Question about Corinex AV200 Powerline Ethernet Wall Mount - Dual Pack (CXPAV200WME2) Network Adapter
Poweline devices won't synch
My corinex powerline devices won't sync. Have followed all instructions and one is set to AP and the other EP, but still won't work.
Comtrend powerline adapter
are you saying the connection between the two powerline devices is dropping? try moving the wireless adapter to a power outlet a little closer to the base router, they might be just a little too far away from each other right now. even though it worked for a long time, the device might be getting interference from some other electrical device on the line which causes it to act up.
Dec 14, 2013 | Edimax HP-2002NCK 200MBps Powerline...
Futher sync issue
Did you try doing a hard reset to the device
Jun 05, 2008 | LG KE800 Smartphone
I have a pair of Comtrend 8902 which have been working well for a couple of years. However, as of last Saturday, the AP LEDs are all flashing red. Holding down the standby button does stop the flashing,...
I don't have those particular ones, but I have added more units to an existing pair of powerline adaptors. They are not paired, but simply configured onto the network you have set up. Once you have the initial pair set up it should be possible to add as many others individually as you need.
hope ths helps...
May 16, 2011 | Computers & Internet
The middle ight keeps blinking and it wont work how do i fix it
Blinking middle light indicates an issue with the powerline used between the powerline adapters. To isolate the issue plug both the poweline adapters in the same room and check the lights on them. If they work fine in the same room then the issue is with the powerline. You may have circuit breaker, surge protector between the powerline adapters and that will prevent you to get a connection.
Hope this helps.
Regards
Anand
Mar 12, 2010 | NetGear XE102 Powerline Ethernet Adapter...
Data communication problems accross my WLAN Bridge
The first step here is to identify exactly what portion of the link is the culprit. Clearly you must have some sort of AP in the remote building for the handheld devices to connect to, since the bridge radio won't perform that function. So I would attach an AP of that type directly to the ProCurve and see if the problem is present or absent when you try to sync devices using that AP without any involvement by the Engenius units at all. If you isolate the behavior to the Engenius units, you may have to play with the Data Rate and Fragment Threshold settings.
May 11, 2009 | EnGenius EOC-3220 (EOC3220)
How do I synch outlook 2003 with iphone
You didn't say whether you're trying to sync everything (mail, calendars, contacts) or just some things or one thing (like contacts only). I don't know if you're using an Exchange server or even if you have the info you'll need to sync with an Exchange server.
I have a Windows mobile device (AT&T Tilt) running Outlook 2007 and everything is sync'd. We also started purchasing the iphone for our employees and sync their email, calendar and contacts to their phone.
I could probably give you step-by-step information (based on how I do this for my users at work) if I knew whether you'll use iTunes to do this or Exchange Active Sync and what you want to sync between your phone and outlook. One method (iTunes) will only update your data between Otulook and the phone when you connect it to the computer with Outlook configured on it but, the way we do it at work, they receive email, data, changes, etc in real time.
Try using this link http://www.apple.com/support/iphone/mail/
What you will find here is support topics and instructions for Exchange Active Sync, setting up email accounts, troubleshooting for contact and calendar syncing.
You can also search support on Apple's Web site. Entering the keywords: iphone outlook 2003 will bring up a lot of support info.
You can use iTunes or MobileMe for synchronization. If using iTunes then try this:
You can configure which items are synchronized during a one time set up process. After initial set up, each time you connect the iphone to your computer, the changes made on your computer or device are synchronized.
  1. Connect your iPhone to your computer. iTunes should open automatically.
  2. In iTunes, in the source list, under Devices, click the entry for your iPhone.
  3. Click the Info tab.
  4. Select which items you would like to sync. For example to sync only calendars, under Calendars, you would click Sync calendars from, and then click Outlook.
  5. Do one of the following:
  • To synch all calendars, click All Calendars.
  • To limit the calendars that are synched, click Selected calendars and then click the calendars you want to sync.
6. Click Apply.
Hope this helps!
Thanks for using Fixya and you can let me know how helpful I've been by rating this solution.
Apr 03, 2009 | Apple iPhone Smartphone
Trying to synch my SanDisk MP3 player to Rhapsody
This player is a little goofy. The normal method to synchronize is through Windows Media Player. But if you go for the Rhapsody subscription, you have to also sync the device through Rhapsody.
-Tha Mp3 Doctor
Nov 13, 2008 | SanDisk Sansa Clip MP3 Player
How do I get the hotsync to sync everytime there is a change?
You may be used to PocketPC ActiveSync. HotSync is an asynchronous synch model - you synch upon demand but not continuously. Pocket PC devices synch all the time while in the cradle. There are advantages to both models. If you want to synch a Palm OS device, you need to press the button. There are some extra appliactions available on www.palmgear.com that will force your device to synch upon a schdule.
Sep 12, 2005 | Palm Treo 600 Handheld
Why does pocket mirror trawl through all items when synchronising a calendar
The HotSync software on the Mac was never designed to cope with the scenario where you synch with a PC elsewhere. It assumes that you are performing a recovery synchronization when it sees that the handheld synched elsewhere. The assumption with the Palm OS was always that you synched one computer to one PDA. With more propsperous times, the software has not yet evolved at Palm Source (not part of Palm Inc any longer.) With regards to PocketMirror, there is a setting to allow you to synch to more than one PC. The setting is buried deep in the PocketMirror settings for each of the four conduits. The setting allows PocketMirror to see more than one PC as your route to an Exchange server.
Sep 11, 2005 | Palm Zire 71 Handheld
Activesync Problem, Help Pls
Try the following. FIRST & FOREMOST BACKUP YOUR DEVICE TO A "CF CARD" USING THE BUILT IN "CardBackup" UTILITY. This is a much faster option than using ActiveSynch. It ca restore also much faster. Once your files have synched go to options & change the synch options to manual & file conversions to NONE. Remove or switch off the device. Next delete the partnership WITHOUT DELETING THE SYNCH FOLDER !!! Be very careful. Switch on or replace the device on the cradle. Active synch should recognise the device & offer to setup the partnership. Let it do so with "THIS COMPUTER ONLY" option. Once your device is scanned by activesynch one of the options it will offer is of combining the records. Select it & let it synch. I most cases this should solve the problem. Hope this helps.
Sep 06, 2005 | Casio Cassiopeia E-100 Pocket PC
Corinex AV200 Powerline Ethernet Wall Mount - Dual Pack (CXPAV200WME2) Network Adapter Logo
Top Corinex Computers & Internet Experts
David Payne
David Payne
Are you a Corinex Computer and Internet Expert? Answer questions, earn points and help others
