a pump microswitch?
A local appliance parts supplier might be able to help. You also can go to www.repairclinic.com and enter Hotpoint TCM580P to see a list of available parts.
Dec 16, 2015 | Dryers
Hotpoint TCM580P not heating
hi check heater element hasent broke if ok go for thermostat
Apr 11, 2013 | Hotpoint TDC32 Electric Dryer
Not filling water tray,condensating all around dryer
hi is condensor box nice and clean in bottom
Feb 15, 2013 | Hotpoint Dryers
I have a hotpoint VTD00 tumble dryer and it is heating up but the drum isn't spinning and smells of burning. Thanks, Annmarie
The belt is probably worn out and is slipping,the smell is from the belt slipping on the drum.
Mar 02, 2011 | Hotpoint Dryers
Comes on and kicks breaker smells like something is burning
if you smell burning then i would say the transformer is burning and if will trip breaker . some times the mag has failed causing over load to trans and both will have to be replaced. this is a big buck repair . you may want to replace ..
Jan 04, 2010 | Hotpoint RVM1435 Microwave Oven
WF220 Hotpoint - burning smell + wash cycle stalls?
The burning smell is coming from motor. Also your clutch is bad where you are hearing the rattle/grinding.
Dec 12, 2009 | Hotpoint Aquarius WF220 Front Load Washer
DRUM NOT SPINNING....and a burning smell
Motor going bad. Run windings inside are burneded up.  Start windings are ok. replace motor.
Jan 07, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC32 Electric Dryer Logo
16 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
