Question about Transcend 4GB JetFlash 110 USB 2.0 Flash Drive (TS4GJF110) Media
Remove writeprotection Write Protected
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 71 Answers
Reformat,use HDDraw copy to copy your files and reformat the jetdrive
Posted on Oct 19, 2013
My sandisk pen drive is write protected
Remove write protection from Sandisk pen drive with write protection removal software. Double-click on the WriteProtect value in the right-hand pane of Regedit.exe. Change the Value data from 1 to 0 and click OK to save the change. Close Regedit and restart your computer.
May 12, 2018 | SanDisk Computers & Internet
How to remove write protection
To remove write protection:
Open Start Menu >> Run, type regedit and press Enter. This will open the registry editor.
Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Double click the key WriteProtect in the right pane and set the value to 0
In the Data Value Box, press OK
Exit Registry, restart your computer and then re-connect your USB pen drive to your computer.
Jan 04, 2014 | Electronics - Others
Remove disk write protected
If this is a SD card, slide over the 'Lock' switch on the side.
If a USB flash drive - try RMPrepUSB - Drive - Clear Read Only Status.
Oct 28, 2013 | Philips Electronics - Others
Device media is write protected
To disable writing access to USB drives and make all USB drives has only read-only access, follow these steps:
  1. Run Registry Editor (regedit).
  2. Navigate to the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
  3. Create a New Key named as StorageDevicePolicies.
  4. Highlight StorageDevicePolicies, and then create a New DWORD (32-bit) Value named as WriteProtect.
  5. Double click on WriteProtect, and set its value data to 1. write-protect-usb.jpg
Once set, all users on the computer is now blocked and prevented from copying, transferring or writing any files, documents and data to the USB disk drives, without the need to restart or reboot computer. Any attempt to download or copy files to USB drive will return the following error message:
The disk is write protected.
The media is write-protected.
Remove the write protection or use another disk.
usb-removable-disk-write-protected.jpg To revert and remove the blocked write access to USB drivers, just delete the StorageDevicePolicies registry key, or delete the WriteProtect registry entry, or change the value data for WriteProtect to 0.
For user who doesn't want to manually editing the registry, simply download the following registry registration files to enable or disable the write protection (block writing attempt) to USB removable drive. Double click the .reg file unpacked from the .zip archive to merge the registry key entries.
Download DisableWriteToUSB.reg
Download EnableWriteToUSB.reg
The trick works in Windows XP SP2 and SP3, Windows Vista, Windows Server 2003 and 2008.
Feb 27, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to remove write protection from pendrive?
Is the pendrive is protected in your laptop or in other laptop also? if its protected only with your laptop then follow the following steps.
  1. Go to registry, follow the path
  2. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevice Policies
  3. There you will find a key "WriteProtect", check the value.
  4. If value is '0' then OK, if '1' then make it '0'
  5. To change the value, double click at the key "WriteProtect", one manu will pop up. change the value.
Note: Be careful while working with registry.
Aug 22, 2010 | Computers & Internet
How do I remove the write protected on my Lacie 500g external drive?
Steps to make your drive Write Protected Or Remove write protected:
1. Open Registry Editor by typing regedit in Run dialog.
2. Navigate to the key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\
3. Find a sub key inside it named “StorageDevicePolicies”. If it does not exist there then we need to make it. Right click on “Control” key -> New -> Key. Name it “StorageDevicePolicies” without quotes.
4. Now right click on this newly created key and then click New -> DWORD value and name it as “WriteProtect”.
5. Modify this key and give it a value 1.
6. Click OK, and remember to restart the PC.
Now no more data can be transferred to the drive but to start using the drive again just give the “WriteProtect” key a value of 0 instead of 1 and restart the PC.
Aug 12, 2010 | LaCie (301146U) 320 GB FireWire 400...
I cant copy song in memory card its shows card is write protected
What sort of memory card is it?  can you remove it and install it in a card reader directly on your pc?  What is trhe phone?
Jan 14, 2009 | Motorola Mobility ROKR E6 Smartphone
Remove Write Protection
Try this,
1.
Check out if the USB drive has a small swich for write protection. If its there try toggling the switch.
2.
Windows can all write protect flash drives. Check out this registry path,
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
You may find a key here on the right side by the name 'WriteProtect'. If it's not there this would not be the cause of problem. If it's there, make sure that the value is 0.
Please let me know if this does'nt work.
Nov 06, 2008 | Transcend (589307) Media
How to remove write protected memory card
How to remove write protected memory card pls help me
Jun 13, 2008 | Nokia 6680 Cellular Phone
Electronics - Others Logo
42 people viewed this question
Top Transcend Electronics - Others Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
