Question about Samsung Refrigerators
RSG5DUMH defrosted itself .control panel cannot be reset,tried all combinations
Why wont my 2001 ford windstar blow out of vents ? only on defrost?
Air Flow Control
Air flow control is accomplished in the following manner:
  • Primary control is through the function selector knob , mounted on the heater function selector switch, which is part of the heater control .
  • The function selector knob has the following positions: OFF, PANEL, PANEL/FLOOR, FLOOR, FLOOR/DEFROST and DEFROST.
  • The heater function selector switch combines a vacuum selector valve with an internal electrical switch.
  • The vacuum selector valve directs source vacuum to various vacuum control motors (18A318) . Refer to the System Airflow Schematic and Vacuum Control Charts.
  • An internal single-pole electrical switch is also controlled by the selector. The switch controls the electrical supply to the heater blower motor switch (18578) .
  • The position of the function selector knob determines the manner in which the system will operate.
  • Each position of the function selector knob is detented for positive engagement.
  • You probably have a vacuum leak , Pull heater control panel an check for vacuum . A broke vacuum hose or The vacuum selector valve is bad ! Or check for a vacuum hose in the engine compartment being off somewhere !
Mar 08, 2015 | 2001 Ford Windstar
The fridge part is too cold causing the food to freeze and the temperature knob not working... out of warranty
sounds like a defrost timer or defrost thermostat issue u can check with a multimeter, the timer can be checked with a sml flat head screw driver inserted in the tiny slot at center and turn slowly till u hear it click once not twice, u will then turn on the defrost timer. this will give another 10 -15 days before it will be all froze up agin. if the defrost timer does not come on after trying this then u may have a bad defrost thermostat, of course u also want to check the cold control knob and the cold control vents are working properly
Jan 14, 2015 | Refrigerators
Kenmore microwave hood combination
If you have tried to reset the microwave oven by turning the mains power off and on without success then it is likely the display is faulty.
The only way to repair is replace the control panel board. This can cost a lot of money.
See this site to give you some idea. Best to contact a repair technician and get an idea of costs.
KENMORE ELITE Microwave Range Hood Controller Parts Model 72180839500
Aug 03, 2014 | Kenmore 1.4 cu. ft. Speedcook Microwave...
1997 Ford Taurus front defrost not working
. Air won't blow out of the floor or center vents just defrost ? Do you have manual or automatic climate control ?
Air Flow Control
  • Primary control is through the function selector knob mounted on the A/C-heater function selector switch, which is part of the integrated control panel.
  • The function selector knob has the following positions: OFF, MAX A/C, A/C, PANEL, PANEL/FLOOR, FLOOR, FLOOR/DEFROST and DEFROST. The A/C-heater function selector switch combines a vacuum selector valve with an internal electrical switch.
  • The vacuum selector valve directs source vacuum to various vacuum control motors (18A318). Refer to the Vacuum Control Diagram , System Airflow Schematics and Vacuum Control Chart .
  • Two internal, single-pole electrical switches are also controlled by the A/C-heater function selector switch. The combination of these electrical switches controls the electrical supply to the A/C clutch and heater blower motor switch (18578).
  • Vacuum Control Motors The vacuum control motors (18A318):
    • are located on the A/C evaporator housing, A/C recirculation air duct and heater air plenum chamber (18471).
    • direct system airflow to the vehicle interior as determined by the remote climate control module or manual override.
    • The five-passenger seating configuration has an additional vacuum control motor mounted on the heater air plenum chamber to control airflow to the rear seat A/C register (19893).
Jul 09, 2017 | Ford Cars & Trucks
A service rep was out and replaced the refrigerator evaporator coil today and the refrigerator is working fine. However the ice maker was not making ice, due to ice build up on the back of the ice drawer...
just a thought sometimes when the defrost has been set you have to go and reset the freezer temp. it should be around zero-f ..... when you reset the freezer temp you should hear it start up. if that dont work call the service company and explain over the phone you need directions to reset or turn it back on.. and tell them if they have to come out you shouldent have to pay because the freezer was working before they came.... and you should have no problems.... the last thing they want is an unhappy customer.. atleast the good companys... good luck i hope this helps
Aug 13, 2011 | Sub-Zero 561 / F
I have a VSX-1015-TX ,I powered it on but have no control from either the remote or the receiver itself,changed remote batteries,unplugged/replugged in receiver still no control,the receiver works as all...
to complete reset, it need pressing couple buttons by combination. if all buttons mulfunction, no way to do this function. does unit have front panel display?
Mar 19, 2011 | Pioneer VSX-1015 Receiver
Changing country selection for lcd tvs
Mine has just done the same thing. I'd be interested in an answer as well.
Aug 01, 2010 | Sanyo Televison & Video
I have Jandy RS4 system with 4-button poolside controls for additional spa control. Inside house control panel stays totally lit up saying ''Rev 6700'', and cannot communicate or control pool operations. ...
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
Oct 07, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Freezer frosts up and will not defrost itself anymore. Do I need a new defrost timer and/or thermostat? If so, where is the timer/thermostat located in the refrigerator?
It could also have a bad defrost heater. The heater and defrost thermostat are located mounted on the evaporator coil and the timer is usually mounted in the control panel with the control thermostat or in the compressor compartment.
Aug 28, 2009 | Maytag Refrigerators
MAYTAG PLUS, MOD MZD2766GE STOPPED COOLING ON THE RIGHT SIDE,
After they replaced the part did they defrost the unit. there is probably ice build up on the coil behind the service panel in the freezer compartment. If the defrost control was the part replaced you can probably push the refrigerator side light switch in and out 5-6 times and force a defrost. if the unit goes into defrost then all the components are fine and you just need to manually defrost the coil either by off loading all food and leaving the unit off for 4-6 hours with doors open. of offloading freezer side remove rear access cover in freezer exosing evaporator coils and use a hairdryer to defrost the ice accumulation. good luck Peyton
Mar 06, 2009 | Maytag MSD2756G Side by Side Refrigerator
Refrigerators Logo
21 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
