Question about Health & Beauty
Rascal 260le soooo, kinda took the rascal to a show and it rained really heavily on the way home and now it wont work. yeah i know i should have covered it up but the lights and the horn work it just does not go back and forth. let it dry out without plugging it in for two days and then checked and replaced both fuses and reset the circuit breaker but no dice. So what do I do next or how do i have it fixed? bought it used off someone else.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 105 Answers
Ouch, will u may need a new joystick or controller,please have a tech with a progamer to check your error log first so u know what to buy ok will be a lot cheaper
Posted on Jan 20, 2014
4 Suggested Answers
HoverTech
  • 232 Answers
SOURCE: Just purchased it used. Both battries show
If the horn won't work, the batteries are dead. If the charger is showing green lights, most likely the gel inside the batteries has gone solid from the chair being stored for a while. Replace both batteries with type U1, 24v, 33 amps and see if that will clear the problem. The fuses are regular automotive type fuses.
Posted on Oct 05, 2010
  • 692 Answers
SOURCE: Plugged the chair into 220v electricity supply. i
WOW!! Big OOPS huh? You probably blew the charger with that jolt. Does your joystick come on at all? Since the charger is connected to the controller or Power Module I hope you didn't blow that up. If you have a digital voltmeter you can set it to 200 volts dc and plug the leads into the 2 outter holes of the charger port located under the front of the joystick. You should read the battery voltage ot 24 - 30 volts. If you don't get anything at the joystick then you will have to remove the seat to get access to the batteries and check the fuses located on the positive posts of each battery. If those are not blown and you still don't have power to the joystick then I'm afraid you blew the controller cause there's no fuse for it. Sorry but if Medicare paid for your chair then you can call a repair service like Roadrunner Mobility @ 1-800-467-2668 or Repair Xpress @ 1-877-581-3733 to have them fix it for you. I might not mention that you plugged into 220 volts tho. Hope this helps
Posted on Nov 07, 2010
  • 692 Answers
SOURCE: No power , no lights on controler. Had battery
Check on the utility tray where your charger cord plugs into the rear of the chair it should be on the far left side of the tray near the amp meter Hope this helps
Posted on May 24, 2011
Testimonial: "Thanks for the help, but the problem was the controler buttons not closing the circuit. Thanks"
Scooter has compression new spark plug new gas and fully charged battery but still wont start
ok first you sed you took spark plug out an checked for spark so the next thing is to look for coil cause some times it can get some rust or many other things but take flywill off an take a small strip pf fine sand paper dut works the best is a womans fingernail file strip off the fine side of one an run it accurse the top of the coil it should have a small tip on it kinda looks like a battery the positive has that little round tip but do not file it to much just so you can see clean meatl then leave the cap that covers the flywill off just so you wont have to go through takeing it off again seconed thing if that dosent work check your spark plug wire oh an when you take the flywill off sand the inside if it an the outer as well hope I helped yeah an if you would like you can call me at 1 417 818 4091
Apr 09, 2015 | GAS Motorcycles
Wont rev and smokes heavily
take it back to engine reconditioner and ask them to fix
Mar 03, 2014 | Motorcycles
2001 Dodge Dakota randomly wont start
you may want to go to a parts place and have them plug one of those meters for a check engine light in the port and see if a code will come up .
Dec 31, 2013 | Cars & Trucks
Fills with water, not agitating
They probably dropped it a good one and jarred the computer. The bump bump bump down the steps into the basement. Hmmm rain on electrical components , if they used it right away and didn't give it a chance to dry out, yeah that might cause shorting across the board. The mechanisms are electronic now and not mechanical like the good old days (My uncle worked for Kelvinator and had old pieces laying around). What about overloading it? Are they overloading it? They've lifted up the cover and peeked at it and saw that it's not agitating? Are they incompetent? So many variables.
Jul 09, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Cant seem to put the rain cover on...
Does it connect to the frame?If so the frame may be bent..or try to but another rain cover,I'm sorry that i couldnt help you more.
Apr 02, 2012 | Baby Gear
I NEED A TECHINCAL MANUAL FOR THE CONTROL BOX PLC FOR A RASCAL 260LE. I MAY GO INTO THE REPAIR BUSINESS
Reginainc If you are interested in repair contact Scott C at Repair Xpress at 1-877-581-3733
Jan 26, 2011 | Universal Health & Beauty
Wont start or do anything..
SOUND LIKE IGNITION COMPONENTS GOT DAMP WHEN IT RAINED.
May 04, 2010 | 1999 Volkswagen Passat
I need the part number for the fuel line. It is a
Click on this link below to go to the Poulan parts store. I have it on the page for your item showing both your fuel lines. Just copy and paste into your browser.
http://www.partstore.com/Model/Electrolux/Poulan/260LE.aspx
I have found that you can get the same line at a automotive store. Just take the old line in and they can match it up to another line for you. This way you don't have to pay for shipping or wait on the part. Hope this helps, let me know if I can help you with anything else.
JimmyC
Oct 03, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Phone problems
i believe it has a warraty. so go to the service center of the phone so they can fix it.tnx
Jul 28, 2009 | Cell Phones
Health & Beauty Logo
65 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
