Question about Bosch 24 in. SHU43 Built-in Dishwasher
My bosch aqua stop dishwasher does not run all the lights are on as normal
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 92 Answers
Could be the microswitch on the door catch.
Posted on Oct 19, 2013
Master_Tech
  • 770 Answers
SOURCE: How do you "undo" the aqua stop?
create an inverted trap in ther dishwasher drain line so the water cant back feed
Posted on Jul 09, 2008
  • 6 Answers
SOURCE: Bosch dishwasher shu4322 has code 1 aqua sensor what is the sensor do and where is it located
Most of the dishwasher has a Thermal hold period in which the machine will not advance to the next cycle until the water temperature reaches a specific degree. it is possible that your aqwa sensor/or heater is bad OR as in most of the cases, the Timer relay that is responsible in turning the heater on is stuck open, in this case you need a new timer. So,Check Timer/Aqua sensor/Heater
Posted on Aug 15, 2008
  • 98 Answers
SOURCE: One year old Bosch dishwasher stop wrking.will not
Start with the basics: Check the status of the breaker and the electrical connections under the toe kick panel. If the unitis getting power, You may want to call the dishwasher helpline to see if it is a recalled model. A free replacement of the control panel circuit board is available for many of these, but if the power switch is the culprit, you will need to buy a replacement button.
I have written a guide to help with drainage issues. The helpline number is near the top. It is here. Thanks!
Posted on Jul 19, 2009
canddplumb
  • 35 Answers
SOURCE: Bosch dishwasher stopped rujnning
Your dishwasher may be pluged into a gfi plug and need to be reset ,you might have wiring short posibly do to a pinched wire. Make sure your door was closed good,that could be the problem,If its a wiring problem call an aplliance repairman or electrician.
Posted on Dec 02, 2009
  • 70 Answers
SOURCE: AQUA SENSOR BOSCH DISHWASHER NOT FILLING WITH
Hi, if your dishwasher is not filling with water, check the Water-inlet Valve and Float Switch
The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Posted on Jun 21, 2011
How do I get to make it stop and work .Dishwasher is not shutting down it says E 15 Water tap flashing , and red Aqua stop light .
inlet valve is the aqua stop long hose to tap has a solenoid at tap end that is likely your fault
Sep 29, 2016 | Bosch Dishwashers
Can i remove the aqua solinoid cut off valve from bosch dishwasher
the valve and wiring can be replaced you cannot remove it altogether as it wont be able to fill up, bosch aqua stops are normally powered solenoids that also double as the water inlet valve unlike most other aqua stops
Sep 27, 2014 | Bosch Dishwashers
I need a user's manual for SGS5302 bosch dishwasher. Otherwise would you tell me exactly how the aquastop works? Is there any method to bridge it? What goes on the wires? Signals from or to the...
Please rate this solution if you find it helpful. Thanks!
The Aqua-Stop function is a flood protection feature. You really don't want to be "bridging it"!
It works by using a float switch to detect when the water level gets too high in the wash compartment. It over-rides any wash programme and starts the pump to empty the water out.
Also if water leaks into the bottom of the dishwasher (under the washing compartment) the float will rise with the water level and when it reaches a critical point, it will over-ride any washing programme and run the pump.
However, the pump cannot remove water from under the washing compartment, but as it over-rides the wash programme, it prevents the washer from continuing with any wash cycle, thus preventing any more water from leaking into the bottom of the washer and flooding your house.
For this reason, you should never attempt to "bridge" (whatever that means) modify or disable the aqua-stop feature. If it's been activated, you have a problem which needs to be resolved before you continue to use the washer.
Here is a direct link for downloading your manual from Bosch (free):
http://www.bosch-home.co.uk/quick-links/customer-service/download-product-manuals.html
Oct 16, 2010 | Dishwashers
Where is an Aqua-stop fitted in a dishwasher?
In the water inlet hose close to the valve on your supply end,its encased in a big ( 2") plastic housing with a brass fitting.
Hope this helps.
May 21, 2010 | Siemens 24 in. SE25A266 ExtraKlasse...
Jul 09, 2008 | Bosch 24 in. SGS43C02 Classixx Built-in...
Freshwater not being taken by aqua-stop safety device
either water valve is bad or water line screen at valve is clogged. also, check if water is turn on..
Apr 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Nov 21, 2006 | Bosch 24 in. SHU66C05 Stainless Steel...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
142 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
