Question about Bradford White M-4-403S6FSX 40 Gallon - 38,000 BTU Defender Safety System Energy Star High Efficiency Residential Water Heater LP Gas
New Bradford White M-4-403S6FSX LPG water heater worked as expected for about 30 minutes and now the burner won't light. Pilot light is on but no burner no matter where thermostat is set.
  • Bradford White Master
  • 5,089 Answers
3 Suggested Answers
  • 5089 Answers
SOURCE: I need the basics for replacing a thermostat on a water heater...Bradford/White brand, model M250S6DS2 50 Gal, 4500 watt per element 240 voltage 50/60 hz. It keeps over heating even at lowest setting
Copy following link for replacing thermostat.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Suggest you might also want to test the elements while power is turned off, just in case the problem is element shorted to ground across metal tank to ground wire.
http://waterheatertimer.org/How-to-test-water-heater-element.html
At least you know the 240volt power to water heater and the circuit breaker are good.
Posted on Oct 01, 2012
  • 42 Answers
SOURCE: BRADFORD WHITE 40 GALLON ELECTRIC WATER HEATER MODEL M240S6DS-1NCWW.. PROBLEM : I WAS ONLY GETTING A FEW GALLONS OF HOT WATER FROM HEATER. FIGURED ONLY TOP ELEMENT WAS HEATING SO BOUGHT TUNE UP KIT AT
Doesn't sound like its the dip tube, its a element problem, I would contact bw directly to see if heater is stil in warranty and they will send you new parts free.
Posted on Dec 18, 2012
How do I light my hot water heater?
It is pretty easy - make sure gas valve is open, change control know to pilot. Press the ignitor a few times and once pilot lights up switch control to warm or hot position.
See instructions by downloading manual for MI-403SF6BN from this site
Bradford White Water Heaters Built to be the best
Sep 15, 2014 | Bradford White Bradford MI403S6FBN-337 40...
How do you light the pilot light?
Hello, You cant light a pilot light on an electic water heater. All you can do it have electrician make sure it is wired in correctly and have him show you the correct breaker or fuse for the water heater.
May 19, 2014 | Bradford White M250S6DS2 50 gallon 240v...
How do i light the pilot light
Usually 1 minute.
Copy following link to identify gas control valve and read lighting instructions:
http://waterheatertimer.org/How-to-light-gas-water-heater.html
Gene
h
Dec 12, 2013 | Bradford White MI40T6FBN 40 gallon natural...
My Bradford White Defender M-I-30T6FBN doesn't show igniter button on instructions
1) Copy following links to identify gas control valve and read ignition procedure, and access service manual for your product:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Honeywell gas control used on recent Bradford White gas water heaters has red knob that rotates to pilot. Press and hold red knob. Then push red igniter button until status light changes.
Feb 11, 2013 | Bradford White Bradford MI30T6FBN-337 30...
Trying to reset pilot light per instructions. Something is missing.
1) Copy following link to identify gas control valve:
2) Add a comment and describe gas control valve, and include if this is on boiler or water heater
Rheem 300170 HWS service manual
1) Rheem does not post service manuals.
Call Rheem and ask why, since the other big manufacturers, AO Smith and Bradford White do post service manuals.
2) You need new propane gas control valve, and matching combustion parts to fit existing tank.
http://waterheatertimer.org/pdf/Rheem-Water-Heater-parts-catalog.pdf
http://waterheatertimer.org/images/IMG_1826-LP-burner-450.jpg
3) Rheem does not recommend changing gas type, especially from natural gas to LPG.
LPG is higher pressure, and burns much hotter and requires cast iron burner, unlike the lighter-weight metal used for Natural gas burner.
The manifold tube and thermocouple must match the gas control valve, and gas-type and have correct thread for propane.
The combustion chamber and heat transfer surface can also be heavier metal for propane heaters.
Feb 08, 2013 | Water Heaters
I am thinking of purchasing a Reliance water heater and notice that there are many complaints about pilots continually going out. Have these issues been addressed? I currently have a A.O. Smith which has...
I do water heater research for specific purpose.
I see complaints about every brand except the brands that are no longer in business
Most complaints about gas heaters involve burners & pilot.
Here are some things that might help you decide:
New water heaters have to meet regulations
for clean-burning and efficiency.
As a result, water heaters exposed to poor incoming air supply, and poor venting are more likely to be affected by chronic pilot light problems.
Bradford White manual I was reading said, to remove chemicals from same room as water heater. Chemicals corrode water heater parts. This would affect the pilot light as well.
'Spray propellants, cleaning solvents, refrigerants, swimming pool chemicals, calcium and sodium chloride, household bleach, waxes and process chemicals are corrosive at very low levels with no odor."
Yearly maintenance: you're supposed to clean burner and combustion area with a wire bush and vacuum each year.
The FVIR is another consideration today. Flammable Vapor prevention.
Consult the manual before buying the product.
Many gas water heaters have a screen located on bottom of water heater. When the screen clogs with dust, the reduced airflow will stop the burner. Unless the water heater legs are set on bricks, then you can't get under to clean the screen.
If the FVIR trips because it detected a flash-over condition, you have to buy parts for all water heaters except the Bradford White. BW has a re-settable FVIR.
http://www.thetankatwaterheaterrescue.com/forums/forum3/2679.html
http://411plumb.com/bradford-white-defender-water-heater-review
The 411plumb,com website is a good source of information
The Tank is a good place to post water heater questions
: Those guys are professional plumbers.
Maintaining your water heater is important.
Look for a brass drain valve instead of plastic.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Anode rod.
If water heater has two anode rods, the tank will last longer.
Inspect anode rod every 3 years.
Loosen anode rod before installing tank so it will come out easily for inspection
Or if it has a powered anode rod, it will supposedly last 'forever' ... until the burner gives out.
http://waterheatertimer.org/Replace-anode-rod.html
Other water heater ideas:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Oct 2010. If you have more questions, add a comment at bottom and it sends me an e-mail
There are a lot of good sources in the links above.
Oct 26, 2010 | Reliance Water Heaters
Bradford White hot water heater - burner lights only 30 seconds
The slightly warm water makes me think of a thermostat problem. The fact that the heater is 10 years old I wonder how hard your water is. Calcium build up kills water heaters. But the yellow flame you mention could be the results of dirty orfices. May want to have a Pro look at that.
May 03, 2010 | Water Heaters
Hot water heater does not light
burner and pilot assebly and orifaces need to be cleaned
Sep 16, 2009 | Fasco Bradford White Water Hot Heater...
Bradford White M-4-403S6FSX 40 Gallon - 38,000 BTU Defender Safety System Energy Star High Efficiency Residential Water Heater LP Gas Logo
164 people viewed this question
Top Bradford White Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Bradford White Water Heater Expert? Answer questions, earn points and help others
