Question about Electronics - Others
I Have Transcend JetFlash 4GB Pen Drive of D33193 showing Write Protection in Action file are not copied from hard disk And also not Formatted. I also try all possibilities that I have Know including changing registry value.
    Champion:
  • 221 Answers
You can repair your JetFlash pen drive at http://www.transcend-info.com/Products/online_recovery_2.asp?LangNo=0
Posted on Dec 24, 2013
3 Suggested Answers
  • 32 Answers
SOURCE: USB drive write protected ????
There is a small unlock tab. Please push it in right place to unlock
Posted on Jan 26, 2010
SOURCE: how to remove the write protection from a
MY JETFLASH V10 OF 8 GB SHOWS WRITE PROTECTED AND NOT FORMATED NOT ADDED ANY FILE
Posted on May 11, 2010
Hi I have a transcend jetflash d33193 4Gb flash that won't format. It tells me the flash is write protected and i don't she any physical lock. i have tried every possible thing i know on it but it...
The message which you are facing while formatting your flash drive maybe be due to below reasons.
1) It could be due to virus. Try to scan your flash drive with your anti-virus and check.
2) Second reason would be when you connecting your flash drive it may include some autorun files which starts its own when you connect your flash drive and because that file is running it wont allow to be formatted, so try to delete all the files including in your flash drive and than try formatting.
or
There is right protect switch on many pen drives , a physical write protect switch which enables you to either allow writing on the disk or disallow writing on the disk.
All you need to do is toggle the right protect switch and you would be able to write files on your pen drive.
Please find an image below for more information.
Jun 08, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I HAVE A FLASH Transcend (Jet Flash V15) 4GB I CAN NOT USE IT WHEN TRY TO COPY A FILE TO IT A MESSAGE APPEAR THAT THE DESK WRITE PROTECTED AND TRY TO REMOVE THE WRITE PROTECTION I TRY FORMAT BUT NOT WORK...
1.Close all files
2.Select Transcend Pen drive-Right Click-Format-ok.
3.After formatting you can copy all files upto 4GB.
Hopethis helps. If it does, please accept and rate the solution! Contact me withany more questions you may have. Thanks for using FixYa!
May 25, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Have TRANSCEND D33193 4GB pendrive when i plugged it in my PC it is not detected , some one please help me.........
all pen drives are like jokers of a pack of cards....they behave very funny when you need them....
one of the most stupid inventions of the computer world....are these pen drives....
they are very much likely to carry virus from PC to PC....unlike the CD / DVD that cant be written without using a write program.....like Nero etc....CD/DVD disk are write protected by default....but the USB sticks can be used by drag and drop files.....so the virus get in without the user doing anything....
also when you thingk that you are buying a 4 GB pen drive, some times the dulicate are not exactly 4 GB...they are just 1 GB...and show 4GB as capacity...after using for some time they show their real face(1GB) and the drive becomes useless....
To tell you the fac many mfg are packing more and more space into a pen drive...like 32 GB, etc...but actually the physical capacilty is only 2 GB but expanded to 8 Gb / 12 / 16 GB using a compress program....after few uses....that becomes usless.....
Apr 25, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have TRANSCEND D33193 when i try to format, I have TRANSCEND D33193 when i try to format, or delete files from it, it shows YOUR DEVICE IS WRITE PROTECTED!
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
Jan 14, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My pen drive is not open (mic d33193)
u need to formate your pen drive, with low level formatting.
Jan 04, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Write Protected Problem
Hi Sir myself piyush gajera sir i was used my pen drive from winxp to another os version. afterwards it gives me an error that disk is write protected. i tried to remove or format but again it gives me prob that it is write protected and not able to format. i used different solutions but unable to format or remove write protected. please help me. how can i remove this write protection. sir my email id is piyush_gajera147@yahoo.com kindly mail me as soon as possible. my Pen Drive is transced d33193. and it has no any stick to remove write protected. Thanks in advance. i have the same error while deleting or formating my pen drive My transcend 4GB pen drive when deliting data it ask to remove the write protection while formating the disk it shows write protected. when copying data it ask to remove the write protect
Jul 09, 2009 | PNY 2GB microSD Memory Card
Transcend 2gb pen drive file copying problem
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format pen drive
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jun 27, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Transcend jet flash v30 32gb pen drive can not be formatted.
first of all transcend do not do a 32gb in V30 - so if its green then its fake - i suggest you try this link it tells you about the fake transcend 32gb - it tells you how to test with h2testw & also you can report the fake from who ever you bought - im hoping you bought via payapl so you can get your money back
http://fakeflashnews.wordpress.com/2009/03/08/transcend-32gb-counterfeit-usb-flash-drive-found-on-ebay-latest-brand-name-to-impacted-jetflash-v30/#comment-92
Feb 02, 2009 | Transcend USA 120GB Storejet 2.5" SATA -...
Doesn;t taking large files
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Jun 19, 2008 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Electronics - Others Logo
150 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
