Question about Fein Multimaster Rs - Msxe 636 - 2 Rs
The on/off switch appears to have blown (there was a fairly loud "pop" sound). When plugged in to the power the device comes on but cannot be switched off unless I remove the plug from the power socket.It also blew the plug 10amp fuse
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 47 Answers
So, you'll have to replace both the switch and the 10 amp fuse. Should be easy for someone who sounds like they understand electrical components :)
Posted on Oct 19, 2013
Why did, while vacuuming with Shark Navigator Professional, did I hear a loud "puff" sound?
that is usually the first sign of the motor brushes in the motor wearing out this will either be followed by the motor sounding louder and popping. or the motor just not working, if it starts popping you must stop using the appliance or the armature will be damaged and you will have to replace the motor
, Motor brushes are fairly cheap an not that hard to do
Apr 04, 2015 | Shark Vacuums
Older Dyson 07 Animal, loud ratcheting noise on carpet setting
That is an indication that the belts are worn, stretched or broken. You simply need to replace the belt. Here is a link to the belt(s) you need and a manual you can view:
Dyson DC07 Belts and Manual
Dec 04, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
The CV750 stopped working. It will come on sometimes but most of time it will not work. I installed new bag and cleaned filter. Green light on side of unit is on. Switch on side of unit will not make it...
The motor may have a sticking brush or a dead commutator segment. Turn off power to the unit to check for sticking brushes. Reapply power, does it now run? If not, shut it off, physically turn the motor a few degrees, and reapply power. If it still doesn't run, look for loose wiring around the motor. If it does run, replace the motor armature or the entire motor if the armature is not available as a separate part.
Oct 18, 2009 | Broan-NuTone CV750 Central Vacuum
Loud 'drilling' noise from motor area when turned on.
Sounds like bad bushings/bearings in the motor -- need to replace them.
May 27, 2009 | Electrolux Vacuums
I have a Hoover Windtunnel model U5462. Plugged in, turned on, it popped and then no power at all. Not circuit breaker in house. Does the unit have a fuse or something similar?
does it have a headlight and does it work? if so then unplug the vacuum and turn the brushroller by hand a few times.then plug it back in,if it works then your motor might be bad.you can try to spray a little wd40 into the switch then.work the switch back and forth a few times first to get the lubricant worked in to the switch .try to turn it on now.see if you have any cuts in the cord.also see if the cord is pulled out of the vacuum .if so you might have a wire unplugged inside the base of the vacuum
Apr 23, 2009 | Vacuums
Wind tunnel supreme sounds very loud
Sounds like a bad motor, you have a years warranty on this, take it in for warranty repair. You will void the warranty if you mess with it.
May 08, 2008 | Vacuums
Fein Multimaster Rs - Msxe 636 - 2 Rs Logo
152 people viewed this question
Top Fein Vacuums Experts
JoeVacs
Are you a Fein Vacuum Expert? Answer questions, earn points and help others
