Question about Dishwashers
Reset dishwasher candy cdi1012
I have 4 led,s staying on they are accompanied by constant beeps until I close the door when the beeps stop after a short period and then there is a whirring sound which I presume is the pre wash pump action can anyone help?
  • 19 Answers
SOURCE: cycle will not start
sounds like your machine is not taking in any water at all, which is the first thing the dishwasher wants to do on all programme settings.The constant whirring noise you refer to will be the water valve trying to take water into your machine.As yours isn't filling in the first place the programme cannot progress without water and it will just sit there whirring.Anyway, to resolve this matter I would check the fill hose which goes from the back of machine to your cold water pipe in your kitchen/utility, in case somebody has turned off supply.where the flexi hose meets the copper supply pipe there should be a thumbturn shut/open valve, turn this 90 degrees or a quarter turn and if you here a rush of water for a split second then you have fixed it.At this point try setting away a programme to see if water is going into dishwasher. If not have a bucket ready and unscrew the flexi hose altogether to make sure water is travelling past shut/open valve.If not you need a new shut/open valve.If water is able to pass this valve reconnect to dishwasher turn shut/open valve a quarter turn to open flow of water again,test machine on any programme again ,if it fills then your sorted, if not it must be your dishwashers internal water valve that will need replacing.Not a major job (located behind fill hose) but make sure electric and water supplies are off first before dabbling and write down your machines make and model number before shopping for part. GOOD LUCK.
Posted on Aug 15, 2007
SOURCE: hotpoint dc28 dishwasher
standing water inside washer
Posted on Dec 10, 2007
eagle338
  • 4889 Answers
SOURCE: Diplomat intergrated dishwasher error code FA
FA is a problem with the tubidity sensor. By holding down the power button, it stops, but just repeats everytime you try a new wash cycle. So keep doing it and you can atleast use it. If you want to go one step further and find a permanent solution try feeling around in the sump (where the filter slots in) being careful for any broken glass. Other than that it will probably be a strip-down job to examine the internal hoses and the pump; not a DIY job to be honest.
Posted on Feb 03, 2008
SOURCE: CDA CW 446 dishwasher problem
The clean light sometimes flashes and just needs to be reset. To do so hit the keys in the following order. <Heated Dry> <Normal Wash> <Heated Dry> <Normal Wash> <Cancel>.
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again.
Posted on Sep 02, 2008
  • 4 Answers
SOURCE: Candy dishwasher CDl 1012/2-80, program stuck?
Hi Derek if its only been used about as you say ten times it will stil be under gaurantee,just call the supplier and have them solve the problem for you mate it sounds as if the program selector is faulty as it is all eletronic programming and could even be a faulty circuit board.
hope this helps
regards JL
Posted on Oct 04, 2009
How can I reset our dishwasher
Open the dishwasher door sufficiently to see the control buttons, then hold the two buttons with labels "Cancel Drain" and press for 3 seconds.
Close the door. Wait nearly 1 minute for the dishwasher to complete the cycle.
Open the door and hold the "ON/OFF" toggle.
Reset Bosch Ascenta Dishwashers
Shut off the child lock if needed by pressing and holding "Open the door far enough to see the keys, then hold the "START RESET" toggle until the "ACTIVE" LED become extinguished. On the SHE5AM model of Bosch Dishwashers, hold the "START RESET" key until the display clock shows "0:01".
Close the door and rest about 60 seconds. On the SHE5AM, wait until the display clock displays "0:00".
Apr 06, 2016 | Bosch SHE4AP06UC Dishwasher
Beeping won't stop at end of cycle
Our Bosch does the same thing, we just open the door shut of the power and close the door again so the heat can sanitize the dishes. I don't recall if there is an alert off button though.
Jan 08, 2014 | Bosch SHU9926UC Built-in Dishwasher
ADL348 is constantly beeping and does not complete cycle
If it beeps continuous and starts on the rinse cycle,then this is indicating the control board is bad and needs to be replaced. NOT THE TOUCH PAD, but the control board.
Dec 17, 2013 | Dishwashers
Candy Futura CDF 325 beeping alarm
Is there a sequence to the beeps?
Jun 04, 2013 | Candy Dishwashers
Jeep and consistant beeping
there are sensor switches on the doors, open one of them and look at the side of the vehicle where the lock is that holds the door close, you will notice a small rubber push button there ,, when you press it,, it closes in turning off the door lights and letting the car know the door is closed.. One of those one the doors is shorting out, by a broken wire or a stuck sensor,, you need to take them out and check the wires connecting them, or play with them by pushing them in and out rapidly until the beeping stops.
Dec 30, 2012 | 2000 Jeep Grand Cherokee
I have a samsung side by side fridge freezer model SRS539HW, the alarm keeps beeping every minute to say the doors are open however they are closed. If I manually pust the door closer button it will...
Solved beeping problem.........Samsung SRS539HW . Have one of these and it is 6 years old. I had to replace the bottom hinge on the fridge side(right). Easy job but now constant beeping as if door is open, and light is intermittent. Found that there is considerable wear on the cable through top hinge of door and one of the wires from a magnetic reed switch in door had broken. I discovered this by shorting the two fine wires (white and pink/white) going to internals of fridge.No more beeping due to door opening and light now working correctly. Of course I no longer get a beep for a valid door open to long but cheaper than getting a refridgerator expert in.
Jan 13, 2012 | Refrigerators
Red service light is on,yet still is operable with intermittent beeping?
The only information I can find.
RED LED: An error has been detected and the BBU will automatically shut off. The BBU will attempt to restart by reconnecting to the batteries. If the error is still present it will shut itself off again. This process will repeat every 5 minutes or until the error has been resolved. This is used to prevent further draining of the batteries. If a red LED remains on when the power is restored, and is accompanied by a beep sounding every 30 seconds, please call for service.
Dec 24, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a Frigidaire Beverage Center Model FFBC46F5LS It was installed on Friday and worked fine until today (Sunday) where it has started to beep constantly. If I press the light button at the bottom of...
I recently purchased a Frigidaire Beverage Center and had the same constant beeping issue as strivieri. I found my problem to be the door sensor. The door sensor is located on the lower bottom right of the unit and there is a metal plate mounted on the swinging door that is suppose to push that sensor in when the door is closed. However, this was poorly designed as it fails to do its task. I had a few adhesive floor protectors laying around that I used to stick to that metal plate that gave it the extra thickness needed to push in the door sensor when closing the door.
I hope this helps anyone else there having the same issue.
Nov 14, 2010 | Frigidaire FFBC46F5LS
Opener beeps
This is battery related. On top of your unit is a battery pack with three colored led lights. You can tell what is going on by looking at these. This information is in your manual or here it is.
GREEN LED: All systems are normal. A solid LED light indicates the batteries are fully charged. A flashing LED indicates the batteries are being charged. NOTE: Batteries do not have to be fully charged to operate the motor unit. YELLOW LED: The motor unit has lost power and is operating off of the BBU. A solid LED with beep, sounding approximately every 2 seconds, indicates the motor unit is activating the door and is operating off of the BBU. A flashing LED with beep, sounding every 30 seconds, indicates batteries are low. Once the power is restored the BBU will recharge. This is indicated by a flashing green LED. RED LED: An error has been detected and the BBU will automatically shut off. The BBU will attempt to restart by reconnecting to the batteries. If the error is still present it will shut itself off again. This process will repeat every 5 minutes or until the error has been resolved. This is used to prevent further draining of the batteries. If a red LED remains on when the power is restored, and is accompanied by a beep sounding every 30 seconds, please call for service.
Nov 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Dishwashers Logo
56 people viewed this question
Top Dishwashers Experts
