Hi, I have an AEG LAVAMAT L 71655 washing machine and the problem is that it does not heat the water so it washes only with cold water.Perhaps it is a thermostat malfunction. Tha question is how can I get access to the thermostat? is there any service manual available? what kind of thermostat it is used? Thanks for your help.
SOURCE: aeg 76669 oko lavamat machine not
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Posted on Jun 24, 2008
SOURCE: Washing Machine Fault Code
The recommendation to get a new motor may be overkill and a very expensive option. Also on this site I found an alternative solution which was to just replace the motor brushes. This we did and it fixed the problem, coasting us just £20.15, rather than the £199 quoted for a new motor!
A reasonably competent person needs to remove the motor, identify the brushes and remove - just involves two hex-head screws. When new the brushes will be around 2.5cm long. They need to be around 1 - 1.5cm long to work. Alternatively the spring(s) may be sticking, preventing the brushes from being pushed against the rotor.
When calling suppliers to enquire as to availability I needed not just the product description, but also the PNC and serial numbers (located inside the front door), as types of brushes have varied during the production period. However the outlet I went to still did not have the correct bush - housings were different. The chap serviing very kindly swapped new brushes into the existing housings - this is something you could do yourself if you cannot get the exact same ones - just a little fiddly.
Hope this helps!
Posted on Sep 25, 2008
SOURCE: AEG Oko-lavamat 538 manual
www.manualshark.org/manualshark/files/5/pdf_10471.pdf
Posted on Dec 10, 2008
  • 3230 Answers
SOURCE: AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
Posted on May 06, 2009
  • 3230 Answers
SOURCE: AEG Lavamat 86720 washing machine
This means your water sensor has detected a leak. it will stop when the sensor is dry.
post further comment for more help......
My AEG lavamat 541 washing machine is not draining
Select the program of draining or spinning.
You should hear the drain working. If not, don't insist.
Turn it off and pull the power cord out. After that, you should clean the filter of the appliance. This is located on the bottom of the front panel. Just watch out ..becuase when you unscrew the filter, all water will come out from there. Be sure you have a towel beside you!
After the water comes out, check into the hole of filter if there is any object that blocks the pump to work. If you find something, perhaps you solved the problem! Here is the user instructions of how you can do it. AEG Lavamat 541 electronic Operating Instructions Manual
Mar 01, 2017 | AEG Washing Machines
Where is the filter for die AEG lavamat 538 washing machine and how do you clean it?
The only filter/screen I am familiar with is the one in the hoses the supply hot and cold water to your machine. They should be checked once in a while but I have never found much in them.
However, the manual for your machine is located here:
AEG OKO LAVAMAT 538 Operating Instructions Manual
Best wishes,
Joe
Aug 24, 2016 | AEG Washing Machines
AEG Lavamat 64809 error code E30
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
Jan 04, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 76400 during spin cycle blows a fuse
its not the heat element its the water pump i would say it has gone to ground try disconnecting the water pump if the fuse does not trip then replace the water pump
Jul 03, 2010 | Washing Machines
Can I use hot water supply only on my AEG Lavamat W 1159?
A valid point but unfortunately your machine is programmed to take both and will register this as a fault.
This is probably not what you wanted to hear but please dont shoot the messenger.
Jan 22, 2009 | AEG Lavamat W1450 Front Load Washer
AEG WASHING MACHINE
fit hoses at random. put on a rinse cycle. if cold water comes in then hoses are correct. if hot water comes in, then reverse hoses
Aug 22, 2008 | AEG Lavamat 72640 Front Load Washer
Washine machines
Yes. There is a part that allows you to connect the cold water supply to both the hot and cold inlet hoses. It has worked successfully on our 6100 for 8 years or so. I think it was part of the original kit rather than a subsequent purchase - it's a Y-shaped yoke with an inlet connection and two outlets that accept the two hoses feeding the inlets of the machine. From memory i tink the situation is mentioned in the user manual somewhere.
Jun 10, 2008 | AEG Lavamat 72640 Front Load Washer
AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
Mar 03, 2008 | AEG Lavamat 88840 Front Load Washer
Washing Machines Logo
75 people viewed this question
Top Washing Machines Experts
