Question about Frigidaire Affinity ATF7000E Front Load Washer
Frigidaire Affinity ATF7000FS0 Front Load Washer is not completing the cycle. It seems to not be rinsing or adding fabric softener. Also, when I place it on the spin only cycle but extra rinse, it will start and lock but then a few seconds later unlock and stop. And when just placed on spin cycle it will work fine. Drains during this cycle also.. but during a regular cycle it will not drain sometimes. Is this the motor control board or the cold water? Please help...
duby1990
  • 370 Answers
SOURCE: I have a Frigidaire Gallery
It can be be your speed control unit. It also can be your door switch. Even though it locks there is still another switch inside that sometimes fails. That is your cheapest way to start and a lot of times that fixes it. If not replace the speed control unit.
Posted on Nov 18, 2008
SOURCE: Frigidaire front load washer not spinning
Unsrew the bottom panel and u will find the pump to the right disconnect the hose from the back thats coming down from the tub.You will find a pocket behind the hose connect filled with all kinds of change probably enough to buy a pizza and a couple of beers. I also had a old credit card,gas pass bobby pins,hard plastic tags.chains and a hand full of sand.
My Frigidaire frontloader is 9 yrs old was close to buying a new one but this defintly fixed the problem..
works like new again.
Posted on Dec 19, 2008
SOURCE: ATF6000ES front load washer won't spin during regular cycle.
clogged filter will cause this error code. I have the same washer and the filter located inside the rubber boot attached to the pump was full of junk. there was enough room for water to get thru but not enough for full volume. clean it out and it should work. note : its a pain to get the boot back on so be ready and take it slow. this worked for me.
Posted on Aug 30, 2009
beltronic205
  • 1474 Answers
SOURCE: fabric softener will not drain
Try cleaning out ..this should cure . the other thing that can cause this is a faulty solonoid valve as some machines have a seperate valve for this action....
Posted on Nov 25, 2009
blueextc3221
  • 15935 Answers
SOURCE: Frigidaire front loader washing machine won't spin...
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
Posted on Oct 01, 2010
Fabric softener not dispensing on Frigidaire Affinity ATF7000E
Hi sotickledpin - The softener requires two valves to open to dispense: the bleach valve and the wash valve. If one fails, it will not fill the softener compartment. If there isn't any cold water supplied to the unit, it will not rinse the softener. Possibly the washer may have a faulty water valve or an incorrect water supply to the unit. Also, if the softener dispenser cap is not installed properly, that can cause it to not rinse out as well. Because it could be a number of any one of several underlying causes, I personally recommend contacting a professional to properly diagnose and repair the unit.
Mar 17, 2013 | Frigidaire Affinity ATF7000E Front Load...
Bleach and Fabric Softner Dispenser
Hi
This is a result of the siphoning action and is part of the normal operation of the washer. Water
may be removed by removing the dispenser drawer and draining
water into the empty drum or sink.
Outside
• When washing is completed, wipe top and sides of washer with a damp cloth. Turn water
faucets off to prevent pressure build-up in the hoses.
• As needed, clean the cabinet with mild soap and water. Never use harsh, gritty or
abrasive cleansers. If door or console becomes stained, clean with diluted chlorine bleach
[1/2 cup (120 ml) in 1 quart (.95 L) water]. Rinse several times with clear water.
• Remove glue residue from tape or labels with a mixture of warm water and mild detergent.
Or, touch residue with the sticky side of the tape or label.
• Before moving the washer, place a strip of cardboard or thin fiberboard under the front
leveling legs to prevent floor damage.
Cleaning the Dispenser Drawer Area
Detergent and fabric softener may build up in the dispenser drawer. Residue should be removed
once or twice a month.
• Remove the drawer by pulling the drawer out until it stops. (Figure 1)
• Reach back into the left rear corner of the drawer cavity and press down firmly on the lock
tab (left rear portion of the drawer). Pull out the drawer. (Figure 2)
• Remove the insert from the bleach and fabric softener compartments. (Figure 3)
• Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders
and liquids. Large amounts of fabric softener residue may indicate improper dilution or
more frequent cleaning is required.
• To clean the drawer opening, use a small brush to clean the recess. Remove all residue
from the upper and lower parts of the recess. (Figure 4)
• Replace the insert pressing the "X" to lock it in place. Return the dispenser drawer.
Inside
• Remove items from the washer as soon as the cycle ends. Excess wrinkling, color transfer,
and odors may develop in items left in the washer.
• Before cleaning the washer interior, unplug the electrical power cord to avoid electrical
shock hazards.
• Dry around the washer door opening, flexible gasket, and door glass. These areas should
always be clean to ensure a water tight seal.
• When extremely soiled items have been washed, a dirty residue may remain on the drum.
Remove this by wiping the drum with a nonabrasive household cleanser. Rinse thoroughly
with water.
• Periodically, wipe dry the bottom of the flexible gasket to remove lint and other debris.
• The plastic drum vanes may become stained from fabric dye. Clean these parts with a
nonabrasive household cleanser. This prevents dye transfer to future loads.
try this out for more ref check the operations mannual page 7
Dec 07, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Fabric softener premature release
In my case it was simply a matter of cleaning the nozzles that spray the water into the MAIN DETERGENT compartment. Turns our that when the washer was filling up, some nozzles were partially clogged and were directing water to the side where the softener compartment was, causing the fluid level to rise and therefore releasing the softener early. The washer was NOT spraying water in the softener side, what happens is that the dispenser tray is configured in a way that when the fluid reaches a certain max level in the softener/bleach trays, it completely drains. A way to test for this problem would be to completely dry the softener tray and start the wash cycle like you normally would (including detergent), only without adding any softener to the tray and see if after filling there is any water in the softener tray, this would prove that the water is coming from the other side.
Apr 13, 2012 | Whirlpool GHW9400 Front Load Washer
I would like to know what laundry detergent and softner to use in my front load, and the right amount to use. I buy the H E products and some of them are really sudsy in the wash sink and I have this awful...
You should use HE detergent following the directions for that detergent. You can add liquid fabric softener. Make sure to fill the appropriate compartment to the Min line if you are doing a small load.
I've never used a washer that drained into a sink (always had a stand pipe). However, I suspect that the gummy residue is the excess softener that was removed in the rinse cycle. Try rinsing the sink with hot water after a laundry. This is part of the procedure to clean the inserts and detergent/bleach/fabric softener drawer when you get a build up in the drawer. In the future, use less fabric softener in the washer. Alternately, skip the fabric softener in the washer but use a dryer fabric softener.
The manuals for most Frigidaire appliances are available from http://www.frigidaire.com/manuals .
The direct link for the manual (in English) for the is: http://manuals.frigidaire.com/prodinfo_pdf/Webster/134609000een.pdf .
I hope this helps.
Jun 05, 2011 | Frigidaire ATF6000ES Front Load Washer
The fabric softener dispenser is not emptying after the cycle has completed.
When cleaning the softener chamber, make sure you remove and clean the syphon tube thoroughly.
This is the only chamber designed to handle liquid. Otherwise, check that you have sufficient water pressure and that the cold valve opens fully. If you dont hear a decent gush of water during the rinse cycle, it's either pressure or the valve.
Mar 21, 2011 | Frigidaire Affinity ATF7000E Front Load...
Why do I have water in the fabric softner dispenser after the cycle is completed.
because the way the washer adds the softener is to spray water thru the dispenser. If your washer is not 100% level a small amt of water will stay in the dispenser
Dec 30, 2010 | Frigidaire Affinity ATF7000E Front Load...
How to use fabric softener
On this machine the compartment is built to hold your softener until it is time to be dispensed. So put in your softener (and bleach if you are using it) at the beginning of the load when you are adding your detergent. The washer will flush the fabric softener cup during the rinse fill to make sure it comes in at the right time for you.
Hope this answers your question!
Jul 04, 2010 | Frigidaire ATF6000ES Front Load Washer
Fabric softener will not drain
Nov 25, 2009 | Frigidaire Affinity ATF7000E Front Load...
Fabric softener doesn't empty during wash. I use he softener, and don't overfill the basin. The washing machine completes the cycle, but the softener doesn't empty.
my son had this same problem and when we took the dispenser out and checked the hoses they were clogged with semi hardened fabric softener that didn't pass through. they always used a warm wash with a cold rinse and since i told them to use a hot water wash with a cold rinse at least once a month they have not had a problem. hope this helps.
Oct 14, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Fabric softener dispenser
remove top of machine, there is a arm running across from programe dail, to drawer despenser,its spring loaded it determines which compartment the water gos into,check it
Nov 13, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
41 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
