Question about Kenwood Audio Players & Recorders
Connecting ps3 receiver
How can i connect my Kenwood KRF-V5200d to my ps3 i have a HDMI cable going from the ps3 to the tv the tv is a tcl
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 71 Answers
Buy a optical cable and connect between PS to the amplifier or take the optical out from the TCL to the amplifier and select optical in,
Posted on Oct 19, 2013
The Machine
  • 788 Answers
SOURCE: How to Connect HDMI Components with AVR 3805 as Hub
In reference to the comment you added to our chat session:
Just connect your receiver to your TV using the same cable your receiver is currently using to connect to your TV, be it Composite, S-Video, or Component. Just switch your TV to that input when you need to set-up something on the receiver.
Posted on Jul 09, 2008
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
DickCanFixIt
  • 948 Answers
SOURCE: I'd like to connect my HP laptop to Yamaha 663 receiver
Connect your S-video output from the computer to an empty S-video input on the receiver. Connect your speaker output from computer to analog audio input on the receiver using a 1/8" stereo connector to RCA patch cable. You may have to set your computer to output video to the S-video jack, consult your HP documentation for instructions.
Posted on Dec 29, 2008
  • 6 Answers
SOURCE: PS3 connection to Yamaha HTR-6130 Av Receiver
URNOTME is right. HDMI is great and all, but wish i would have spent a few more dollars on a unit that supports switching. htr-6130 does pass-through, so you have to use seperate audio connections. really there is no use running HDMI into the receiver and then into the receiver and THEN to the tv. just go straight to the tv, then run your audio either optical (best) or coaxial.
Posted on Jan 23, 2009
SOURCE: Sony strdh500 will not recognize sony ps3
your hdmi port doesnt carry audio to all speakers what is perfectly normal for low end receiver, hdmi pass through audio only
Posted on Dec 28, 2009
I NEED A manual for a krf v5200d
  • Hope this helps.
Nov 02, 2011 | Kenwood KRF-V5060D Receiver
How do you connect a tv to my kenwood krf-v555od surround receiver
there are two ways using rca cables and using fibre optixs it depends what sort of audio out you have on your tv it will either have rca or digital choose witch one to use and go from there
Jun 19, 2010 | Televison & Video
How do I connect my Sony PS3 with HDMI and component sound with Kenwood VR-606
Component outputs do not provide sound. Component CABLES however can be used as a rather equal alternative to analog cables for audio.
Your receiver does not have connections for component, nor HDMI. You can however still connect your PS3 to it for audio by any one of its three digital inputs. It only has S-video and does not upconvert video signals so I recommend against making any video connections to it. Connect the PS3 video directly to your television for whichever video input it is compatible with High definition video. This method will always provide the best picture.
Dec 12, 2009 | Kenwood VR-606 Receiver
Music, sound effects no dialogue
MAKE SURE YOU HAVE ALL THE AUDIO SELECTIONS ON UR PS3 CHECK THE BOXES ,,IN THE AUDIO SETUP
May 14, 2009 | Kenwood KRF-V5060D Receiver
Best way to hook up all my componets
The best way to use the Denon and get your money's worth is to connect all devices to the Denon using HDMI connects if possible, if you use HDMI make sure you assign the audio if needed.
HDMI from Denon to TV. the Denon will upconvert all signals to HDMI to the TV
Jan 29, 2009 | Denon AVR588 Receiver
I have a brand new kenwood krf-v5200d amp. when I turned it on the first time it when't straight to the standby light blinking. I have checked all speakers and they are connect correctly. Any idears
#1 check the batteries in your remote,#2 if this is a new system contact the the dealer(let them handle it)i'm sure they will make it right.(what i'm saying,is don't void your warranty buy trying to fix it your self.enough said!thanx for using fix-ya!!!
Nov 29, 2008 | Kenwood Audio Players & Recorders
Connecting PS3 to receiver via HDMI
First put the orginal ps3 cable onto ps3 then to tv.set tv to see ps3 and go to ps3 setup,now down to display settings,set to hdmi,picture will go off so now switch tv to hdmi input .Next go to sound settings for ps3 and set to hdmi if your amp can work this way ,if not set sound out to optical.
hope this helps.
CABLE GUY.
Jun 24, 2008 | Onkyo HT-SR800 System
Install ps3 on avr-4306
PLUG THE STANDARD PS3 CABLE INTO PS3 THEN TO TV GO TO SET MENU FOR PS3 AND SET VIDEO OUT TO HDMI,PICTURE WILL GO OFF SO BE QUICK AND PUT HDMI CABLE INTO PS3 THEN TV,NOW SET AUDIO OUT PUT TO HDMI,THEN CONNECT TO AMP,IF YOU STILL GET NOTHING CHECK AMP SETTINGS IE INPUT SELECTION FOR HDMI.
HOPE THIS HELPS.
CABLE GUY.
Jun 18, 2008 | Denon AVR-4306 Receiver
Increase AM bandwidth to 531khz to 1700khz
ya am booster antenna of the am output u could try 1st or u saying teh kenwood limites u to 1620 max only ch >
Jan 23, 2008 | Kenwood KRF-V5060D Receiver
57 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
