Question about Hifonics Zeus Z1000D Car Audio Amplifier
When i turn on my amplifier the protection signal is on,some people said that the protection circuit is in bad conditions,but i can not find it in Mexico,it is the real problem or i could check another item in my amplifier,sorry for my english i'm from Mexico
Maybe you have defective speaker! try to cut out your speaker from the amplifier then you power on again! if the protection is in again you have defective power output! transistors or mosfet transistors.
Posted on Sep 27, 2007
Aug 26, 2015 | Sony Audio Players & Recorders
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be with your output drivers. Please check for short on the outputs fitted for both the channels. Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise which can be a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board. Maybe the protect circuit by itself is shutting off due to a faulty bias or there is a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the amplifier comes out of the protect mode then check for short on the speakers.
Mar 14, 2012 | Onkyo Audio Players & Recorders
Jan 23, 2012 | NAD M3 Master Series Integrated...
Nov 29, 2011 | Audio Players & Recorders
It is not so easy to probe into to find a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
Jun 25, 2011 | Crest Audio CA 6 Amplifier
Mar 30, 2011 | Audio Players & Recorders
Feb 28, 2010 | Teac A-H300 Amplifier
Jan 11, 2010 | Clarion APX1300 Subwoofer Mono Amp - 300W...
Sep 03, 2009 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
Apr 08, 2009 | RCA F31672ET TV
181 people viewed this question
I HAVE A Z1000D AMP MY PROBLEM IS THE AMP TURN ON BLOW A FUSE BUT I DOT PUT ANY SPEAKER ON THE AMP JUST POWER
