Question about Windsor SR12 Sensor Bagged Upright Vacuum
How do you change the bypass valve switch on a sensor S12 vacuum? I can't remove the swivel neck assembly to get to the switch.
2 Suggested Answers
VacuumRepair
  • 438 Answers
SOURCE: how do you change the belt on a winsor sensor s12?
Step 1. Remove the vacuum bag housing so that you are only working with the power nozzle or the bottom portion of your Sebo, this will make it much easier to work with. Turn the vacuum upside down, and remove only the 5 screws that I have circled in red:
Step 2. After removing the screws on the bottom of the vacuum cleaner, separate the top housing from the lower agitator housing, sometimes it may take putting a flat head screw driver in between the white and grey colored housing and prying them apart.
Step 3. You now have full access to the belts on your machine. It's most likely the belt that wraps around the brush gear rather then the belt that's attached to the motor that's gone bad. I have never replaced the motor belt in 8 years of servicing Windsor vacuums.
If you have any further questions on how to replace the belt, please feel free to reply to this repair by leaving your question in the comment section, I'm always more then happy to answer any question you may have.
Thanks again,
Chris Jones
goVacuum.com
Posted on Apr 27, 2010
How to fix sensor s12. red light for bag stays on even when vacuum bag is not full and the vacuum is clear
You most likely will need to change the Yoke assembly. There is a sensor built in that gets clogged with fine debris over time. This will take care of the problem.
Feb 09, 2015 | Windsor SR12 Sensor Bagged Upright Vacuum
How do I remove the swivel neck assembly from the vacuum case?
You will also need to remove the screws on the inside that hold the motor in place because part of the side support for the swivel is under the motor. Remember to disconnect wires coming from the swivel as well before you try to pull it out, so that you do not damage them. Hope this helps.
Jul 16, 2014 | Windsor SR12 Sensor Bagged Upright Vacuum
Loud whistling noise it is just going on five years old when I pull it backward a loud noise emmits
If you whistling is only happening when pulling back on the machine, the problem is with the connection between the bag housing and the swivel neck. There is a rubber gasket between the two, located on the bottom of the bag housing. Check to see if this seal is in place. If it is there and in good shape, check for excessive wear on either the swivel neck or bag housing. Windsor Sensor Vacuum Seal 5163 86144910 allstar javelin
Apr 02, 2014 | Windsor Vacuums
I have a Windsor Sensor s12 and power shuts off after 5 min. of vacuuming. I'm wondering if it's overheating of if there is some other sensor that causes it to shut off.
Your Sensor most likely has an internal heat sensor that is shutting off the motor. Some vacuums install an external heat sensor with a reset button that you must push to re-start the vacuum. If your model does not have an external reset button it is most likely a sensor inside the motor. If it is defective the motor must be replaced to solve the problem. But first make sure the overheating is not being caused by a blockage somewhere or the bag is too full. Air must pass completely through a vacuum starting at the floor where it picks up the dirt through all the canisters, filters, bags, etc. and then is exhausted from the vacuum. Any restrictions or blockage can cause the motor to over heat.
That Vac Guy
Jan 04, 2013 | Windsor SR12 Sensor Bagged Upright Vacuum
How do you change the belt on a winsor sensor s12?
Thanks again,
Chris Jones
goVacuum.com
Apr 26, 2010 | Windsor SR12 Sensor Bagged Upright Vacuum
HOW DO YOU CHANGE BELT CANT SEEM TO REMOVE BOTTOM TO GET TO IT KENMORE WISPERTONE 116
The top cover to the light lense pops off at the ends. When you get that cover off then you will see 2 screws that are by the swivel neck. Take those out and then the whole body top cover comes off. That will get you into the roller brush and belt area of this machine.
Dec 11, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Windsor sensor says bag is full when its not
Are you vacuuming up fine particals like pet dander or just large amounts of regular dust? Also when was the last time you replaced your filters?
Just some sugestions.
Mar 17, 2009 | Windsor SR12 Sensor Bagged Upright Vacuum
Assemble Swivel Assembly onto Kenmore Canister vac
Got this post off this web site...I just replaced my swivel and it worked:
http://www.managemyhome.com/mmh/answers/Answers.action#l4q110567
To install a new swivel assembly, you will need 2 small, flat tip screw drivers. Unplug the vacuum. Push the screw drivers in between the hose and the collar where you see the seams in the plastic collar on the end where the hose enters the collar. This will release tabs that hold the collar to the swivel. Pry and pull the collar back over the hose and then pull the small screwdrivers out of the collar. Slide the collar back along the hose. Unplug the wiring connections from the hose. Pull the hose wires up and out of the holder on the swivel assembly. Lift the tabs on the side of the hose and pull it off of the swivel. Push the new swivel onto the hose. Align the hose wires and secure them in the holder. Plug the wires from the swivel into the hose wires (blue to blue, white to white). Secure the swivel wires into the wire holder on the swivel assembly. Push the collar back up the hose and onto the swivel with the plastic seams aligned with the tabs on each side of the hose. Snap the collar securely into place.
Nov 12, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Miele Vacuum cannister
Most times you have to replace the neck on the powerhead. Sometimes the switch in the handle of the hose will have a bad solder connection. But S300 is not a good model number, also the powerhead has its own number on the bottom, so couldn't look up parts for you.
Feb 21, 2008 | Miele S300 Bagged Canister Vacuum
Windsor SR12 Sensor Bagged Upright Vacuum Logo
130 people viewed this question
Top Windsor Vacuums Experts
Mike
Thatvacguy.com
Are you a Windsor Vacuum Expert? Answer questions, earn points and help others
