Question about Rubbermaid Pelouze 4010-88 150 lb. Digital Receiving Scale with Remote Display FG401088
Pelouze 4010-88 Digital Receiving Scale How to use
Pelouze 4010-88 Digital Receiving Scale How to use stay on mode
How to calibrate rubbermaid 4010-88 digital scale
Pressing the ZERO button will set the display to zero.
Here is the Spec Sheet
http://www.rubbermaidcommercial.com/rcp/products/detail.jsp?rcpNum=4010-88
If you think it is no longer accurate you would have to get an engineer in to reset it. Here is the Calibration Certificate.
http://www.rubbermaidcommercial.com/rcp/ObjectServer?table=PDFs&id=660
Dec 29, 2015 | Rubbermaid Pelouze 4010-88 150 lb. Digital...
Envelope postal scales by pelouse
go to a tobacco shop or a tobacco pipe shop"head shop",or ebay, Vintage Pocket Hand Held Postal Scale 0 2oz ,or here, Postal Scales Hand Held Scales , or, Items found similar to Hand held pocket postal scale keychain 100 grams... good luck,most staples will not sell them because they are commonly used to weigh drugs.
May 21, 2014 | RTO Pelouze Scale With Remote Display -...
Fix my pelouze fs6 scale
Based on its appearance I'm guessing that you need to unplug it and open it up. Clean it as well as you can with a stiff brush and an electronics safe cleaner. Roaches are the most likely cause of your scales failure!
All the above may be fruitless, it may not be possible or worth the cost to repair.
Time for a new scale! You must keep it clean and turn it off and disconnect it when you aren't using it. Roaches like warm damp dirty places!
Apr 03, 2014 | Health & Beauty
I need user manual for the Pelouze Model PE5 postal scale capacity 5 lbs?
If i were you i would try to search for it on google or look on their website.
Oct 19, 2013 | Computers & Internet
How to calibrate a Pelouze model 4010 scale with a
when i turn on my 4010.the screen display shows 4010 but thats all it does.any solution.
Jul 08, 2009 | RTO Pelouze Scale With Remote Display -...
I need to download the new postal rate on the scale, but I have no user manual or connector. Please let me know how to go about doing this.
Here is the answer on the Pelouze web-site you can also download a manual here. They have all of the software you need to get the rate change installed.
https://global.dymo.com/enUS/RNW/RNW.html?pg=std_adp.php&p_faqid=650
May 12, 2009 | Office Equipment & Supplies
PELOUZE 4010 SCALE READOUT FAILED
my pelouse when i turn it on it stays on 0.0 when i put weight on it stays on 0.0 it then goes of i need help to get it to work
Jan 28, 2009 | Office Equipment & Supplies
Rubbermaid Pelouze 4010-88 150 lb. Digital Receiving Scale with Remote Display FG401088 Logo
54 people viewed this question
Top Rubbermaid Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Rubbermaid Office Equipment and Supply Expert? Answer questions, earn points and help others
