Question about Maytag Dryers
Maytag gas dryer trips breaker when I push the start button
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 71 Answers
Inside transformer is blown and shorted
Posted on Oct 19, 2013
Illeagle
  • 525 Answers
SOURCE: I have a Maytag Neptune
This is your complaint;
"I have a Maytag Neptune MDE4000AYW Dryer. The internal light is on but the control panel will not start the dryer. The breaker did not trip, i have full electricity to the dryer. My settings work but will not preform when i press the start button. Is this an internal electrical problem? Can i fix this myself?"
Thank you for providing a valid make and model number!
Tip: A volt-ohm meter is a valuable tool for diagnosing problems.
My Solution:
!. Sometimes a breaker will only trip 1 side of the 2 sided breaker. Reset the breaker by flipping it off then back on to remove any doubt!
Note: This is not 100% positive, as a breaker can fail on 1/2 the sides, so you will need a meter to test voltage, if you have ruled all else out.
2. Sometimes a thermal fuse in the dryer will open due to a venting issue. The fuse is mounted on the blower housing
or on the element tube. See links for part diagram: http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=516650&PPStack=1
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1660&PPStack=1
See this link for diassembly procedures:
http://www.repairclinic.com/0100_18.asp
Inspect your vent thouroughly for obstructions. Also, inspect your lint filter if you use fabric sheets, by holding the filter flat under running water. If the water beads up and does not strain through the filter screen, replace the filter and avoid using fabric sheets.
3. The door switch may have failed, see link for part diagram.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46718, See item no.6.
4.Wiring: The wiring at the dryer terminal block may have burned up. See link for diagram:
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=516193&PPStack=1
5. Push to start switch failure. See link below:
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1033496&PPStack=1
In an effort to improve my quality of answers, please show your appreciation by rating the effectiveness of my answer.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 16, 2008
  • 4 Answers
SOURCE: maytag gas dryer
This is valid for a Maytag Neptune MDG3000AWW Gas Dryer (I am responding to a problem which was mis-identified as a MDG5500AW Gas Dryer)
NOTE: Motor problems begin intermittantly. They can be temporarilly fixed by blowing out the motor with compressed air. Eventually ALL motors fail. In my case, with six kids it took 10 years for our Maytag motor to fail. YMMV.
  1. Confirm where the burn smell is coming from. This will require you to disassemble the dryer. This is not hard - it will require the following tools:
    crosstip medium screwdriver
    1/4 inch socket
    5/15 inch socket
  2. UNPLUG DRYER
  3. TURN OFF GAS
  4. Disassemble by taking apart the FRONT of the dryer:
    a. Remove the door and opposite side door plugs (crosstip screws)
    b. Remove the front panel - this exposes sheet metal bolts (5/16 inch) some with crosstip on left and right of unit. Set panel aside (right side) WITHOUT unplugging wires
    c. Unscrew all the exposed bolts.
    d. Top bolts left and right secure the unpainted metal hooks which secures the top of dryer. Unscrew these bolts and wiggle the metal retainer hooks off. Lift top and support to create 6 inch gap in the front (top unit hinges in back and has electrical connections - do NOT disconnect wires)
    e. Release belt from pulley by reaching left and under drum (this is out of sight)
    f. gently lift out drum and belt and set aside
  5. This has exposed the interior.
  6. IF your motor still made sounds when pressing the start button, THEN plug the dryer back in and have an assistant press and hold the start button. You press the dryer close door button (on front panel which you set aside) and observe and listen. IF the glow plug in the gas ignition chamber glows bright, it is fine. You may see a slight curl of smoke or smell some smoke from the glow plug. THIS IS NORMAL and indicates your ignition circuit is fine.
    Observe the motor. Listen and smell. IF you see smoke from the motor, or IF you hear a "starting sound" but the motor itself doesn't spin, is very slow to start spinning, or makes racket, or it made a noise and then stopped... THEN your motor is burned out. Confirm by sniffing the motor. IF the motor smells burned, THEN your motor is burned out.
  7. IF you determined your motor has burned out, THEN you can replace the motor for around $100. OR you can replace your dryer for > $700. Your choice. It is slightly tricky getting the motor out. Instructions Below.
    NOTE: If your motor is burned out it CANNOT be fixed because it is a "double wound motor." The motor must be replaced.
MOTOR REMOVAL INSTRUCTIONS
  1. UNPLUG DRYER
  2. TURN OFF GAS
  3. Expose the dryer interior by following instructions above
  4. With the drum out do the following:
  5. Remove the blower cover by unscrewing the 8 screws
  6. Remove the cotter clip securing the front of the blower to the motor spindle (Try using two screwdrivers... You'll need to replace this cotter clip because it will deform)
  7. Remove the wiring harness on the back of the motor
  8. Remove the two motor securing clips holding the motor to the motor support frame (this is tricky - I got them off by leaning on the top of the clip with a heavy screwdriver and a large channel-loc wrench)
  9. Remove the cotter clip between the motor and the blower housing
  10. Remove the two 5/16 inch bolts securing the motor support frame from the motor
  11. Lift out the motor and blower housing
  12. Have an assistant support the plastic blower barrel tines with the motor hanging down and the blower up
  13. Using a hammer and a punch tap the motor spindle (axel) until the blower is free of the motor
  14. Take this motor to your appliance repair center for replacement.
To replace simply reverse these instructions. GOOD LUCK!
Posted on Nov 01, 2008
thedayos
  • 57 Answers
SOURCE: My new maytag centennial electric keeps tripping
Hi Matt
I'm not sure that swapping out the breakers to higher rated ones will give you a solution so I'll throw in 2 cents to see if my advice holds true. Let's start by asking this. Is the appliance "rated" at 220 volts at 30 amps per leg. I assume this from your post as to what it has been rated. Next - How long is the "run" of wire from the junction box to the outlet where the appliance plugs in? This usually does not matter in most households but if the run is of significant length it may need a larger gage wire to support the current draw of the appliance. Lastly, and perhaps most importantly, are the lugs and wire connectors tight at the outlet, the plug, and the breaker box. A loose connection will ramp up the current fast. This is assuming the first two items were met. Tell me if any of this helps and we'll work it out from there.
Thanks.
Len
Posted on Feb 28, 2009
MNTECH
  • 1543 Answers
SOURCE: LG DLE5977W dryer trips circuit breaker
You could set the dryer to manual dry and then no heat and see if the result is the same. If it runs then, you have a short in the heating system somewhere. If it still kicks out the breaker, you've got even worse troubles. Most likely an electronic board, and what ever caused it to go, like maybe still a heating system issue. I*d suggest calling a qualified service tech for this one. In the USA, you can find one at http://www.lge.com/us/support/repair/support-repair-provider-lookup.jsp
Posted on Aug 06, 2009
dmftrucker
  • 1922 Answers
SOURCE: my house circuit breaker kept tripping and
sounds like your heating element has opened up it was probably partially shorted to the case and this was causing your breaker arcing condition previously
Posted on Oct 03, 2009
Control board sparks, smokes and smells when trying to start
Did you have a lightning strike near by? Or power outage with a power surge. Could have shorted the board.
Mar 13, 2015 | Maytag Epic MGD9700S 27 7.3 cuft. Gas...
Hoy to fix my maytag PYE2300 dryer stop working. i push the start button and is does not power up... nor make any noise
Do you have any ticking coming from the timer control when you set the time? Be sure the dryer breaker on the breaker panel is not tripped. You may be missing one leg of your 220 volts from your breaker also. I you have a volt meter you may check to see if you have 220 in to your dyer. BE VERY CAREFUL AROUND POWER, THIS COULD INJURE OR KILL YOU IF YOU DO NOT KNOW WHAT YOU ARE DOING.
Dec 30, 2010 | Maytag PYE2300AY Electric Dryer
Whirlpool gas dryer WGD5540SQ it is getting power, drum does not turn, just hums when I push start button. I checked for blown circuit breaker, i' ve cleaned lint tray and checked vent to outside. I've...
there is a reset button on the motor more then likely it tripped, there are actually two one resets the other trips, but here is a website it will help with the dissemblance of the dryer, Tim:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Oct 19, 2010 | Whirlpool WED5520SQ Gas Dryer
My Maytag Neptune dryer flashes an 88 when I push the start button, there is nothing in the manual about solution codes
lack of power did you recently have a brown out or power outage that may have messed up the breaker in the fuse box box
Aug 18, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My maytag dryer stopped abruptly.
Not sure if you received my last e-mail, but do you have power to the receptacle - because you could've tripped a breaker. And, do you have an electric 240v dryer, or a gas 110v dryer?
Mar 13, 2010 | Maytag Dryers
My house circuit breaker kept tripping and
Sep 24, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Bravos Dryer blinking start button
Manual says it could be a number of things, and you should have a copy of the manual since you've only had the dryer 3-4 months. If not, go to the Maytag website and download.
Some things to check -
1) Press Start/Cancel if dryer was stopped in a middle of the operating cycle.
2) Check that one of the two breakers has not tripped or fuses blown (if an electric dryer) in your breaker panel.
Please reply the flashing code number so that I may can help you further.
Jan 19, 2009 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
Dryer won't start.
Would first check the Breaker panel Breaker and see if it is tripped. Try resetting, if it trips out immediately would call an electrician.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Won't start
Hi check the thermal fuse at the rear of the dryer It looks like this 00208689.jpg
Dec 16, 2008 | Maytag PYG2300A Gas Dryer
Dryers Logo
51 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
