I have a bush A126Q washing machine which I have had one day & the start button has jammed. Does anyone know how to un-jam it or get front panel off? Thanks
    Master:
  • 818 Answers
If this is a new machine I'd advise you to contact the company-you may viod the warranty by trying to fix it yourself-cheers Denny
Posted on Oct 19, 2013
  • 15 Answers
SOURCE: Door jammed
take the top off the machine,put your hand down to the reigon of the door lock and by using a small screw driver the catch on the door can be forced open without doing any damage.
Posted on Jul 19, 2007
  • 177 Answers
SOURCE: 2 problems with speed queen washing machine
The motor is not starting this is the humming noise not a good sound, try it in spin to see if the motor runs in this direction. You may have a motor issue because of the water leaking on the motor?
Now that you have the front panel removed you can look for leaks, you will need a flash lite, start a cycle on the small setting and look for where the water is coming from. If it is coming from the center of the tub above an aluminum case which is the transmission you need a tub seal, if the water is coming from somewhere else it could be a pump, or hose, or ?
Posted on Jul 16, 2008
SOURCE: FRONT LOADER DOOR LOCK WONT OPEN OR JAMMED
On a Bosch wfmc3200uc there is a green plastic string, similar to fishing line, located behind the round panel on the front of the machine. It is attached to the top right of the round black piece. Just give a slight tug this will release the lock.
Posted on Oct 21, 2008
barkencoa
  • 3463 Answers
SOURCE: Hotpoint WMA34 washing machine
Remove top cover, 2 screws are hidden behind 2 plastic covers at front of lid, push the lid back to remove , undo the screws that hold the dispenser, and slide the console panel to the right, then you can access the control board and reset the button,
Posted on Jan 04, 2009
  • 6277 Answers
SOURCE: i have a beko washing
Are they actually 'jammed on' or are they just lit?
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 04, 2011
How do I remove the front bottom panel of my bush a126q washing machine.
its a click off i would look at the user manual
ive checked and its easy got on google
its a click off afair
all else fails read the manual ....??
i use an eating knifes like taking off a tyre
so as to subdue the strains
jam em in lift it out
too lift out the plastic tongs..
Dec 23, 2014 | Washing Machines
Reset switch Bush A146Q
MY ON/PAUSE BUTTON IS BROKEN ON A126Q /A146Q model. i do not want to have to buy a new machine, where can i get this part?
many thanks,
Jul 29, 2012 | Washing Machines
My bush washing model no:a126q will not start
Check that the washer supply is OK using another item - a kettle for instance. If it's not check your breakers/fuses. Reset/replace if necessary and if the same thing happens, or if there was nothing wrong with the breakers/fuses in the first place, sorry but with such a fault it is impossible for anybody on this forum to remotely guess what could be wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
John C
Sep 15, 2011 | Washing Machines
The start button is stuck...cannot get the front piece off to see why my button is jammed in there. can the front piece be reoved without taking the door off?
You have not mentioned the make and model but in most cases the front panel can be removed only after the sides are taken off.
Please check the visuals in the link below:
http://www.espares.co.uk/advice/washing-machines/a/7
Aug 18, 2011 | Washing Machines
What would stop a bush a126q washing machine draining, it just stops in the middle of a wash cycle?
hi i have a BUSH A126Q model W/M .Spin and Drain dosnt work. I clean the FILTER but same problem. Error code is Err 03. The start light & program ready light is blinking when M/C go to spin / Drain.
Its looks pump dont work //////
Please advise me what to do ???????????
Thanks
Mar 19, 2011 | Washing Machines
How do I open the door to my Bush a126q washing machine after a quick wash?
Reset it back to the spin cycle and try to empty some more water out of it. It should release the door when it knows it is empty.
Dec 05, 2010 | Washing Machines
Bush A126Q White and the ''end of programme'' light is staying on
Sorry Jo, I think I may have mis-understood your explanation - is there actually a problem with the machine functioning properly or is it simply that the end of cycle light will not turn off?
If it is the latter then simply turn the dial back to 0 before opening the door from the previous wash, this action tells the washing machine to reset itself as the drum is about to be emptied.
I have the exact machine however as it is graded, it didn't come with any manuals, at the end of the wash I just figured thta this was what I needed to do.
Its almost as if you need to double-declutch the washing machine - return the macine to 0 before selecting another cycle.
Feb 03, 2010 | Washing Machines
The rinse is flashing and cannot get the start button to operate
I had this problem, Un plug machine, I took the filter cover off (flap/door at bottom right of machine, then undo the round filter cover,turn anti clockwise) impeller was jammed (2 nails out of someones pocket!) freed impeller (should turn with finger) once free,put cover back on and away it went!. Hope this might help. John.
Oct 05, 2008 | Bosch Classixx WFO 2466 Front Load Washer
Oct 05, 2008 | Washing Machines
Door jammed
Jul 24, 2006 | Indesit W 123 Front Load Washer
Washing Machines Logo
269 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
