Question about Panasonic Car radio CD CQ-C1110GN CD Player
CD stuck I have a panasonic cq-df401u. I left the cd in the player over night, the next day when I started the car it was playing, went to eject it and it went straight to the radio. Been that way ever since.I don't have one of those rods to manually eject it. I don't even know were to look to manually eject it if I had one.
  • 3 Answers
Lol i had that happen to me once i had to take out the stereo plug it bk in but turn it upside down and then eject it after i did that i never had a problem with it again but then again i only kept it for another month then got a new 1, good luck hope this helps
Posted on Sep 27, 2007
SOURCE:
Cd won't eject, Panasonic cq-c8300u, makes buzzing sound, door won't tilt open. thanks!
We regret to inform you this model would need repair. We recommend you use the below link to locate an authorized service center.
www.panasonic.com/repair
Apr 26, 2014 | Panasonic CQ-C8300U CD Player
It wont play cd just keeps saying e1 eject cd radio plays fine
look for areset botton if it dosent have one by a cd cleaner if after that its the same replace the radio
Jun 11, 2010 | Panasonic CQ-DFX403U CD Player
Can I connect an mp3 player to this stereo deck through the CD CHANGER IN port?
no not really. the cheapest and most easy way of doing it is to buy an fm trnsmitter most electronic shops sell them they work by sending the music into a pre tuned fm channel on the deck its a bit like a wire less input
Apr 24, 2010 | Panasonic CQ-DF401U CD Player
E1 Error on Panasonic CQ-C1110W Car CD Player
If you receive an error reading or the cd ejects automatically briefly after being inserted, the headunit needs to be repaired or replaced
Jul 01, 2008 | Panasonic CQ-VD7001U Car DVD Player
Panasonic cq-DFX444LEN
The heat is normal due to the large output IC's Panasonic uses. You need to get a "Laser Lens Cleaner" one that uses fluid. You can find them at just about any retail store these days for 15-20. Run it thru a couple times and hope that's the magic bullet to fix the issue, otherwise it needs service at a cost of 100-150 on average. If the cleaner does the trick, make it a habbit of cleaning your player every 3mos or 3000 mi. It truly is the best preventative maintanance on any CD/DVD/PC etc.! Hope this helps
Apr 04, 2008 | Panasonic CQ-DFX403U CD Player
Burnt CD Stuck Inside of Panasonic Car Stereo
Looks like you will have to dismantle the player. CDR discs are slightly thicker than commercialy made audio CD's and some times stick.
Mar 26, 2008 | Panasonic CQ-C3103U CD Player
Cd stuck in player
I realize this post is a little old , but for anyone looking for a solution try disconnecting your negative battery terminal for a minute or so then reconnect. Next try to eject your cd. Worked for me ^^
2001 taurus
Feb 13, 2008 | Car Audio & Video
Wont play cd
Is this a "home burnt" CD? The code means CD ERROR #2.It is usually because the CD was written in a format the head unit can not play.If it is a studio CD. I would contact Panasonic and find out what code # 2 means.I had a code too because of what I said before but I do not remeber the # it was.
Nov 11, 2007 | Panasonic CQ-DF903U CD Player
Panasonic CQ-DF401U
yes alll that problems exactly the same
Apr 14, 2007 | Panasonic CQ-DF401U CD Player
Panasonic Car radio CD CQ-C1110GN CD Player Logo
218 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
