Question about Acer Aspire 5050-3242 Notebook
Rtc error ab2 - Acer Aspire 5050-3242 Notebook
I have a RS Medical RS-4i Plus and it keeps saying on the display, RTC error how can i fix that.
Verbatim right of of the manual: If any of the following Device Errors appear the product will not work and will require repair by an RS Medical technician. Contact Customer Service at 800-935-7763 to discuss repair or replacement options. RTC error - displayed when the real time clock (RTC) has been disrupted or has lost charge.
Nov 03, 2017 | The Computers & Internet
2000-0233(Not used with UEFI BIOS)
System board - RTC 'seconds' count is not updating
An error occurred during the tests that involve the Real Time Clock (RTC) of the main system board in the system. If a memory error is detected, try memory modules individually. If no 2000-0123 memory error & If diagnostics fail again after the BIOS is current, contact Technical Support to resolve the problem.
  • Update to the latest BIOS.
  • Repeat the ePSA diagnostics
  • If failure continues contact Technical Support
Probably an exhausted battery.
Apr 11, 2014 | Dell Computers & Internet
Every time i boot up my brand new dell vostro i get an error: 00c08270 real time clock error - check time and date settings. I have been continuously updating the time and date but the error message keeps...
Meaning the RTC battery needs to be replaced.
The Real Time Clock battery is the CMOS battery.
http://support.dell.com/support/edocs/systems/vosA860/en/sm/index.htm
Coin-Cell Battery
The laptop has to be completely disassembled down to the motherboard (System Board) in your hand.
On the bottom of the motherboard is the RTC Battery.
Since the laptop is brand new this falls on the place where you purchased it, or Dell.
It is still under warranty as far as replacing the RTC Battery. (It came with a bad battery. They need to replace it, not you)
Regards,
joecoolvette
Jul 09, 2011 | Dell Vostro A860 Notebook
Bad rtc chip please reboot
RTC is the Real Time Clock or the Modem within the terminal. This error means that the device is failing and would need to be replaced at some point. To resolve you would need to powercycle many times in a row until the screen with show "TAMPERED", then it will go to the Sale, Refund, Void screen and you can run transactions. This error will arise in the future. RTC error cannot be resolved for good. Thank You!
Jun 17, 2011 | VeriFone VX510
Verifone vx 510 bad rtc chip please reboot
verefone the terminal has a problem in the display shows bad rtc chip, as I can compose for it functioning properly again?
Jan 11, 2010 | VeriFone VX510
I get the message "Bad check sum (CMOS)" Model toshiba tecra 730XCDT
hi friend,
Probably a dead Motherboard battery. Need to enter the BIOS screens and reset values. Especially the time and date. Maybe the boot order and if using USB KBoard enable legusy USB devices. This will occur each time your friend shuts down and reboots until the battery is changed.
Issue
When you turn your Toshiba computer on, you see an error message like: **** Bad RTC battery ****
**** Bad Checksum (CMOS) ****
Check system, then press [F1] key The Real Time Clock (RTC) battery provides power for the internal clock/calendar and for maintaining system configuration settings.
This error can occur when a machine has been left turned-off for an extended period of time (around a month), and is the result of a depleted RTC battery. Other symptoms include not being able to execute Windows Update properly, errors/problems executing application software (like Norton Antivirus), and the appearance of the Windows XP "Desktop Clean Wizard".
Resolution This condition is easy to fix in 3 basic steps: Reset the BIOS defaults
Set the correct date and time in Windows.
Charge the RTC battery Please follow the detailed instructions in the next section.
Procedure Set BIOS defaults Press the [F1] key as instructed in the error message:
Check system, then press [F1] key In the BIOS setup screen press the [Home] key to restore the default values, then press the [End] key to save and exit, then the [Y] key to confirm and restart the system. Set the correct date and time in Windows As Windows starts-up, you may see an error message about an "Invalid System Time". Go ahead and click "OK" to clear the error dialog. Open the Windows Control Panel and open the "Date and Time" control by double-clicking its icon. Set the correct date and time, then click OK to save. Charge the Real Time Clock (RTC) battery To charge the RTC battery, connect the AC adapter and turn the computer on (both the DC IN and Power LEDs must be green). Leave the machine on for approximately 24 hours to ensure a full charge in the RTC battery. Please note that the RTC battery does not charge while the PC is turned off, regardless of whether the AC adapter is connected or not. Other Information: If, on subsequent reboots, the "Bad RTC Battery" error persists, it's quite likely that you actually do have a bad RTC battery. If that's the case, you should contact a Toshiba Authorized Service Provider to have the system serviced. Windows XP Desktop Cleanup Wizard The first time you reboot Windows XP after resetting the system clock, Windows XP may try to run the "Desktop Cleanup Wizard". Simply Cancel the "Desktop Cleanup Wizard" at the first dialog. If you do manage to clean your shortcuts from the desktop and want to recover them, you will find them in a folder called "Unused Desktop Shortcuts". You can recover them as follows: Double-click to open the "Unused Desktop Shortcuts" folder
Drag the selected items back to your desktop
Close the "Unused Desktop Shortcuts" folder. You can delete this folder if it is empty.
thank u for using fixya
regards,
sivaranjini
Aug 10, 2009 | Toshiba Tecra 730CDT Notebook
Hp all in one 5610 wont receive fax and phone line does not go on double ring . incoming fax shows phone off hook when trying to receive fax.no ready appears
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab2
Jul 07, 2009 | HP Officejet 5610 All-In-One InkJet...
Turn on computer and message reads ****bad check sum (CMOS) ****
That means that after computer had been off for a long time the CMOS battery has drained, and CMOS (BIOS) settings had been reset to default.
Usually the computer will work fine after pressing F1, but you may get wrong date and time.
Try charging battery completely, often the problem disappears, if it does not , then the choice is between pressing F1 each time you start the laptop, or disassembling the laptop and replacing CMOS internal coin battery, located on the lower side of the motherboard.
May 17, 2009 | Toshiba Satellite 1805-S204 Notebook
Part # for aspire 5043 motherboard
There are a few motherboard this series:
MB.AA101.001RF - Refurbished Main Board AB2 V128 w/MDM&Cable
MB.AA101.002RF - Refurbished Main Board AB2 V64 w/MDM&Cable
MB.ADX01.001RF - Refurbished Main Board AB2.UMA w/MDM/Cable/RTC
MB.ADX01.001 - Main Board Ab2 UMA w/Mdm/Cable/Rtc - Repair Flow Only (repair flow. send failty motherboard in advance)
MB.AA101.001 - Main Board Ab2 V128 w/Mdm&Cable LF - Repair Flow Only (repair flow. send failty motherboard in advance)
MB.AA101.002 - Main Board Ab2 V64 w/Mdm&Cable LF - Repair Flow Only (repair flow. send failty motherboard in advance)
www.acerparts.com
other guy asked for aspire 5100 motherboard, look here
http://www.zandparts.com/acer/index.php?cPath=40886_40887_40929_41356
Nov 22, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5050-3242 Notebook Logo
22 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
